July 31st 2017 Update
1.IMALENT DX80 8x XHP70 2nd Generation 32000LM Outdoor Search LED Flashlight 806M-- 25% OFF
Original Price: 379.95
Coupon Price: $284.96
Coupon Code: BRANDIML
Aug 16th 2017 Update
1.JETbeam II PRO Copper XP-L HI Anniversary Limited Edition 510Lumens Tactical EDC LED Flashlight
Price: $122
2. Mecarmy PT26 9x XP-G2 S4 3850Lumens Rechargeable Ultra Bright LED Flashlight +26650
Price: $178.90
3.Nitecore HC70 XM-L2 U2 1000LM Cave Exploring LED Headlamp With Battery Case
Price: $99.95
4.4PCS Samsung INR18650-30Q 3000mAh Unprotected Button Top 18650 Battery With Protected box
Price: $21.99
5.Nitecore TIP SS Stainless Steel 360LM Metallic USB Rechargeable LED Keychain Light
Price: $34.95
6.WUBEN T103 XHP35-E4 1280Lumens 7Modes Rechargeable LED Flashlight +18650
Price: $72
7.Fenix TK65R XHP70 3200 Lumens Rechargeable LED Flashlight
Price: $219.95
Link: https://www.banggood.com/Fenix-TK65R-XHP70-3200-Lumens-Rechargeable-LED-Flashlight-p-1181208.html?
Sep 4th 2017 Update
Hello Guys,
The BLF Q8 already online, and we will make preorder for it on Sep 7th,the price is much cheaper than the original price, let's look forward for it together. By the way, thorfire and banggood is the cooperative partner relationship, so the lights will ship on Banggood directly.
Features:
• Compact and lightweight 4500 Lumens flashlight
• Utilizes four XP-L LEDs
• Uses four 18650 batteries for maximum runtime up to 1500hours
• Features advanced temperature regulation (ATR) technology
• Innovative side switch accesses various modes and functions
• Integrated power indicator in side switch indicates remaining battery power
• Power indicator displays battery voltage accurate to 0.1V
• Intelligent memory function for brightness levels
• Direct access to ultralow and turbo outputs
• Toughened ultra-clear mineral glass with anti-reflective coating
• Stainless steel bezel ring protects core components from damage
• Constructed from aerospace grade aluminum alloy
• HAIII military grade hard-anodized
• Waterproof in accordance with IPX-8
• Tail stand capability
Package included:
1 x BLF Q8 4x XP-L 4500LM Professional Super Bright LED Flashlight
2 x Flashlight Body Tube O-ring
1 x Flashlight Head Lens O-ring
1 x Switch cover
1 x English Manual
Note:
Before ordering please make sure that you know how to operate the flashlight.
How to use the UI: bit.ly/narsilinfo
For the safety to the battery: bit.ly/lionsafety
For more information to see: bit.ly/blfq8
Sep 18th 2017 Update
1.Jetbeam E40R SST-40 N4 BC 1150LM Rechargeable EDC LED Flashlight 18650/CR123A
Original Price: $64
2.Klarus Titanium H1A XP-L V6 550Lumens LED Headlamp With Two Side Lights
Original Price: $99.95
3.JETbeam E20R SST40 N4 BC 900Lumens High Brightness Rechargeable EDC LED Flashlight
Original Price: $58
4.JETbeam TH20 XHP70.2 3450Lumens high-performance Tactical Flashlight
Original Price: $139.99
5.Klarus Mi1C XP-L HI V3 600Lumens Mini-might Brightness EDC LED Flashlight
Original Price: $48.95
6.LUMINTOP SDmini II XP-L HI 920LM USB Rechargeable LED Flashlight With Side Light
Original Price: $49.90
7.Klarus XT12S XHP35 HI D4 1600Lumens Magnetic Charging Tactical LED Flashight
Original Price: $86.95
Sep 26th 2017 Update
1.Astrolux MF02 XHP35 HI 2700Lumens Long Range Searching LED Flashlight 1697M
Price: $119.95
Preorder Price: $84.95
Features:
-New Astrolux searchlight with a maximum throw of 1697meters
-Utilizes a XHP35 HI LED
-Powered by 4x18650 batteries
-Max runtime up to 300 hours
-Max throw up to 1697 metres
-One single switch provides access to all functions
-4 brightness levels and 3 special modes selectable
-Light off or Normal mode, click twice to enter turbo or click three times to enter tactical strobe
-High-efficiency boosting constant current circuit,stable property and physial reverse polarity protection.
-Direct thermal path(DTP) copper board
-Intelligent temperature control design,automatically reduce lumen output when temperature is higer than 55 degree in turbo
-Breathing light lock-up design,it detects voltage and battery percent
-Integration and high efficiency optical lens
-Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish
-Standard 1/4 inch Tripod mount
-Waterproof in accordance with IPX7
-Tail stand capability
Package included:
1 x Astrolux MF02 XHP35 HI 2700Lumens Long Range LED Flashlight
1 x Lanyard
1 x Tripod Mount Screw
1 x Back Strap
2 x O-ring
1 x Flashlight Holster
1 x English Manual
Note:
Do not reverse setting the battery to protect the flashlight.
Do not open the head to check anything to protected the driver and leds.
Please use unprotected button top or flat top 18650 battery,with button top will have better performance.
Please be careful when install or take down the battery from the battery holder,it will be easy to break down the pill
any code for MF-02?
MF-02 also in Neutral White?
no double click for instant turbo? >.< this is going to push me away from buying the light
I got still some XHP35 E2-3C in 5000K left
It says ‘click twice for instant turbo’.
oh my bad
im getting blind kakaka
Stop pointing flashlights at your face while double clicking! :laughing:
Now the preprder price is $84.95, you can order it directly.
No neutral white?
Oct 12th 2017 Update
Hello Guys,
We have many new arrivals recently, such as BLF Q8, Astrolux MF02, HaikeLite MT03 II and so on. And a bigger news, we will begin to sell Fitorch flashlights on our website from now on. More information, you can click here: https://www.banggood.com/search/fitorch.html?
1.36% OFF For Fitorch EC10
Code: EC10
Link: https://www.banggood.com/Fitorch-EC10-XP-L2-700Lumens-5Modes-Mini-Tactic...
2. 30% OFF for Fitorch P20R
Code: P20R
Link: https://www.banggood.com/Fitorch-P20R-XP-L2-1180Lumens-Rechargeable-Tact...
3. 26% OFF for Fitorch ER16
Code: ER16
Link: https://www.banggood.com/Fitorch-ER16-XP-L2-1000Lumens-Magnetic-Tail-Rec...
4.30% OFF for Fitorch P30R
Code: P30R
Link: https://www.banggood.com/Fitorch-P30R-XP-L2-1180Lumens-RechargeableCharg...
5. 18% OFF for Fitorch P30Z
Code: P30Z
Link: https://www.banggood.com/Fitorch-P30Z-XP-L2-750Lumens-5Modes-High-Bright...
6. 31% OFF for Fitorch MR35
Code: MR35
Link: https://www.banggood.com/Fitorch-MR35-XP-L2-1200Lumens-5lightcolors-Rech..
Oct 18th 2017 Update
1. Nitecore HC33 XHP35 HD 1800Lumens L-Shaped LED Headlamp
Price: $64.95
2. IMALENT BG10 XHP50 2300LM LED Bicycle Light
Price: $56.95
3. AMUTORCH JM70 XHP-70 1200Lumens Brightness Long Range Searching LED Flashlight
Price: $69.99
4. AMUTORCH JM70 XPL HI 1200Lumens Brightness Long Range Searching LED Flashlight
Price: $59.99
5. Nitecore HA20 XP-G2 + Two F5 Red Light 300LM Unibody LED Headlamp
Price: $44.95
6. Rofis R1 XM-L2 U2 900Lumens Magnetic Tail Magnetic Charging EDC LED Angel Flashlight Headlamp
Price: $69.95
7. Wuben T101 XHP70-N4 3480Lumens Tactical LED Flashlight
Price: $120
8. AMUTORCH AM30 XHP-70 4000Lumens Brightness Magnetic Charging LED Flashlight
Price: $76.69
9. Klarus Mini One Ti XP-G3 130Lumens USB LED Keychain Flashlight
Price: $39.95
Oct 30th 2017 Update
1. Maeerxu M8 XPL 1200Lumens Stepless Dimming Long Range LED Flashlight
Price: $32.99~$36.69
Nov 6th 2017 Update
1. Astrolux S42 Flashlight+Samsang 18650 30Q battery
Price: $39.95
2. Astrolux Ti3A LED Flashlight
Price: $18.95
Price: $29.95
Some interesting new Astrolux lights there!
Dec 6th 2017 Update
1. Klarus Mi1C Ti/Cu XP-L HI V3 600Lumens Mini LED Flashlight
Price: $54.95~$69.95
2. HaikeLite MT07S HI 3000Lumens Long Range LED Flashlight
Price: $89.95
3. Convoy S9 XM-L2 580Lumens USB Rechargeable LED Flashlight
Price: $19.95~$20.95
