I really wanted to order this and the D4 around the same time and not wait ages. So I don’t mind waiting I have more important things to pay first. (probably buy some tools for work)
Only 4 lights I am buying this year those 2 and the K70 and the astrolux thrower. I don’t have the spare cash
I have bought heaps of parts this year I like moding and building. I am also building a light bar.
I’m certain many knew that a small number of prototype is not the same as production. But honestly, what could have been done about it? In an ideal world, a slow ramp of production would have been great (ie. a batch of 50, then 200-300, then all others). But there would have been even more “I want my Q8 now” grumbling and perhaps the manufacturer would not have wanted to go along with it (delaying revenue for sunk development cost, higher per unit cost for small batches). There’s always a cost to quality and it looks like this project hit a fairly good balance.
If the improvements promised come good, I will be very happy. I’d even have been content with the first batch problems, having participated in a few BLF special adventures, and had to fix them up myself. Really, I think that things are a bit out of proportion here, and thank you early adopters for flushing out the first batch minor issues. I hope you are taken care of once the hoo-ha has died down, and we are generally pleased with what still seems to me to be a very fine product, at an unbeatable BLF price.
$40, £30 is I think a bargain however you look at it. I’ve spent 2/3 that on SRK clones with counterfeit emitters, crappy drivers, little modding potential, rough metalwork etc.
I can’t see that price happening again, codes or otherwise, for some time, but what do I know ?
2 of mine came in. Nice build on these lights but some things needed attention first thing. I expected some black gunk to be on the ring inside near the circuit board, and wasn’t disappointed. It appears that when these lights are tested the cells they use are dirty. A “pink pearl” pencil eraser removed the black deposit without much trouble. I had to blow out the eraser dust.
One of the complaints folks have had are buggered up screws. Mine had possibly a little of that but not enough to mention. I did need to put some grease on the o-rings and threads, there was some on the threads, but the o-rings were dry. The cheat sheet fit right into the end cap slicker than snot. Another complaint heard is that the switch LEDs are of unequal brightness. Both of mine appear to be of the same brightness or close enough; I didn’t need a lit switch anyway, but it’s a nice touch. Thanks for including it Thorfire! So far in the Q8 I’ve only used the UI functions available in the Emisar D4 and it’s Narsil Lite UI. Later tonight I’ll play with it more. Physically it’s longer than the Meteor M43 with a diameter roughly the same but that too was expected since this light has reflectors and the M43 doesn’t.
Some folks complain that the flats on the battery section don’t line up with the milled sections on the head. Mine don’t either. Big deal.
I kept it on turbo and sure enough in 3 minutes it stepped down. I might change that to temp’ control just in case I need turbo for longer and it’s –20°. In those 3 minutes the head got decidedly uncomfortable to hold. I’m thinking temp’ control or no control (ones own hand being the temp’ control) is the way to go.
I probably knew it, but had forgotten… It has no hole for a lanyard, but it does have a threaded hole in 1/4-20, so it will accept a d-ring or some such, or go onto a tripod. I haven’t decided yet, but I may drill and tap a hole in the endcap for a lanyard ring. Dang! I forgot! I bought a camera hanging dingus that goes on a belt to hold the light. I just tried it without the belt and it’ll work fine for using it for nighttime chores. It just needs a bit of blue loctite on the threads, and a belt.
The smoke grenade pouches work great and if anything are just a hair snug, but that means they will pull out and not fall out.
I’ll keep cells in both of these for a few days to make sure the switch LEDs are “burnt in” and working.
These are very nice lights! Quite a light for being a “budget light”! I have yet to be disappointed with any BLF light.
My hat is tipped to the team! Kudus! You folks did a great job and produced a fine light! But again, I have not been disappointed with any BLF light that I’ve purchased. It’s definitely worth more than what I paid for it. It was also interesting to watch the process an idea to completion and now I have them on my desk. It can’t get dark soon enough
It hasn’t been that long ago (back when Americans made stuff) that we just blamed assembly problems on “Friday afternoons” or “Monday morning hangovers” of failing Union negotiations. I don’t think I ever heard anybody blaming it on American workers trying to get a product out the door too quickly.
Like BrianK, mine came to Maine today via FedEx SnailPost. Wow, sure took a long time to cross the country! Unbelievably slow.
Worth the wait, of course. All seems in order. drilled out the driver screw holes, chamfered the shelf tapped holes, cleaned the brass contact surfaces at the head and, excellent! Tail spring bypasses are next.
Great job Q8 team and, especially, The Miller, for putting up with us all for so long over this. Thank you! Waiting for nightfall….
Clearly you have forgotten the Project Vanguard so bad in the end the Dwight D. Eisenhower had to swallow his pride and let the Ex German run with the ball.
Though with projects like that blame are rarely assigned when things go wrong.
FWIW, meanwhile in Finland: My Q8 by BG “Free Shipping”/singpost is ready for pickup and tracking shows it arrived at my local post office this Tuesday morning. Unfortunately I’m out of town for several days, so I can’t say anything about the product yet. :weary:
I tried and failed. Some had fractures that were not visible and kinda broke when looked at. They will still work for many purposes, just need a little more time during construction and don’t look as pretty.
Probably alot easier sitting back in your armchair, analyzing. The folks here have a regular life beyond this forum. They designed a light, found a Chinese manufacturer to work with them. Built a light worth three times what was paid. I think the team, and Thorfire did a great job on this. Other than a few led issues, every light works as designed. There have been 500 shipped, and unfortunately, the ones you hear about are the few with issues.
From a USA, manufacturing standpoint. If you think they had a dedicated team to produce only this light, your wrong. Who knows how many orders, or how many different orders, they produce in a day. I can guarantee, an assembly team is going to make errors. From what I understand, and by visual of my light. Every light was checked. An led that was brighter than the other on a QC check, probably wouldn’t be noticed, except by a Flashaholic. The flickering, and led dying is an issue, but probably wasn’t detected in the initial check. The other issues with dust, and adhesive are trivial. A screw that might have been damaged, but was secure, probably would have passed.
I actually feel bad for TheMiller, and every one else involved with this, including Thorfire. This is such an awesome light, and basically, the last ten pages, are folks that want to nitpick it to death.
Unfortunately, they have to deal with this. I think everyone involved has stepped up, and I expect Thorfire will make it right (they always have for me).
EDIT: Ok, it took me so long to write that, their have been a few more positive posts. :+1:
