I just noticed in the OP photos that the head unscrews, but mine will not budge. Is there a trick to unscrew it or do I just need to eat some more spinach and try again?
it does unscrew—may be locktited in or something
doubt it
just use more juice
it;s kind of hard to grab, thin on the edge
use a rubber jar opener pad thingy
wle
I wasn’t aware or I forgot… So, what’s the cut-off voltage?
is possible to use for this flashlight unprotected cells?thanks
Yes.
question-is possible to open this flashlight?the output is too low for me.want change driver.but which side switch driver which gives 6 amps as the fet driver could fit for this flashlight?anyone tried it already?
There is no space for that because DQG uses a single PCB with both driver and LED.
However, I’ve seen 2 ways of finding the space:
- use a smaller reflector, which doesn’t fill the head fully
- use a Carclo triple optic
I’ve seen Ledil Satu triple considered too, but haven’t seen anyone actually using it
Have a look at this thread DQG Tiny 18650 + Narsil + Nichia 319 = Ultimate Compact EDC
Also a conversion to triple with optic is possible, unfortunately the pictures are gone Modding the DQG 18650 Tiny III into a triple
yes i see…pics are dissapeard
the nichia mod-is it much more powerfull than the stock?…….
There were 2 triple builds on this forum (one with Tiny 4th and one 3rd) and at least one on fonarevka. So you may be able to find the pics.
yes i see it already….but….thats too much for me……sadly.hard to open,hard to change…….its a pitty.so nice flashlight.but not enough bright
Is there an 18350 tube that would work with DQG Tiny 4th?
No, it would have to be a totally new body, there isn;t a tube per se.
it;s just a cap and a main tube, there is no middle section to be shorter
wle
What do you mean there is no middle section?…
oh
well there it is!
mis remembered
i guess you could make a short tube but i have never heard of one for sale
wle
Right, I was just wondering if maybe a shorty tube from some other light would work…
The Nichia 319 mod was for better Tint/CRI, better UI, and higher efficiency,
not for higher output.
The XML2 in the stock light gets very hot while the body of the light remains fairly cool.
If you modify it with a proper PCB and heat transfer for the LED, you will quickly realise that it can only dissipate approx 10W heat maximum
(which is what an XML2 or XPL or Nichia 319 etc will generate at 3A).
Any more power than that and you are just going to burn your hand faster.
Tailstanding indoors with no airflow, mine gets hot and thermal throttles on high after a minute or so.
If you want a nice compact EDC light with good runtime and decent output for most common tasks, modify this light if you want, but keep the max level under ~10W.
If you want any more light than that for any extended period of time, get another, larger light with more surface area to dissipate heat.
Was the switch improved on new ones ?
what do you mean by ‘new ones’?
i had one from dec 2016 that i complained bitterly about, due to the terrible switch, design, and or manufacturing that made it come loose
wle
wle
I see a gear best deal today . Do you think the ones being shipped today have improved ? Will epoxy help ?
