Features:
-New Astrolux searchlight with a maximum throw of 1697meters
-Utilizes a XHP35 HI LED
-Powered by 4x18650 batteries
-Max runtime up to 300 hours
-Max throw up to 1697 metres
-One single switch provides access to all functions
-4 brightness levels and 3 special modes selectable
-Light off or Normal mode, click twice to enter turbo or click three times to enter tactical strobe
-High-efficiency boosting constant current circuit,stable property and physial reverse polarity protection.
-Direct thermal path(DTP) copper board
-Intelligent temperature control design,automatically reduce lumen output when temperature is higer than 55 degree in turbo
-Breathing light lock-up design,it detects voltage and battery percent
-Integration and high efficiency optical lens
-Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish
-Standard 1/4 inch Tripod mount
-Waterproof in accordance with IPX7
-Tail stand capability
Note:
Do not reverse setting the battery to protect the flashlight.
Do not open the head to check anything to protected the driver and leds.
Please use unprotected button top or flat top 18650 battery,with button top will have better performance.
Please be careful when install or take down the battery from the battery holder,it will be easy to break down the pill
