Q8 modding
I got it on the list to save off the current level setting, and detect short power glitches, then restore the output level. Do-able, just not sure how it would perform, timing wise, if it would recover from these type of hits, etc. This came up near the end and didn't have time to develop, test, get it in. Really wondering now if the stiff springs MtnE sells would prevent it. Problem is though if you have springs stiff enough to work with 30Q BT's, it's probably gonna be too tight for full size protected cells. Actually I didn't try protected cells with the stock springs - may work much better, not sure.
Can you elaborate?
Actually, most clicky switch drivers use power interruption to change state and they do ‘remember’ their state during the time they are off the battery - even long enough for a long press. Banging the light would be a very short event. And many of those can handle LVP nonetheless.
I can’t prove it, but given the way the light behaves when bumped this way, I think the processor does not lose power. Consider that when power is first applied, the light blinks twice to indicate this. That is not what I see happening. I think that the code is still running and polling the switch input. It perceives a very short term drop in voltage on that pin, checks what it is supposed to do in the case of a single click and turns itself off.
There is no intrinsic difficulty in holding up the MCU during very short term power glitches, it’s just a matter of circuit design and bulk decoupling.
It’s something not necessarily done with clicky tail switches (where the driver is looking for power interruptions to change modes), but for an e-switch it shouldn’t be too difficult.
I’ll be taking a look myself, not knowing the detailed design or layout it might be as simple as adding a big bulk decoupler across the MCU, or not.
In my SRK clones its a big problem to fix (I have considered it) because the LED power is also on the same rail/PCB trace as the MCU, so the tens of amps possibly taken by the LEDs exhaust any simple add-on decoupler/holdup cap. instantly. I’d have to cut traces and add a couple of things to improve it. But if the MCU is isolated from the main power by e.g. reverse protection diode, maybe it isn’t too difficult to fix, depending on how the driver PCB is laid out. Shared trace with the LED + supply would be a bummer. I’ll take a detailed look once I have mine, because it really is an issue for me.
I have no idea how this works but what you describe as a fake single click seems to make sense indeed.
If so, maybe that could be filtered out in firmware, or the e-swtich powered from the same isolated well-decoupled rail as the MCU.
I’m anticipating that when the batteries lose contact with a bump, they will then bounce around a bit, predictable if you know mass of batteries and spring constant. Just as most mechanical switches and relay contacts “bounce”, once you look closely at them.
Edit: if one of the four cells was replaced with a very lightweight part, with a big capacitor inside (maybe supercap), that might be much more resistant to losing contact, even when the main cells do. If it had a small spring on the + end too, even better.
if you are concerned about power loss when the light get hits you can increase C2 to compensate
Bistro HD OTSM does that to detect long presses of the tailswitch with a 47uF capacitor
Might not be so simple if, as suggested MCU is indeed holding up, but false switch presses are being triggered by transients. Glad this little issue, which is important to me, is attracting attention, but will wait until I have my torch before jumping to conclusions.
Edit: PS Lexel, how do your drivers behave in this scenario ? Like the look of your dual 7135 bank ones.
So much good information here.
Thanks everyone!
from the MCU and its parts for powering the MCU its identical, just one more output channel and a better FET
@Tom,
what solder do you use for the springs? The stuff for electronics, multicore with 0.5mm OD with 4 percent silver?
Sn60PbAg = 60 Sn, 36 Pb, 4 Ag 180
I use Kester SN63PB37 #66/44 1.0MM ("44" rosin core), 1 LB spool that been lasting for couple years now, lot more to go. I work with a very senior super tech, who I think is the one recommending this. Right now I'm use no clean solder flux in a pen, but prefer using the better stuff, Kester #186 RMA, but hard to find and seems quite expensive now.
This is one listing for it: http://www.ebay.com/itm/Kester-186-Soldering-Flux-Pen-/122702524233?hash=item1c91a3ef49:g:1PwAAOSwBp5ZuESC
"No Clean" is actually harder to clean up.
Cheaper here: http://www.ebay.com/itm/Kester-Rosin-Flux-PEN-186-good-for-Solar-cells-Panels-/140359491548?hash=item20ae13dfdc:g:3OYAAOSwyZ5Un0xr
Wow, can’t believe the mod thread is up to 20 pages already. By the time I get my Q8, it will be double this. Has anyone swapped out the emitters yet…sorry…I’m not about to read through 20 pages to find out :slight_smile:
Re: springs I’m considering using be-cu springs left from my Chimera build as inner springs with outer coated steel springs and punched copper buttons to lock the ends together. The be-cu spring would provide a low resistance path while the outer coated spring would improve compression resistance. I considered using the be-cu springs alone then did a tail impact test of the Chimera and found that after a moderate impact it went off then turbo (lexel 2s tactical dual switch srk driver). The be-cu and steel pair would essentially be using a be-cu spring as the bypass for the steel spring.
Makes sense. The bumping worries me just a bit, as I’d been thinking the Q8 will make one heck of a bike light.
It would take a heck of a bump to disconnect all 4 batteries. With spring bypasses the wire makes the springs a tad bit stiffer so I don’t know if I can even get my Q8 to disconnect if I tried. Sanding down the battery tube also shaved off a fraction of a mm to make things more snug as well. Thinking of taking the tube down just a bit more to line up the flat spots, but I will wait for my screws to come in so I know the driver is sitting flat.
The ti-cu springs in my Chimera are 1mm, no bypass. An impact from about 1 ft to impact with the palm of my hand caused stated change. I suspect the method I suggested might prove to be better than a wire or wick bypass.
Findings with my Q8 lights:
- it’s a disconnect and not a spike or fake key press, easy to recognize: it flashes 2x as it does when powering on,
- disconnects occur with and without spring bypasses,
- disconnects occur with long protected cells and with short ones, but even on weak bumps with short cells.
Proposal to avoid power off on bumps
An additional 100 uF ceramic cap over C2 appears to be sufficient in my light. No power hickup on hardest bumps, even scratched the tailcap during tests.
bumps on the tail end will disconnect cells easier then on the side.
still, or a bike lght I would go with something with spring on both ends of the cell
