It’s updated in the repository now.
One thing I am noticing in the BLFA6_emu is that the attiny>13 builds (the only ones that actually fit without removing a strobe or something) , the present version of the config does NOT use temperature step-down bump-up. It uses standard bistro "regulation". That's probably not how I meant to have it. I'll most likely change that in the future (already did in my development branch). Of all the builds that should get that feature by default, it seems this one should. I mean this feature was actually inspired by BLFA6's timeout in the first place. Oops. Oh well, not a problem until someone actually has it working, not to say that it's broken, we don't know yet, it may just be broken/not-configured-for KFulton's particular hardware, just don't know.
@KFulton Come to think of it, this may very well be your "bug". The bistro temperature regulation fluctuates the level up and down to try to control the temperature (I don't really like it personally, but it's all good because others do). Were you using turbo? Even if you weren't, maybe there's an issue with temperature readout, the default calibration, etc. One thing you could do try if you play with it again is going in the temperature calibration mode (menu 7), and clicking out during the initial 2-second low light phase. That should disable temperature regulation.
Bistro’s thermal regulation is pretty bad, TBH. It was barely sufficient for a single emitter in an X6v2 host, and probably not a good idea on anything with a higher power-to-thermal-mass ratio. I’ve made much better methods since then, but I haven’t tried to make them fit on attiny25 for bistro yet. I did at least put an upgraded method into Crescendo, but it takes a sizable chunk of the ROM and the adjustments are still pretty noticeable. The Crescendo regulation pattern looks like this:
Note: It’s normal and expected for the lumen output to rise a bit as the battery gets low, because there is less voltage difference between the battery and emitters… and therefore less heat. So, it can put out more light at the same temperature. And it aims for constant temperature, not constant brightness.
For what it's worth, I quite like the step down I've implemented. For anything but trying to get max lumens on a bicycle (changing wind conditions, undesirable to have operator intervention) I don't need anything more. As I've said before, my new method is intended to supplement TURBO modes, not regulated sustainable light levels. TURBO should go beyond sustainable and be available in bursts when you decide you need it. For turbo, presumably you're holding the light and in normal operation you don't even truly need anything on a decent quality light where the electronics won't overheat without the case getting hot. This thing provides a measure of protection in case you forget and set it down, while still providing the above, and the behavior will feel very similar to BLFA6, just auto-tuned to the thermal capacity of the light.
The new thing does this very very well in my opinion. I might just go ahead and make it default in classic and tripple-down as well if even the inventor isn't crazy about the old thing. Of course it's still not a regulated mode. It's a turbo protection.
Oh, and this is a nice plot. Well done.
Awesome, I didn’t remember that you upgraded bistro’s thermal code for bistro-HD. It looks like it does better than bistro in quite a few ways.
I’ve been meaning to merge the updates into regular bistro, or at least the parts which work on the old hardware, but I’ve been preoccupied with other projects. I was probably a ferret in a past life, because I like shiny things and my attention span is— ooh, what’s that shiny thing over there?!
If you ever get the urge to do runtime graphs, zak.wilson’s ceilingbounce app makes it pretty easy. I found it extremely useful when testing thermal regulation algorithms and a few other things.
Normally I don’t really care about thermal regulation. It’s easy enough to regulate the temperature manually. However, I’ve found that companies who sell lights don’t want to sell anything which could overheat when given to a monkey. So to make them happy I’ve spent way too much time trying to monkey-proof things lately.
BLFA6_EMU issues
I can now can confirm that 1.3-r2 BLFA6-emu was designed for people who embrace the unexpected, who like surprises, who are not frantically trying to control everything around them. If you are a free spirit like this, I will bring back 1.3-r2 for you. If you prefer to be more boring and control-freak like, and want modes to be actually predictable, you should use verstion 1.1 for BLFA6 for now.
I don't know what's causing this. 1.1 does work, but it has (non-problematic) quirks too. First, on first boot it starts in the menu, not horrible, but quirky, probably not too hard to track down. Second, I did get the same random mode change behavior with 1.1, but only when it running it still plugged into the usbasp. So that's interesting. One thing 1.3 did was "improve" pin state settings, and leaving it plugged into the usbasp is likely to pull floating pins up or down.... hmm. It's usually a bad idea to run that way, and often does strange things, but it's interesting that this time it does this particular strange thing.
1.3.2-r2 now has blfa6 still broken, but differently, so that may be a clue too. I'll have to track it all down. It's very likely either the pin state changes, thermal regulation changes, or changes to the fast presses code, as those are basically the areas with changes. It may not be isolated to only BLFA6, although I don't see any problem with tripple channel OTSM or OTC.
solved
I was initializing the default mode at startup but it has to be initialized after failing to read a saved mode. The failed read left it at 255. This resulted in a chain of undefined events that eventually led to an array under-read to set the level from some random changing piece of memory. The bug existed in 1.1, but other randomness resulted in it starting in the menu which actually fixed the mode_idx.
This was all fine on other builds because they used a different mechanism for first initialization, which is probably why I missed it.
The next release will include this fix, and probably not much more, so as to hopefully make a it a more stable release, not a more featured one.
Voltage read-out handbook: dividers, Vcc, "internal", LDO, demystified
Adding some sections to the manual in next release:
Appendix A. Voltage Readout Methods
Method 1, Classic divider (Non-OTSM, 1S or series):
Config options: READ_VOLTAGE_FROM_DIVIDER
Traditionally voltage is read across a voltage divider made from the R1 and R2
resistors. The ADC readout is made relative to the internal 1.1V reference.
In other words the ADC result is V_divider/1.1V * 255. This method does not
work for OTSM, because the voltage pin detects power off when voltage is below
about 1.5V. For this method, all divider voltages must be below 1.1, which
won't work for OTSM.
When to use: For any build without OTSM
Advantages: Works in 1S and 2S, 1 point calibration possible.
Disadvantages: Doesn't work with OTSM, requires a divider.
Method 2, inverted (aka "internal") reads (1S OTSM):
Config options: READ_VOLTAGE_FROM_VCC
This has been become known as "internal" voltage reading. It effectively just reads
Vcc, or the voltage on the supply pin of the mcu. However it does this
actually reading the internal 1.1V reference, but reading it referenced to Vcc,
essentially inverting the result. The ADC value procued is 1.1V/Vcc * 255. And
clearly Vcc= 1.1*255/ADC. It works well when Vcc represents the battery
voltage, ie in 1S.
When to use: Can use for any 1S build, but useful for 1S OTSM
Advantages: Should work pretty well with no calibration, and easy to adjust.
Can be used on small boards with no voltage divider.
Disadvantages: 1S only, Calibration theoretically more difficult to get exact.
Method 3 Vcc-referenced divider reads (LDO OTSM method)
REFERENCE_DIVIDER_READS_TO_VCC
Like method 1, but references the divider read to Vcc. ADC result is
V_divider/Vcc * 255.
When to use it: This works for any LDO build, ie builds where Vcc is regulated
and can be used as a reference. It is only needed though for OTSM LDO builds,
but is likely to be better than Method 1 for any LDO build, due to the more
stable voltage reference.
Advantages:Most stable voltage reference can mean calibration-free.
Disadvantages: Requires regulated mcu input voltage (won't work in 1S)
Note, this may work on zener builds in theory, but depends on the stability
of the zener (for OTSM it also requires a quality schottkey protection diodes and
depends on the leakage of the zener).
Summary:
For non-OTSM builds with a divider the classic divider method is fine.
For 1S-OTSM or 1S with no divider or 1S for calibration free use, use inverted
reads (Meth 2).
For LDO-OTSM builds, use Vcc-referenced divider reads. (Meth 3)
Any OTSM build must have separate builds for 1S and LDO.
Build details explained
Several preconfigured builds are included. Many represent rebuilds of older
versions. Level of testing varies widely but many of the features included in
the builds are tested (a few aren't yet). All builds now include the new thermal control method. Most now include powersaving (Noah's torch: 40 days and 40 nights of moon mode).
default: This has no gauranteed setup. Probably will remain a Tripple build and
may have new features come and go. It's purpose is to be THE definitive
baseline configuration file, including all the latest build options (although
some will be commented out, but still there). If starting a new configuration
from scratch or studying the options, this is the one to look at.
II.1 attiny13 compatible builds (will auto build for attiny13 and above)
biscotti-HD:
Based on TK's biscotti,
Target layout: nanjg105D, 1-channel FET only
Limitations:
Very minimal, no OTC, no med press, noreverse, no hidden modes,
no muggle, no moon.
Features:
Includes turbo-timeout/bump-up in attiny13.
3 strobes, 4-bar battcheck, LVP, OTC-less short-press detection.
HD Features:
Original biscotti included no thermal or turbo-timeout.
Extra room in HD allows TURBO timeout/bump up (like BLFA6) in attiny13,
or the new bistro-HD thermal step-down in bigger attiny's.
Corruption protection for OTC-less press timing makes clicks more
reliable. (SAFE_PRESSES)
Modgroups:
13 modegroups including strobe groups and reverse to make up for
minimal features.
Notes: There is no reason a BLFA6-emu-like build cannot be constructed for a
convoy board layout.
battcheck-divider: flashes adc channel for voltage read from divider using 1.1V
internal reference.
attiny25 compatible builds (everything els):
BLFA6_EMU-HD
Mimics BLFA6_emu code, but configurable with any bistro-HD features.
Target layout: BLFA6 2-channel FET+1, but doesn't fit on attiny13
Only for attiny25 and higher.
Limitations:
battcheck is "only" 8-bar version (by tradition), No OTSM in default
config (but can be for attiny25+)
Features:
Almost full bistro features: OTC, medium clicks, reverse, hidden, muggle,
moon. 8-bar battcheck. Temp calibration in attiny25+
HD Features:
Includes TURBO timeout/bump up (like original) in attiny13, or new thermal
step-down/bump-up in bigger attiny's.
Modegroups: Very simple, only 2 groups included, 7 modes and 4 modes.
Strobes and turbo are in hidden modes.
classic-HD
HD version of classic bistro
Target layout: BLFA6 2-channel FET+1, only for attiny25 and higher.
Limitations: No OTSM in default config (but can be)
Features:
Full-featured: OTC medium clicks, reverse, hidden, muggle,
moon. Volts+tenth battcheck.
HD Features:
Bistro-HD thermal step-down.
Modegroups: 10 modegroups, from 1 1o 6 modes, including strobe groups.
Strobes and turbo in hidden modes.
trippledown-HD
Essentially identical to classic but configured for a TA 3-channel
FET+7135s+7135 board. Uses original bistro tripple-down modes.
TAv1-OTC-HD
FET+7135s+7135 board, and TA's extended modegroups. v1 refers to version 1
of the TA boards.
Modegroups:
Includes TA's v1.3 modegroups, 26 modes in all including a two
added by me (HD has room for more)
See Tav1.3+ modegroup listing in Apendix below.
HD Features: As all before uses new thermal control.
Benefits from added space to get a couple of new modes.
TAv1-OTSM-HD
The flagship build. OTSM Uses large cap to run timer during power-off,
creating reliable, stable click-timing.
Target layout: TAv1 tripple with OTSM components (see details in manual),
1S only for this build.
Otherwise the same as TAv1-OTC, but uses "internal" (inverted) Vcc voltage
reads. This generally does not require calibration to be pretty close to
right.
HD Features: OTSM, Vcc read, HD thermal control
TAv1-OTSM-LDO-HD
Same as TAv1-OTSM-HD, but uses vcc-referenced divider reads needed for OTSM
in builds >1S. Works on LDO or zener builds if appropriate diode (or high
quality LDO) is used.
HD Features: OTSM, vcc-referenced divider reads, HD thermal control.
highly experimental builds
e-switch-noinit-HD:
This is an experimental build for e-switch support.
Layout: TAv1, 1-S or LDO, no OTC, standard TA divider
Features: standard bistro with TAv1.3+ modegroups
HD features: Eswitch, HD thermal control.
Note: almost completely untested
dual-switch-OTSM-HD:
This is an experimental build for dual switch, e-switch plus click switch,
with OTSM timing for the click switch.
Layout: TAv1, 1-S only version, OTSM parts, no OTC
HD features: Eswitch, HD thermal control,
adds dual-switch-noinit: Enables noinit timing control on clicky switch in
a dual-switch light.
Note: completely untested, Use the highest reccomended OTSM divider resistors
(or try a bit higher) to reduce drain during e-switch off. With 4kOhms ,drain
will be around 1mA which is about 120 days of power from a 3Ahr battery, but
voltage drops continuously over that time. Power it off with the
click switch when shelving it.
dual-switch-noinit-HD:
with no timing cap on the click switch.
Layout: TAv1, 1-S or LDO, no OTC, standard C2 is fine (not OTSM), standard TA divider
dual-switch-dumbclick-HD:
where click-switch does nothing (no mode change), light comes back on as it
was, like a long press with mode memory. Especially useful if e-switch is
set to not use mode memory, best of both. Requested by Lexel.
adds dual-switch-dumbclick: Overrides all mode changes if click switch is
press--> just turns light off, and back on as it was.
dual-switch-turboclick-HD:
where click-switch always goes to TURBO
adds DUAL_SWITCH_TURBOCLICK: click switch always goes to first hidden mode
(TURBO in this case).
Note: completely untested. Likely non-sensical, eswitch needs low leakage
but OTSM needs fast leakage, probably 1mA anyway.
4-channel-dual-switch
This is an experimental build for dual switch, and 4 pwm channels
Really it's just a rediculous concept demonstration config to prove how much stuff
can compile and still fit in an attiny25. The concept was actually tested a
little at some point though, with 4-channels certainly working, but calling it
experimental is an understatement.
Layout: quadrupledown, 1-S only, OTSM cap and parts,
4th PWM channel on OTC pin. E-switch and click switch both detected
on voltage pin.
HD features: Eswitch, OTSM, 4th-channel PWM, internal Vcc read, HD thermal control
Modegroups: Presently it's actually just setup with the 3-channel modegroups of
TAv1.3+, so it's not really even using PWM4. It would need customization.
Note: almost completely untested, would need a separate build for LDO version
(because it uses OTSM).
Have you tried 4-channel PWM on hardware?
I got it working in FSM, but the 4th channel is inverted and I haven’t found quite the right tweaks yet to un-invert it.
Yes, I tried it, although I don't promise that it works in precisely the latest build combination, but the code for it should be fundamentally fine. Yes I definitely had inversion problems at certain stages of developing a solution at least. This is precisely one of the biggest cases the simulator came in very very handy. You can step through tick for tick and watch what the timer ramps and matches are doing and see when the interrupts get called, and watch your portb values.
I don't recall all the details now, maybe it will come back to me. Just looking quickly at my code, it seems I set portb on compare match, and clear portb on max. That does sound pretty backwards and even seems contradictory to my not very clear comments for the interrupts, and I kind of recall being temporarily((and now again) confused by this. I'll see if I can get a chance to run the simulator in the next few days and try to remember what's going on.
Mostly unrelated, but the biggest problem in the end was getting the light to shut off. Again I forget the details, but there is some delay or jitter in the interrupt calls that makes full off not happen. So I passed a global (actually a general purpose register bit, to facilitate streamlined assembly interrupts) to the interrupt handlers that disabled them entirely for mode 0. I didn't test extremely low modes extensively. As I recall the timing error on the simulator was around 6 timer ticks, but the simulator runs I think at 1MhZ, so one could hope that's about 1 tick in the real world.
Wish I could remember this better, might soon.
I do seem to recall that my timer is counting down, not up, and that does explain the backwardness. The thing I don't remember is why it's counting down. I think this is configurable right? So did I configure it backwards for a reason? I don't recall.
Update: Well, I just ran the simulator, and it's definitely counting up (and the manual says it should). So ... hmm.. So let's define the question better. Did you copy my implementation and that's inverted or did you re-implement it and yours is inverted? I've got a test rig read to flash and can test this again very quickly as soon as I get to it. It turns out I'd forgotten, but the modegroups included do include a 4th pwm for testing still, so it's ready to test as is. I'll give a shot again soon.
In the end though, if it's inverted, reversing the interrupts is clearly the cure.
I implemented it last month sometime, and didn’t know you had one until yesterday. I’ll have to check how yours works and see if it resolves the issue I ran into. The inversion isn’t really a problem though; it’s just inconsistent compared to the other three channels. A bigger problem is that the lowest few levels appear less stable, but it sounds like you ran into something similar with inconsistent timing.
For my purposes it’s still fine… but if there’s a way to improve it I’d like to do so.
Yeah, I'm starting to wonder if the header file has the interrupt vector numbers swapped. It's worth a look at the header or the proprocessor output to see. No reason to stay inverted though. Just swap the interrupts.
I tried to compensate the low-level timing error and failing. In the end, the off-override was the way to do it. You save quite a few bytes by keeping these interrupts in carefully crafted assembly that doesn't touch any registers, and getting the override variable to work with that was fun. The trick is that if you use the machines gpio registers (which aren't normally used for anything) that you can do conditional logic with them without first copying them to working registers (which would clobber something in the interrupted process, which would thus need the usual full stash and restore mechanics the compiler performs).
Well, the header is fine. It's also possible that my interrupts are just backwards and broken now. In the end I used timer1, non-phase, which should be pretty simple.
So funny enough, my interrupts were reversed. I think I know why now too. I remember switching this from some testing last minute and thinking it seemed wrong. It was, that test was flawed too.
Anyway, I'd never tested with a proper driver (just a resistor from the mcu) until now. With a 7135, I just tried a moon level of 4/255 at 16khz. It works fine. I didn't test down to 1. 255 works too and everything in the middle. So I'll be swapping the interrupts back as they should be in the next release.
In the end though, no, there's nothing inverted about it. It works the way I'd expect it to (which just happens to be wrong presently).
version 1.4 posted,
* 1.4 Enhancements:
* Applied TEMP_STEP_DOWN to all configs as default now, replaces bistro thermal regulation.
* Added an eswitch-TA-HD build (hunh.. why wasn't that there before?). Experimental single e-switch build.
* ALthough dual-switch-noinit should also work on a simple e-switch light.
* Added safe_presses to dual-switch-noinit-HD
* 1.4 Bugs fixes, cleanup, etc:
* Fixed bug in 4-channel PWM.
* Fixed bug where fast presses wouldn't time-out in a strobe mode.
* Fixed mode_idx initialization when FIRSTBOOT wasn't used (Kfulton's BLFA6_EMU random-mode bug, first exposed in 1.3)
* Arranged for safety check to prevent corruption etc from potentially resulting in getting stuck in non-existent override mode.
* No code-size cost for this check! Corruption may still cause an un-predictable brightness level, but will reset on next short-click.
* This is actually a secondary guard for the BLFA6 random-mode bug and other similar problems.
Hmm I got drivers with odd behavior
it has extremly low timing for the medium press
ist almost impossible to do short clicks
I checked the 47uF voltage it falls slowly when the switch is pressed
also all parts were checked and the solder pads soldered by hand again
Then i tested another Driver with v1.4
It seems the newer versions of OTSM hex make this
the old v1.3 from march works well
Thanks for the feedback. I found the problem. I accidentally sneaked in an incomplete part of a new feature that I thought I'd commented out. Simple fix. I'll release an update 1.4.1 along with a new 1.5. In a few minutes.
This actually confirms to me that I should finish that new feature. I actually almost like this new timing (it's exactly twice as fast for short-med threshold, although it wasn't exactly meant to be). The new feature is supposed to allow it to be right in between those two speeds without losing much cap time. Of course the actual speed would still be adjustable, just more resolution for the adjustment. Well no complaints about the old timing, so probably not a priority still. With twice as fast I could just BARELY manage a short click with double-clicks, if I tried very hard. To me, that's almost perfect, but a little too fast.
Posted version 1.4.1 (just fixes the timing bug) and 1.5 (fixes many bugs in e-switch build). I tested timing on both, they're working much better.
