yes that is the question, does anyone here using those type of flat batteries without having to add this solder? im looking at nkons batteries keeppower but says they are not for flashlights so im not sure… come on simon make a new version of the l6 that takes either flat or not its too confusing what batteries will work or not. u guys must think i am an total idiot lol.
I use the flat top Liitokala 26650s the “naughty” way with a button magnet and nylon washer between the batteries.
Unless the drivers don’t have a spring anymore (too lazy to look back through the thread to look) the flat top has no problem connecting at the top to the driver.
It’s not Simon’s fault. Cree made the xhp70 only run at 6 or 12 volts, not 3 because it would pull too many amps at 3. Then a single lithium battery doesn’t have enough voltage. You have to use 2 in series to get the voltage up high enough.
I think what you really need to ask for is some type of standards in batteries. It’s like the wild wild west with lithium batteries. No standard sizes or shapes like D cell or AA. So we just have to do our best to find cells that fit our needs.
Don’t forget, there is also this little Jaxman series adaptor you can use.
I feel I made a very wise and expedient decision. I traded my L6vn for a K60vn!
Emailed Vinh just in time,the repaired L6vn was in the shipping line! I made a great deal as always w/ Vinh. I negotiated a low enough price and threw in my Orbtronic 26650 for some collateral!!I am only paying $30 more after throwing in the brand new Orbtronics.
Without having the K60, I believe this to be true and a much better light than the L6vn!
Wise and expedient decision on my part!
-Love control rings,way better UI than forward clicky for L6vn!!!
-Bigger light, better heat sinking-less heat.
-Bigger head/reflector more defined hot spot
-Only 500 less lumen and 65Kcd more
-Has a holster
-K60vn Will NOT be top heavy like the L6vn. That light only weighed 7 grams more than my TK75vn and felt like a pound heavier because it was TOP HEAVY!
I enjoyed being on this thread,but I am happy w/ my decision!
Just got my L6 couple weeks ago. Added R100 resistor.
Using Aspire battery, only have 2 pieces.
Want to dedome the led and put SMO reflector on it.
Already purchase that, thankfully.
I do like TA driver, but the shipping almost same the price.
It’s not easy choice for me. Ordering couple isn’t worth for me.
Yes, want to perform that actually.
I’m aware the side effect after the procedure.
Still contemplating about that. Want to purchase some XHP70 and XHP70.2 for spare.
Or like you, to keep the original set.
I’d like to improve the overall output as well as the throw of my convoy l6 5000k flashlight. What’s the easiest way to do this? Swap emitters to .2 with a smooth reflector, swap the driver, or just do a resistor mod?
I’m leaning toward the driver replacement but I don’t know which driver to chose. I have a D4 and it’s my favorite UI of all my lights so something like that would be preferable…
Is it currently stock? If so then swapping to the 70.2 will give you no gain. The Smo reflector is relatively cheap and will improve the throw. A swap to a fet driver will give you the biggest gains in output. You’ll get about 11 to 12 amps with a fet driver and Good batteries. Lexel is currently making the Texas Avenger driver with narsil which is very nice. Also, Richard of mountain Electronics is offering a FET driver. He even has an option to load the D4 ramping firmware on it.
So I would do those first. Then if you still want more output you can swap to the 70.2 and get 17 to 18 amps. It also helps to get a smoother beam pattern.
It is currently stock. I will order the 30mm FET+7135 Driver from Richard and have him flash it with the D4 firmware for 35 cents extra (lol). How hard is it to replace the driver?
I assume I just remove the two screws next to the LED (are they screwed into the retaining ring or is unscrewing them unnecessary?). Then, I unscrew the retaining ring on the head by opening pliers so there’s some sort of friction on the inside of the ring that will allow me to grip it and twist? And then I can just desolder the wires from the old driver that are going to the LED and e switch and solder those onto the new driver? Is it really that simple or am I in over my head?
Is there a recommended cheap soldering iron and type of solder I should buy? My old radioshack iron got lost in my move years ago.
I have those Liitokalas and I just put a small flathead under the flat top and bent the metal upwards enough that the batteries now work in series without the nuisance of a button magnet. No soldering necessary. FYI, I’m not sure if I have genuine Liitokalas but it should work either way.
The 1 or 2 screws by the led prevent the mcpcb from rotating when you tighten the bezel.
The driver retaining ring has 2 holes in it. I use snap ring pliers to fit in and easily turn it. Or you can take needle nose pliers and grind the tips down to a smaller diameter.
The rest is all correct. 4 wires to unsolder from the old and solder to the new.
You want to use rosin core wire for electronics. Typically 60/40 tin/lead Sn/Pb, roughly 3% flux.
The cheap soldering irons are okay, but not very high quality or very powerfull usually. Before I bought my digital soldering station I used this model for many years. http://www.frys.com/product/4825190
and still have it as a backup. Pretty cheap with adjustable heat and 50w of power. The 3 o’clock knob position is good for circuits and max is good for automotive wires. So not a lot of adjustment range, but still nice.
