DQG Tiny 4th 18650 xml-2 review
Have a look at this thread DQG Tiny 18650 + Narsil + Nichia 319 = Ultimate Compact EDC
Also a conversion to triple with optic is possible, unfortunately the pictures are gone Modding the DQG 18650 Tiny III into a triple
yes i see…pics are dissapeard
the nichia mod-is it much more powerfull than the stock?…….
There were 2 triple builds on this forum (one with Tiny 4th and one 3rd) and at least one on fonarevka. So you may be able to find the pics.
yes i see it already….but….thats too much for me……sadly.hard to open,hard to change…….its a pitty.so nice flashlight.but not enough bright
Is there an 18350 tube that would work with DQG Tiny 4th?
No, it would have to be a totally new body, there isn;t a tube per se.
it;s just a cap and a main tube, there is no middle section to be shorter
wle
What do you mean there is no middle section?…
oh
well there it is!
:slight_smile:
mis remembered
i guess you could make a short tube but i have never heard of one for sale
wle
Right, I was just wondering if maybe a shorty tube from some other light would work…
The Nichia 319 mod was for better Tint/CRI, better UI, and higher efficiency,
not for higher output.
The XML2 in the stock light gets very hot while the body of the light remains fairly cool.
If you modify it with a proper PCB and heat transfer for the LED, you will quickly realise that it can only dissipate approx 10W heat maximum
(which is what an XML2 or XPL or Nichia 319 etc will generate at 3A).
Any more power than that and you are just going to burn your hand faster.
Tailstanding indoors with no airflow, mine gets hot and thermal throttles on high after a minute or so.
If you want a nice compact EDC light with good runtime and decent output for most common tasks, modify this light if you want, but keep the max level under ~10W.
If you want any more light than that for any extended period of time, get another, larger light with more surface area to dissipate heat.
Was the switch improved on new ones ?
what do you mean by ‘new ones’?
i had one from dec 2016 that i complained bitterly about, due to the terrible switch, design, and or manufacturing that made it come loose
wle
I see a gear best deal today . Do you think the ones being shipped today have improved ? Will epoxy help ?
epoxy might help make it stronger against the pushing, not sure if it would have thermal implications, or if it would permanently fix it.
i would guess the current ones, still calling themselves “IV”, are the same.
theoretically you could write to the head of the company and ask, but i never had much luck with that.
if there are new versions, he may not know what gearbest is selling currently.
wle
also i don’t see any deal - they have been as low as $13.99 recently
I did not know that . I’ll wait for better deal . Thanks .
2.8V in my test.
WOOOT?? Any deal around? I’ve seen there’s a code for 26 USD at m4dm4x’s… do deals at 20 usd or under happened recently?
Also, the 4th version it’s been produced for a long time, any news about maybe a new version in the air?
exactly the information that I was looking for in this thread… with the new 18350 cells around, such this light screams for a short tube of some kind…
no luck I guess? :frowning:
I wonder how can I improve performance of my Tiny.
I like the beam profile, wouldn’t want to make it much floodier. Or much throwier either.
Turning it to a triple (f.w. triple Oslon Black) is far beyond my skills.
Swap LED?
The LED included is quite good, I don’t see any stock emitter that would be 3V, significantly more efficient and not floodier.
Dedomed Samsung LH351D might be an improvement, but a small one and I feel it’s not worth the effort….
Res-modding?
I’m not sure even minor current increase is a good idea without improving thermal path.
But maybe……should enable more improvement than LED swap…
Improving thermal path?
Dunno, maybe potting with Arctic Alumina and attaching a copper plate on top of the light engine would enable me to spread some heat outwards?…
Painting interior with white heater paint?
There is GITD strap inside and it clearly glows. Which is an evidence that there’s stray light hitting flashlight walls. Painting white would put some of this light in the spill…Has anyone painted the interior of a TIR light with white paint and reported the result?
