I had “Curious cases of Benjamin Button” recently with newest batch of noctigons. Symptoms were that after re flowing everything was tested and works flawlessly(mode selection and everything) and when you assemble it to flashlight I got High mode only :smiling_imp:
So atiny is trying to change modes(i can hear high pitch noise) but high mode still remains…
That happened around 5 times out of 50 emitters so I guess it could be that what Mitko mentioned.
I did not try yet but I think electrical insulating thermal glue like AA or Fujik(if it really must be used) can resolve this issues if they ever happen to you.
Indeed, sometimes you wont be having a short connection but just a modes lost( it stucks on high), or like on some of my drivers offtime memory function disabled
I’ve had a similar result when there is power bleeding off to ground to led negative on the driver board. High mode always.
If there is a short of some kind in the MCPCB the best solution would be to just dump the mcpcb and use another one. Trying to prevent a short with thermal epoxy would likely result in having to use a layer so thick it would negatively effect the thermal path.
Wow that is great, thank you!
I particularly appreciate the intentionally casual technique, and lack of precision shown, to highlight the effect of surface tension with the wetted solder.
Very illuminating video, I had no idea that the leds could tolerate that duration of time at the solder’s melting point, or that thermal shock was the greater issue. I would have hurried it and had poor joints and raised, heat shocked emitters if I’d tried it on my own experimentally.
This is something that I’ve been putting off learning to do, I’m now quite inspired.
Thanks again.
