Agro
(Agro)
September 28, 2017, 8:00am
93
There is no space for that because DQG uses a single PCB with both driver and LED.
However, I’ve seen 2 ways of finding the space:
use a smaller reflector, which doesn’t fill the head fully
use a Carclo triple optic
I’ve seen Ledil Satu triple considered too, but haven’t seen anyone actually using it
finges
(finges)
September 28, 2017, 8:27am
94
Have a look at this thread DQG Tiny 18650 + Narsil + Nichia 319 = Ultimate Compact EDC
Also a conversion to triple with optic is possible, unfortunately the pictures are gone Modding the DQG 18650 Tiny III into a triple
yes i see…pics are dissapeard
the nichia mod-is it much more powerfull than the stock?…….
Agro
(Agro)
September 28, 2017, 8:58am
96
There were 2 triple builds on this forum (one with Tiny 4th and one 3rd) and at least one on fonarevka. So you may be able to find the pics.
yes i see it already….but….thats too much for me……sadly.hard to open,hard to change…….its a pitty.so nice flashlight.but not enough bright
Pete7874
(Pete7874)
September 29, 2017, 1:28pm
98
Is there an 18350 tube that would work with DQG Tiny 4th?
wle
(wle)
September 29, 2017, 8:04pm
99
No, it would have to be a totally new body, there isn;t a tube per se.
it;s just a cap and a main tube, there is no middle section to be shorter
wle
Pete7874
(Pete7874)
September 29, 2017, 8:55pm
100
What do you mean there is no middle section?…
wle
(wle)
September 29, 2017, 9:03pm
101
oh
well there it is!
mis remembered
i guess you could make a short tube but i have never heard of one for sale
wle
Pete7874
(Pete7874)
September 29, 2017, 9:05pm
102
Right, I was just wondering if maybe a shorty tube from some other light would work…
agnelucio
(agnelucio)
September 29, 2017, 9:21pm
103
The Nichia 319 mod was for better Tint/CRI, better UI, and higher efficiency,
not for higher output.
The XML2 in the stock light gets very hot while the body of the light remains fairly cool.
If you modify it with a proper PCB and heat transfer for the LED, you will quickly realise that it can only dissipate approx 10W heat maximum
(which is what an XML2 or XPL or Nichia 319 etc will generate at 3A).
Any more power than that and you are just going to burn your hand faster.
Tailstanding indoors with no airflow, mine gets hot and thermal throttles on high after a minute or so.
If you want a nice compact EDC light with good runtime and decent output for most common tasks, modify this light if you want, but keep the max level under ~10W.
If you want any more light than that for any extended period of time, get another, larger light with more surface area to dissipate heat.
pennzy
(pennzy)
January 3, 2018, 3:43pm
104
Was the switch improved on new ones ?
wle
(wle)
January 3, 2018, 3:51pm
105
what do you mean by ‘new ones’?
i had one from dec 2016 that i complained bitterly about, due to the terrible switch, design, and or manufacturing that made it come loose
wle
pennzy
(pennzy)
January 3, 2018, 4:00pm
106
wle:
wle
I see a gear best deal today . Do you think the ones being shipped today have improved ? Will epoxy help ?
wle
(wle)
January 3, 2018, 4:11pm
107
epoxy might help make it stronger against the pushing, not sure if it would have thermal implications, or if it would permanently fix it.
i would guess the current ones, still calling themselves “IV”, are the same.
theoretically you could write to the head of the company and ask, but i never had much luck with that.
if there are new versions, he may not know what gearbest is selling currently.
wle
wle
(wle)
January 3, 2018, 4:17pm
108
also i don’t see any deal - they have been as low as $13.99 recently
pennzy
(pennzy)
January 3, 2018, 4:25pm
109
I did not know that . I’ll wait for better deal . Thanks .
fedcas
(fedcas)
June 12, 2018, 1:54am
111
WOOOT?? Any deal around? I’ve seen there’s a code for 26 USD at m4dm4x’s… do deals at 20 usd or under happened recently?
Also, the 4th version it’s been produced for a long time, any news about maybe a new version in the air?
exactly the information that I was looking for in this thread… with the new 18350 cells around, such this light screams for a short tube of some kind…
