It is the right stuff for this kind of application. Just as it is for e.g. grounding straps on cars, and aeroplanes, that have to survive lots of movement and vibration, with massive current, where ordinary wire wouldn’t last ten minutes.
I've had them broken, come loose - when you do enough lights that get sent out all around the world, you have to consider these things and learn quick. Soldering is tricky - it creeps up the braid. In this type of use, I don't see much flexing there. Certainly the PCB is raised by the thickness - might not be much though. Only concern I see in this usage is coming loose from the top of the spring, but even so, if flopping around can't do any harm I suppose. I used to use braid as the only way of doing bypasses, but after several failures, gave up on it, as, I thought, many others did. There's also a good reason why bare exposed copper isn't used much. Silver coated multi-stranded copper is quite reliable.
Also not a fan of the copper braid (Solder Wick) in just the spring bypass. The short length and 2 close by solder points, along with hardening flux usually makes a single or small flex point subject to breaking there.
I guess there s benefit in using copper braid opposed to solder wick, no flux to harden except the amount you apply, if any. Also the solder is less likely to wick down stream as fast or as bad. Tops of AlexGT springs look good in that aspect with minimal wicking. Going to the screw as he did is the shortest and most direct contact possible to the housing.
The way I try to keep the solder from creeping up the braid is by covering most of it with pliers that absorb the heat and prevent the solder from going up the only thing exposed is the piece of braid that is being soldered. Hope it made sense…
I am currently looking for a silicone wand diffuser that can be attached to the head for use as a lantern like the klarus silicone diffuser that fits perfect for the Manker U11
Swapped the switch leds to orange. I video-ed doing it but watching a 12 minute video with crappy focus is a lot to ask for the reader of this post :party: . Still here it is, to show how messy the act of modding can be, at least my way of modding. :laughing:
Thanks djozz for the ‘uncut’ video. Those leds are so small… but you make it look rather easy, not even removing power on the light - but at least you know right away if it works. I didn’t hear any cursing either…
I was expecting that you would ‘try out’ each led on the board to determine which way to solder them, but you seem to know this off hand… How do you know the +/- on the leds before soldering?
There’s usually a marking on the back of the led pointing from + to - . The Q8 switchboard conveniently shows an arrow too (a diode symbol to be precise) too, between the solder pads.
On the front of the leds you can figure it out too, the - is the cup containing the die, the + is the wire going into the cup from above. And if there’s a green dot on the front, it is on the minus side.
Nitpicking, but ballsy to do it powered, to demonstrate.
I think you were shorting out the MCU output to the LEDs a couple of times when removing them (when both went out) ?. Encouraging that it survived a couple of brief shorts to ground. Maybe a “don’t try this at home” warning ?
