Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
Did I read the headline correctly... Productions is up and running again?
Yep! That’s just a few post up the page:
So when Banggood said ” “Expect ship in:Sep.26,2017 – Oct.08,2017” for my last order they weren’t joking :slight_smile:
I am impressed, from stopping the line (what date was that ?) Recognising and investigating the issues, re-designing and manufacturing new switch PCBs including procuring new components, maybe sourcing some new fasteners, reviewing assembly procedures, building the next batch of 500 and getting them over to Banggood to despatch, took how many days ?
yes that old very well be true tomtom
the holiday coming sure pushed things along fast!
yeah sorry, I figured the topic title change would answer your PM :smiley:
This is very good news.
When will BG start sending out these flashlights?
Thank you
Nobody knows.
If the next 500 lights are ready they will probably start shipping today or in the next days, but that’s just a guess.
We’ll know when people start to report shipping notice emails from BG.
However, there is a big holiday coming in China, so even if it’s shipped, it may well stay put for a while as most of the country will be off work.
I hope I will get a notice from BG :smiley:
Thanks for calming my frazzled nerves d:
Hoping at least one of mine will be in the next 500 (first was ordered Sept 12, strategic choice not to be in first batch)
After that perhaps there will be a pause before the next 700+ go out. If so, not the least bit bothered. Good things come to those who wait.
On Sept 12 there was already more then 1300 preorders… Yours is likely to be out of the second 500 batch. :frowning:
Not too worried about the upcoming holidays, rather have it screwed together later than mangled sooner :wink:
Keep up the good work Q8 team :+1:
W o w…… 1300 on the 12th!! Good deal for the GB.
Looks lIke my last ones will be a while then.
Oh well, as has been said; no rush. :wink:
Not when I ordered (I’m at least 5 hours ahead of you Yanks, we run on GMT+1 at the moment), and get up very early. I think it was sitting on about 800 when I hit the go button, that was my strategy. But maybe I mis-remember. In any case, not bothered.
Edit: my order date of Sept 12 was China time which is 7 hours ahead of UK time (checked PayPal receipt) So I ordered on the 11th, depending how you look at things. (the only true time is at the Greenwich Meridian, despite what everyone else would like to think, or try to re-name it UTC etc.) Thought my brain wasn’t ready to give up just yet.
To have a little bit better statisticts: My Q8 arrived today with the expedited shipping service.
Leds in the Button: 100% ok and even
Screws at the PCB: Not stripped
Screws at the Tailcap: One slightly stripped, all 3 others A-OK.
Emitters centered, flawless reflector
No kinks or damage to the Frame
Only the brass ring at the plus pole was a little bit dirty.
I got mine 2 days ago.
So far I have not found any problems. :slight_smile:
I would be grateful if I could buy one more.
Maybe MadMax or Elfeland is the quickest way, for now.
So I noticed a post by TA Tom E that someone had 135uA through the switch LED and it didn't work, then lowered the resistance and had 155uA and then it did work.
I don't think that's a Vf issue and I never felt Vf variability would cause this, although it depends how close the diode Vf is to the supply voltage. It could cause mismatch in the LED's when driven through a single resistor but it shouldn't cause them to quit entirely, and 155uA to 135uA probably shouldn't either. That looks like some kind of leakage current problem, like 135uA isn't real functional diode current, thus it not making light. Is it normal for an LED to have a minimum turn-on current?
BLF Q8 Group buy sale statistics, Using UTC+2 time.
Date -> Preorders
7. Sept 02.00 GB Started
7. Sept 20:40 -> 500
7. Sept 23:50 -> 742
8. Sept 04:35 -> 931
8. Sept 07:47 -> 993
8. Sept 10:24 -> 1024 — Yes exactly at that time, I double checked!
8. Sept 21:42 -> 1106
9. Sept 03:58 -> 1143
9. Sept 22:20 -> 1202
10. Sept 0428 -> 1212
11. Sept 22:32 -> 1320
12. Sept 22:11 -> 1359
13. Sept 20:45 -> 1389
14. Sept 2042 -> 1422
15. Sept 20:20 -> 1458
16. Sept 10:00 -> 1493
16. Sept 19:40 -> 1523
25. Sept 05:42 -> 1671
26. Sept 12:32 -> 1706
26. Sept 19:59 -> 1726
27. Sept 10:57 -> 1764
27. Sept 16:40 -> 1775
The total parasitic drain for the Q8 is 135uA. The LEDs drain 113uA and the driver drains 22uA.
Amplificus swapped the 15K switch resistor to a 10K resistor and that made his switch lights start working again. Then he measured his parasitic drain again and got a total of 155uA.
