Review: Energizer Vision HD 2xAA Flashlight
14 posts / 0 new
rookiedaddy
rookiedaddy's picture
Last seen: 1 day 18 hours ago
Bought this from Harvey Norman store. With today's conversion rate, that's USD 16.29, a pretty good deal I would say, considering elsewhere these are going slightly higher. This is 2016 version though, as Energizer has updated the 2017 version from 300 to 400 lumens.
what prompted the spending was this...
everything else was blurred (like in the picture) until I parted my money... yea... you know that moment that things started to come clear one after another?
as usual, light is made in China while batteries in Singapore... and if you wanna check out the data sheet, the model number is PMHH21. Actually, Energizer's model number is anything but helpful especially when they updated the model... there is no revision number nor letter to indicate it's a different version or different make. Good luck figuring out the original specifications after a few years. and see below for the model number printed at the tailcap...
ok now, the main reason for this review...
do you see that beautiful Energizer's Daylight tint?! Yup! That's a beautiful neutral white tint! In fact, this isn't the first Energizer light that feature such a nice neutral white tint, approximately 2 months ago I bought an Energizer Hardcase PivotPlus 2xAA flashlight that features similar tint and I absolutely love it!
The only downside to this Vision HD 2xAA is the low mode that features really low frequency PWM. Even the slow strobe that's hidden (you need to press and hold for 2 seconds when flashlight is ON to activate the strobe) I consider as OK-design!
The UI is very simple mode cycling using the electronic switch: OFF > Click once to High Mode (300 lumens) > Click once to Low mode (85 lumens) > Click once to OFF. Again, strobe is hidden and can be activated by turning on the flashlight and press and hold the switch for 2 seconds. To turn off the strobe, click once and the light will be switch off.
Let's take a look at a few more pictures of the light...
the e-switch is quite small
the body knurling pattern looks smooth at first, but it does provide good grip in use. tailcap is smooth but I have no issue unscrewing the tailcap at all (in contrast to those comments from Amazon).
The positive contact point at the head... it's spring loaded although it doesn't appear at first. I had a surprised when first inserted the battery.
No spring contact at the tailcap, just a slightly raise washer type button to make the battery negative contact.
The tailcap threads and the O-ring comes pre-lube, no excessive amount of grease like other manufacturers, but just a nice lube around the thread and the O-ring.
The second AA battery is exposed and only cover upon screwing the tailcap back to the body.
This flashlight's wall is thick! and if you are into modding, you could shorten and enlarge the tube to fit single 18650 size and I don't think it will compromise the body integrity.
A bit of rattling when shaking the flashlight, but easily fix with a piece of rolled paper around the batteries.
and finally, the business end of the flashlight...
first time seeing this type of optics, 2 TIR + 1 diffused optics, weird but somehow it works! The beam profile is actually a good balance of throw and flood.
bykfixer coined a phrase: "even a bad flashlight aint bad these days", although I don't think this is a bad flashlight, but a consumer grade flashlight it is (probably budget range too), and bykfixer's phrase is equally relevant here especially given big name consumer product producer catches on with phrase like "DELIVERS A WIDE, POWERFUL BEAM TO IMPROVE HIGH-DEFINITION VISION"!
I guess Energizer may be on to something here... and we probably need to re-term High CRI flashlight to Full High Definition (Full-HD) like in Flat-screen TV to gain market traction... laughing
still changing sig ::
Edited by: sb56637 on 09/02/2017 - 11:48
jch10400
Last seen: 3 weeks 5 days ago
Thanks for the review. This is the kind of flashlight I would have bought before finding BLF. I looked up the price on US Amazon ($19.99 versus approximately $19 for a BLF A6 in the recent banggood sale) and noticed that the Amazon details say the newer 400 lumen light has “One-press digital focus effortlessly transitions from a full spot light to a full flood light”
stephenk
stephenk's picture
Last seen: 45 min 15 sec ago
Thanks for the review. I think some Energizer lights are quite underrated.
Lightbringer
Lightbringer's picture
Last seen: 12 min 28 sec ago
Wow, I’m actually kinda impressed. Big Smile
Wonder what little beasties are under the TIRs. XP-G?
rookiedaddy
thanks for the kind words guys...
jch10400 wrote:
...Amazon details say the newer 400 lumen light has "One-press digital focus effortlessly transitions from a full spot light to a full flood light"
thanks for the heads-up, I was intrigued by those wording too, after googling around, I'm guessing the newer model could be referring to the same digital focusing control system that they used in the Vision HD + Digital Focus headlight where they control the focus by ramping the brightness up and down alternating between the 2xTIR and 1xDiffused optics. You can search in youtube for how that digital focus system works in their headlight.
stephenk wrote:
...I think some Energizer lights are quite underrated.
I agree wholeheartedly.
sorry mate, can't tell without removing the optics... Silly
rookiedaddy
bought a new 6AA 1300 lumens version...
comparison to 2AA...
this is a newer version (not talking about brightness nor number of batteries) as Energizer has put something called "digital focus" in the control circuit. It alternate between the lone flood optics and 2 TIR optics by holding down the switch when the light is on, as a result, you can somewhat have "variable brightness" while the light is alternating between the optics. An interesting idea indeed. Kudos to Energizer for creativity!
Cliffdenyer
Cliffdenyer's picture
Had two of these, both stop being able to do high mode after the batteries have been used for like half hour – one hour. And theres a loud is humming noise on low mode, then after the batterie is used for for 1-2 hours it stops turning on at all. My dad and I both had one and they both did this, they sent us two replacements and they did the same.
Shame well made torch but terrible driver that cuts out far to early on used batteries…
#228
Cliffdenyer
Going to use one as a host as the shell and pill are good
#228
Cliffdenyer
#228
Cliffdenyer
The hardcase one has the same modes and brightness but it’s 100% reliable in like the 2aa vision pro. Still nothing tops there 6 as double barrel from the early 90s, as you might have guessed I’m a bit of an enetgizer collecter
#228
Vsmh96
Last seen: 1 year 1 month ago
Hi there, out of curiosity, is your “PMHH21” still working?
If yes, does it suffer from the following?
1. Random shut downs
2. Flickering when held in a specific position
3. At times, does not respond to the “on” button
I ask the above as I have 3 of the PMZH21’ (400 lumens) and have the same slanted positive terminals as shown in your picture above.
The Panasonic batteries per the picture is quite a battery, it is like steroids back in the day as it burned out many of my torchlights, granted they did make the incandescent bulbs shine brighter, any issues with the use of the Panasonic’ so far?
Hope to hear from you soon.
Thank you and warm regards.
Vsmh96
I’m not sure if the newer version does the same but it does get warm and a sign of low battery would be when strobe mode only flashes once and power is cut or no longer able to continuously flash.
Vsmh96
This is an absolute monster.
Does your tail cap “grind” the negative side of the batteries and even in some cases cut them?
rookiedaddy
Vsmh96 wrote:
Hi there, out of curiosity, is your “PMHH21” still working? If yes, does it suffer from the following? 1. Random shut downs 2. Flickering when held in a specific position 3. At times, does not respond to the “on” button I ask the above as I have 3 of the PMZH21’ (400 lumens) and have the same slanted positive terminals as shown in your picture above. The Panasonic batteries per the picture is quite a battery, it is like steroids back in the day as it burned out many of my torchlights, granted they did make the incandescent bulbs shine brighter, any issues with the use of the Panasonic’ so far? Hope to hear from you soon. Thank you and warm regards.
Vsmh96 wrote:
This is an absolute monster. Does your tail cap “grind” the negative side of the batteries and even in some cases cut them?
So sorry for late reply…
1. Nope. No random shut down on mine.
2. No flickering either except when battery is really low in juice. That’s when the low frequency PWM kicks-in… very annoying…
3. Yes, I did experienced it but only on the 400 lumens version that it does not respond to the ON click in rare occasion, I can’t reliably simulate it. It happens very intermittently…
4. No issues with the Panasonic batteries, I’ve exhaust 5 sets of them in the 300 lumens version and 3 sets in the 400 lumens.
5. The tailcap does grind the negative side of the batteries, but it doesn’t “cut” them. This is the main reason I don’t use NiMH rechargeable in these lights.
