I’m happy to see that you’re listening to your customers too. :+1:
I’m yet to receive my first HeikeLite light, but I have one complaint already.
Stop inflating your numbers. It’s really disheartening to buy a 150 kcd light and then learn it’s 70kcd. Frankly, I didn’t believe 150 kcd, but nevertheless hoped for much more.
The first batch of MT03 released a year ago had problems with the 4S configuration, so only 2S2P was offered since then. Any chance you could go back to 4S again, just like MT07S?
MT02. 70 kcd is from a review
If I knew the real number, I would consider MT01 instead….and probably get MT02 anyway. But I would be more satisfied with it.
If you upgrade the MT07 to XHP70.2, then it makes sense to upgrade MT03 to XHP70.2 as well? People might be hesitant to purchase MT03, worrying it will be updated to XHP70.2 soon as well.
For customers that bought your earlier versions and can prove it, can you offer a nice discount on the new versions of the same models?
I really like the looks and general design of your lights, but I quit using my MT03 and MT07 (first version, both) due to parasitic drain (ruined a nice set of 30Q's) and mushy buttons.
I really like your brand and your lights, you guys keep up with the latest styles, but unfortunately I stopped purchasing your lights when you guys removed turbo from the mode sequence. I was able to turn the light off on turbo so that the next time I turn the light on, it will be on the highest mode…turbo.
Now, all your new lights require a double click. And I think, it’s requires another another double click to get to max.
The double click is nice to have, for when I have the light on medium , and want quick access to turbo. But, to require that from off is a pain.
Please put turbo back in the mode sequence and I’m sure you’ll have more buyers.
Can I get a replacement driver for my MT01? Can you stop ignoring my emails please and let me know whats going on with the replacement driver that you promised? It would be nice to have a working flashlight instead of a $50 paperweight.
improve battery choice description, the light needs button top. You don’t mention it, BangGood say straight that flat tops are supported
I really dislike the UI:
With long waits (especially during mode change) it feels really sluggish
There’s no way to reduce brightness w/out destroying night vision by going through high
The low mode is much higher than I’d like
I prefer ramping to modes
I suggest that you rip it off and replace with some open source BLF firmware. A small 1-time cost of porting, yet huge improvement in user experience.
It may be just my light, but machining of battery tube interior is the worst that I’ve seen so far. Works OK as there’s nothing sharp in it, it just looks cheaper than the $5 lights I’ve seen so far.
I believe a XHP35 HI LED would be a better choice. Now it just doesn’t throw as far as I’d like….though, frankly, I expected so since I learned intensity measurements from a review.
