Emisar D1
Just ordered one from Mountain Electronics in green along with the 18350 short tube. They should have them in by the end of the month.
The list of recommended batteries seems a direct copy and paste from the D4 which has a much higher output (almost three times) which is why I asked.
In terms of power this is true. The reason you have the same recommended batteries is because the D1 and D4 are both FET driven. This means that you get maximum output with batteries that have least voltage sag, so batteries that are (most) high drain. So with both the D1 and D4 you have maximum output with cells like the VTC6 and 30Q, and you have less output with something like a NCR18650GA (but more runtime on lower output due to higher capacity).
Ohhh thanks for the explanation.
So will getting a battery that goes above 10A really matter for this particular light? Doesn’t this light top out around 6A?
Absolutely. Check out HKJ’s comparator here: Battery test-review 18650 comparator
Punch in Sony VTC6 and Sanyo NCR18650GA. Then mark 5 or 7 amps. You then see that the VTC6 has a higher voltage (less sag) than with the GA. The led is sensitive to minor differences in voltage, so with the VTC6 you get a higher output.
So this means that even if you have less than 10A current, there is still a difference in output depending on cell.
So I should just get the efest 18650 (max discharge of 35A) which would provide highest output and be done with it!
Approximately how much less runtime than the Sanyo 3500mah battery?
Sony VTC5A will probably give you the highest output (check it out in HKJ’s comparator), but you sacrifice a bit of runtime.
Efest does not manufacture cells, they just put a wrapping on them. Efest often (always?) puts higher current ratings than that of the original manufacturer, so I don’t like Efest. You also pay more just for the Efest branding. Regarding runtime, I don’t know the capacity of the Efest you mentioned, but it’s perhaps 3000 mAh? In that case you get about 10% more runtime with GA.
Yes, I accidentally ordered the efest for my MF-01, before I read HKJ’s review. Good to know though that the VTC6 are recommended for this light - that was another accidental purchase I made, thinking they were the button top version. Now I’ll be able to put them to a good use, and have some spares! :slight_smile:
Thanks for the info!
It’s a great light, and you can’t go wrong with any of the cells discussed. Just don’t put UltraFire or protected NCR18650B in it or something like that. Cheers man! :partying_face:
I just ordered a VCT6 from Illumination Supply as they were out of stock over at Mountain. I orderd the D1 last night!
I am confused though. It says pre-order on Mountain website - not shipping until 9.29 but I got an email this morning saying it shipped. Are they already in stock and shipping?
Strange. I placed an order yesterday morning and have yet to receive a “shipped” email.
My Emisar D1 arrived a couple days ago. I love it! :heart_eyes:
I took some beamshots comparing it with two ‘pocket throwers’ that many BLF members will be familiar with.
The EagleEye X6R is the rechargeable, dual-switch variant of the EagleEye X6, which the Kronos X6 was based on. Mine has a TA driver from Lexel running Narsil. The X6R’s reflector isn’t identical to the X6, but it’s close.
The Astrolux S3 is the clone of the Kronos X5.
All three lights have XP-L HI emitters in neutral white tint.
Location 1 - D1 vs X6R
Location 1 - D1 vs S3
Location 2 - D1 vs X6R
Location 2 - D1 vs S3
To my eye, the D1 out-throws the S3, but doesn’t quite match the X6R. I think the smaller form factor more than compensates for that. :wink:
When my Solarforce clip arrives, the Emisar D1 will be my new favorite pocket thrower.
I ordered mine today from Mountain Electronics and the order status says Complete, whatever that means.
@goshdogit thanks for those beamshots!
Just got an email from Mountain. Apparently some color/ led combinations are already in stock so mine was indeed sent today! I ordered the black in neutral white. 9.29 is the date where all variants will be in stock I believe.
Awesome beam pics goshdogit, thanks for sharing :slight_smile:
would love to see this compared to Convoy C8 XPL.
Would like to see that too. But I doubt it can out throw a stock XPL HI 7135x8 C8. A modded FET C8 would destroy the D1. But the most important thing about the D1 is that it’s very capable for such a small light. And it can throw while still having a decent sized hotspot and useful amount of spill. I haven’t been this impressed by a pocketable thrower since nineteen ninety eight when the Undertaker threw Mankind off Hell In A Cell, and plummeted sixteen feet through an announcer’s table.
