Xiaomi Mi 2 Powerbank 20,000mAh Review - New 20Ah King?
78 posts / 0 new
will34
will34's picture
Last seen: 44 min 56 sec ago
30-4-2019 Update
Almost 2 years after my initial review and regular use of about 100 full cycles my unit started to show signs of swelling. My power bank is fully charged and ready to go most of the time, which is not optimal for Li-Ion storage but otherwise defeats the purpose of a power bank. And that’s how most people who are not into batteries will use them anyways, so “real world results” nonetheless.
A bit of swelling in pouch batteries is not always dangerous but there is a chance it continues expanding, in which case I must dispose it. One more reason to go with 18650, they also degrade quicker when stored fully charged, but at least won’t became dangerous.
Spins on its belly
Vs flat surface
Xiaomi Mi 2 Power Bank 20,000mAh Quick Charge 3.0 Portable Charger
Unit supplied by banggood for review and testing, product link (aff?): https://www.banggood.com/Original-Xiaomi-20000mAh-Polymer-Power-Bank-2-D...USB-Output-with-Quick-Charger-3_0-p-1114740.html?utm_source=bbs&utm_medium=william&utm_content=chendongling
This is the new version of the 20,000mAh Xiaomi Powerbank, and even though it shares a lot of similarities on the outside with the old one, it’s been completely revamped on the inside. I have already reviewed their new 10,000mAh model and was surprised by the performance, so much that I would say with confidence it is the best powerbank in its class and price range. Will the bigger brother live up to its hype? Let’s see…
Specs from Xiaomi:
Battery Capacity: 20000mAh 3.85V ( 77Wh )
Battery Core: Polymer
Interface: Micro USB, USB
Input: DC 5V/2A, 9V/2A, 12V/1.5A
Output: 2* DC 5.1V/2.4A, 9V/2A 12V/1.5A (18W Max)
Size: 135.5 × 67.6 × 23.9 mm
Weight: ~400g
One of the reasons I love Xiaomi power banks is because they state all the numbers in the spec, including the energy rating which is useful to measure efficiency. This version uses a 3.85V battery which gives it a slight advantage in energy as compared to 3.6V and 3.7V chemistry. Higher nominal voltage and an extremely efficient conversion module gives the Xiaomi 2 the almost unbelievable results in the discharge tests (See below).
Unboxing:
Typical Xiaomi powerbank box that comes with a short USB cable and a brief instruction manual in Chinese (not pictured)
Some info in the back of the box
Build quality and interface:
The Xiaomi Power Bank 2 has great built quality just the like original, even though the casing is fully made of plastic it feels really solid on hand.
Close up of the finish and logo. It has a smooth polished finish with small dots over front and back sides. White plastic gets dirty quick!
Vs. the older version, about 1CM shorter and narrower. A tad thicker but hardly noticeable. Weight comes in at 326gr (new) and 339gr (old).
Vs. another typically sized, 6× 18650 powerbank.
Xiaomi powerbank family
Obligatory size comparison with a S2+
Close-up of the top: button, 4 LEDs to show capacity, micro USB for input and 2x USB out. The matte finish can be easily scratched, but not very noticeable because it is white.
Lots of technical info underneath
In action
Compared to the older model, key differences are:
-No longer uses 6× 3.7V 3,350mAh 18650 batteries, now it has 2× 10,000Mah 3.85V Lithium Polymer cell.
-Quick Charge 3.0 supported for both input and output. (only input for old version)
-Faster recharging, thanks to the reduced CV phase of the new battery.
-Variable output voltage added
-Smaller size, rounder edges
-Low current mode added
Operation and performance:
-It has auto start when a device is connected
-Will automatically turn off after 30 seconds if a load is not detected
-One single button operates the power bank, it will turn on the output or restart it when pressed.
-Double click activates a low current mode, designed to charge/power low power devices such as bluetooth headset, USB lamp, keychain flashlights, etc. These devices draws very small amount of current and in normal mode would not keep the power on.
-Pass-through charge is possible but QC is disabled for both input and output.
Variable output voltage: Just like the 10,000mAh powerbank 2, this one has a variable output voltage. When the connected load is above exactly 1.5A the voltage gets bumped from 5.0V to 5.2V. This is extremely useful to compensate for cable losses and helps to maintain a healthy charge current. I would have preferred a permanent 5.3V output voltage like some modern smartphone chargers, since there is really no reason for manufacturers to stick to exactly 5.0V anymore. A 5.0V output reaches the device at 4.5~4.8V after cable losses and most -if not all modern 5V devices can safely receive up to 5.5V,
The included USB cable is the same that comes with all xiaomi products, a flat type cable that measured 0.09 Ohm resistance at 5V 2A. This is good compared to my other short cables.
Charge test:
-Maximum input using a QC3.0 adapter was 12V/1.5A
-From empty to full it only took 6hr 11min, impressively fast.
-103Wh required to fully charge with an efficiency of 75%
-After being fully charged it draws ~40mA while idle
Discharge tests:
5V/1A: output was completely flat, and it achieved the highest efficiency I’ve ever seen in a powerbank at 98%.
5V/2A: nice and flat output like in 1A test, slightly lower energy.
9V/1.5A: output remained above 9V the whole discharge test.
12V/1.5A: output voltage was sustained above 12V the whole discharge test.
The complete chart, even at 18W output the efficiency remains above 85%. Why don’t we have a flashlight driver like that? Big Smile
Notes:
-I got 975mAh more output capacity than the spec, and unbelievably high efficiency at 98% (Spec’d 93% Shocked ). I wonder if that’s due to capacity being underrated? Either way, it’s a good thing. Same happened with the 10,000mAh version. Lets hope that Xiaomi don’t ever realize this and go cheap on their products.
-Compared to the older Xiaomi 20,000mAh (pictured above), I’m getting roughly 15Wh more at 5V/2A which is a dramatic 25% increase. This is enough to give an extra full charge to a smartphone with a ~3000mAh battery.
-The internal battery is a High density lithium polymer with a nominal voltage of 3.85V, so compared to a common 3.7V 18650 based power bank of the same capacity there is a considerable energy increase. Keep this in mind when shopping power banks.
Compared to other 20,000mAh powerbanks: All tests done at standard 5V 2A discharge rate and charged with a QC 3.0 capable adapter
-Xiaomi 2: 74.4Wh, 6hr 11min to recharge
-Xiaomi 1: 59.3Wh, 6hr 45min to recharge
-Ravpower “porsche design” (pictured): 63Wh
-Vinsic: 62.4Wh, 5hr 10min to recharge (short recharge time thanks to highly efficient input converter)
Final words…
The new king of 20,000mAh? ABSOLUTELY. Most users don’t realize how much better this Mi 2 powerbank performs compared to others, but just look at the numbers! Crown If you liked the 10Ah powerbank 2, you’ll love this one. As always, I put my power banks under heavy use for some time before reviewing and everything was flawless.
What I like:
-Compact size and great build quality.
-Extremely high efficiency
-Strong output charges the most power hungry devices. Recharges very quickly as well.
-Has low current output mode and variable output voltage, which are not offered in most power banks.
-Budget price! At the current price of $30.99, it easily beats other brand name products such as Anker, Ravpower, Aukey.
What I don’t like:
-Plastic construction is solid, but for some people it might look cheap compared to other products of the xiaomi line-up. I’m totally in for an aluminum case version.
Thanks for reading and I hope this review has been useful to you. Big Smile
Edited by: will34 on 05/01/2019 - 00:08
MiG0
Last seen: 1 hour 55 min ago
Thanks for nice and useful review.
M4D M4X
M4D M4X's picture
Last seen: 47 min 44 sec ago
thanks for the great information!
already member of M4DM4X.com ?
the best deals are waiting for YOU!
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
dekozn
Last seen: 4 hours 52 min ago
This might be a stupid question but if the capacity is 20Ah and the stated efficiency is 98% then why don’t we see an output capacity of 19.6Ah?
I’ve never been really good at math so please be gentle but for me 14975/20000×100=74.9%. What am I missing?
Idiot proofing something only creates improved idiots.
dekozn
OK I feel stupid, ofcourse I should have used the Power numbers(Wh) instead of Ah number Facepalm
tjeret
Last seen: 2 years 3 months ago
You can take another way too with Ah calc
With 100% boost converter, Ah available in theory is
Ah bat*(Vbat/Vout)
20.000Ah*3.85V/5.04V = 15.277Ah
Actual result is 14.976Ah
14.975Ah/15.277Ah roughly 98%
Btw, thanks for the test Will34
It is awesome result indeed but to bulky for me
I will stick with 10.000mAh version
tatasal
Last seen: 13 min 18 sec ago
l own several Xiaomi products, and among them are powerbanks for my children, and so far not one of their products has disappointed me, for they are products of excellent quality.
lt’s great to know Xiaomi is not resting on their laurels, and is even improving. Thumbs Up
CRX
CRX's picture
Last seen: 39 min 30 sec ago
Thanks Thumbs Up
dodge_911
dodge_911's picture
Can you get both ports to output QC3.0 at the same time?
I've tried with mine and can't get it to do that.
:: YouTube ::
http://bit.ly/dodgereviewsyt
:: Discord ::
http://discord.gg/fqJEDyy
:: Join the Discord ::
we need more BLF'ers!
MiG0
Only one port can output QC3.0 at any given time.
d_t_a
Last seen: 1 hour 36 min ago
Quote:
Weight: ~400g
This weight seems incorrect. I believe that spec came from some online shop (eg. banggood or gearbest seem to quote that).
The official weight from the Xiaomi website is 330.5grams.
https://www.mi.com/battery20000/
I own one (PLM05ZM) and using a digital weighing scale, the powerbank weighed 328grams.
Using ZKE EBD-USB+ load tester/meter, I did a discharge test (QC3.0 12v @ 1.50A) with the following results, which seem to exactly jive with the one above.
—————-EB Tester Software—————-
Device:EBD-USB+
Mode:D-CC 1.50A 11.00V
Begin Volt:12.27V
Cutoff Volt:12.59V
Capacity:5435mAh
Energy:68.44Wh
Avg Volt:12.59V
Title:EB Tester Software – Mi 2 20000mAh PLM05ZM (full) QC3.0 12v 1.5A drain rate
——————www.zketech.com———————
Total time: 3 hours 38 minutes
What I don’t understand is the voltage kept on increasing as the powerbank gets discharged and shut down. Voltage was 12.18v initially (1.50A load), but just before it completely got drained, the voltage reached a high of 12.78v (all the above measurements are from the ZKE EBD-USB+ tester software).
will34
will34's picture
400gr was from BG spec, The real measured weight as stated in the OP was 326gr for new and 339gr for old version.
There’s also a very small increase involtage in my unit at 12V but I believe that is normal, such small difference can be nelegible. At 5V, above 1.5A the output voltage steps up 0.2V, this is intentional in order to fight against cable losses. I just realized there is no graph for current ramping, will upload one soon.
d_t_a
Using EBD-USB+ ‘Auto-Test’ (0.1-3.0A) on the Mi 2 20000mAh powerbank’s USB port (seems like it can handle 5v @ 2.90A, although voltage drops)
sp5it
sp5it's picture
Last seen: 12 hours 54 min ago
Can anyone confirm that QC from Blitzwolf BW-C10 works with that power bank?
I’m asking because QC from BW-C5 I own does not work with that power bank.
Mike
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
Palus
Last seen: 2 years 1 month ago
Thanks for the review! Seems to have an excellent capacity for its weight. Currently $25.99 at Gearbest with coupon code PBANUK1.
I’m still looking for a good QC3 charging adapter with two outputs and low weight. From what I see on Amazon, most of the adapters seem to be poor quality, making noise, delivering QC current only sometimes, breaking…
d_t_a
This Xiaomi PLM05ZM (20000mAh v2) has one of the most number of supported protocols:
Palus wrote:
Thanks for the review! Seems to have an excellent capacity for its weight. Currently $25.99 at Gearbest with coupon code PBANUK1. I’m still looking for a good QC3 charging adapter with two outputs and low weight. From what I see on Amazon, most of the adapters seem to be poor quality, making noise, delivering QC current only sometimes, breaking…
Do you mean USB wall charger with 2 QC3 ports? I believe Anker’s PowerPort Speed has 63-watt (5-port desktop charger, with 2 QC3.0 ports) and 39-watt (2-port wall charger, both ports QC3.0 capable) versions, including a PowerDrive Speed 39-watt car charger with 2x QC3.0 ports.
Palus
Yes, a wall charger. I cannot find the 2-port PowerPort Speed with EU plug and it seems a bit heavy (130g?). My current 3-port charger (RAVPower, not QC) has a weight of 85g. The new one should not be much heavier.
Edit: I found the Blitzwolf BW-S6 on Banggood, 2-port (1 QC), ~100g, also tested on lygte-info.dk and seems to be safe. Does anyone use this one?
dodge_911
dodge_911's picture
d_t_a wrote:
This Xiaomi PLM05ZM (20000mAh v2) has one of the most number of supported protocols: !https://i.imgur.com/AD7n939.jpg!
What's that meter you're using there?
:: YouTube ::
:: Discord ::
sp5it
sp5it's picture
It is charging Moto Z Play Turbo mode – 3A 5V. Tested by myself.
Mike
maukka
maukka's picture
Last seen: 4 hours 46 min ago
dodge_911 wrote:
What’s that meter you’re using there?
ZY1276
Palus
I watched some videos on Youtube and there it looks like QC is disabled for output but working for input?
https://www.youtube.com/watch?v=KfntN4ZlOCU&t=2m33s
https://www.youtube.com/watch?v=QWmGP8XsHdA&t=9m09s
d_t_a
Based on my quick testing, when passthrough charging is used, QC output is disabled, but QC input can still work (ie. the powerbank is being charged at 12v, whereas the device that’s connected to the powerbank can only be charged at 5v).
dodge_911
dodge_911's picture
Palus wrote:
I watched some videos on Youtube and there it looks like QC is disabled for output but working for input? https://www.youtube.com/watch?v=KfntN4ZlOCU&t=2m33s
Ah, so that was you Big Smile
:: YouTube ::
:: Discord ::
Palus
Did you see me? Wink
But good to know that pass-through charging and QC on the input work at the same time.
d_t_a
While browsing around, I notice another new model from Xiaomi — Mi Powerbank 20000mAh 2C PLM06ZM:
http://www.xiaomitoday.com/xiaomi-mi-powerbank-2c-20-000mah-review-almos...
It is supposed to be a lower-priced alternative to the 2nd-gen PLM05ZM (Mi 20000mAh 2). The PLM05ZM was released (in China) for RMB 149, whereas the PLM06ZM is RMB 129.
But from above review, the lower-cost also means it seems to be a slight step back:
- weight has increased (v1 = 338 grams ; v2= 330.5 grams ; v2C = 358 grams) – the heaviest of the lot (but still a good deal lighter than many 20000mAh powerbanks from other brands (usually 420-460 grams if using Li-Ion instead of Li-Po)
- the length is also slightly longer (probably why it weighs more)
- the same QC 3.0 output (only 1 port can be QC3.0 ; if both ports in use, then both ports can only manage 5v simultaneously)
- no mention of whether pass-through charging will support QC3 input+output (but likely not)
- uses Fitipower FP6601Q chipset (the BlitzWolf BW-S9 uses a FitiPower FP6600Q chipset, so likely similar protocols supported)
- QC3 input is now only 9v/2A ; the v2 PLM05ZM can have 9v/2A or 12v/1.5A input (but probably just similar charging speed) [in my test I got 12v/1.6A charging rate sometimes for my PLM05ZM]
- I notice GearBest is selling this at $29, which is still higher than prices for PLM05ZM (as mentioned, the PLM06ZM is supposed to be cheaper than the PLM05ZM, maybe as it becomes more common) (ie. assuming powerbanks can be shipped to your country; so far I haven’t found any foreign seller that allows shipping of powerbanks to my location – Philippines, not even from AliExpress [which appears to be able to ship 18650 batteries to the PHL via Turkey Post/Belgian Post] )
dodge_911
dodge_911's picture
Palus wrote:
Did you see me? Wink But good to know that pass-through charging and QC on the input work at the same time.
Yeah, ever since I signed up for that Youtube Black thing I get notifications whenever someone watches my vids innocent
:: YouTube ::
:: Discord ::
mrheosuper
Last seen: 11 hours 18 min ago
anyone has any news about newest xiaomi 20000mah (a.k.a xiaomi 20000mah 2c), as far as i know, it’s bigger, nothing more
https://www.gizmochina.com/2017/09/16/xiaomi-launches-20000mah-mi-power-...
and quite cheaper, maybe gonna be new budget king
Forgot my pen
dodge_911
dodge_911's picture
mrheosuper wrote:
anyone has any news about newest xiaomi 20000mah (a.k.a xiaomi 20000mah 2c), as far as i know, it's bigger, nothing more https://www.gizmochina.com/2017/09/16/xiaomi-launches-20000mah-mi-power-... and quite cheaper, maybe gonna be new budget king
Actually literally two post above yours Wink
:: YouTube ::
:: Discord ::
mud_muncher
Last seen: 5 months 1 day ago
Does anyone know a simply way to force these to run at 12v all the time? Is there a wire you can bridge in the USB cable?
mrheosuper
dodge_911 wrote:
mrheosuper wrote:
anyone has any news about newest xiaomi 20000mah (a.k.a xiaomi 20000mah 2c), as far as i know, it’s bigger, nothing more https://www.gizmochina.com/2017/09/16/xiaomi-launches-20000mah-mi-power-... and quite cheaper, maybe gonna be new budget king
LOL, my bad
Thank you
Forgot my pen
eas
eas's picture
QuickCharge requires a timing-dependent handshake to activate the higher voltage/power modes, which is probably a good thing, considering that 9 or 12v could be bad for a normal USB device expecting 5v.
