Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
17431 posts / 0 new
teacher
teacher's picture
Last seen: 8 months 13 hours ago
nvanlaar wrote:
I’m not sure what this means, but they are moving around… maybe.
Pretty sure the next stop for yours will be Hong Kong. Yours, like mine; do appear to be moving. Thumbs Up
hank
hank's picture
Last seen: 11 hours 12 min ago
> conductive grease
Hm. Opinions vary.
That guy says nope.
Quote:
Using aluminum and copper blocks with various surface conditions, I’ve been unable to verify any connection improvement from specialized conductive greases.
and he has this warning:
Quote:
Silicone greases can be converted by arcs to silicone carbide, which is highly abrasive. For this reason, silicone grease should be avoided when contacts are “hot switched” and have any chance of arcing.
Now those attentive to spelling may remark that ‘silicon carbide’ is a well known abrasive, whereas ‘silicone carbide’ would be something else again, if indeed it’s a thing at all.
Google suggests it’s not a thing. But what do they know?
Tom E
Tom E's picture
Last seen: 15 min 16 sec ago
Tally-ho wrote:
I don't see a pause after moonlight mode when turning on the light with a press & hold. For me it seems that it immediately starts ramping up and I need to ramp down to have the lowest output. Is the pause duration at moonlight of the D4 the same as the Q8 ? The moonlight is easy to catch with the D4 while I always miss it with the Q8.
Did you miss my "fast hands" post? smile
Hhhm, good Q. Let me check....
Edit: Ramp mode pause defaults to 0.368 secs in the Q8. Here's the code:
#define RAMP_MOON_PAUSE 23    // this results in a 0.368 sec delay, paused in moon mode
Same value used in the original D4 firmware. Might be the feel of the switch that's different?
Tom E
Tom E's picture
Tally-ho wrote:
I did a factory reset and now both D4 and Q8 are fonctionning the same way with a click & hold from OFF. Before the factory reset, when I was doing a click & hold at the same time on both flashlights, the D4 was turning ON on moonlight almost instantly and after the "moonlight + pause" it was ramping up. The Q8 was turning ON after a longer delay directly to ramp up without "moonlight + pause". I probably disabled the moonlight (but there is no way to do it in the manual) so I probably set it to the lowest level by mistake. It seems that the emitters weren't even emitting light at this lowest moonlight.
I can confirm a setting of moon mode to 1 disabled the LEDs. Not sure if that's expected - they are using a "good" 7135, I bet was hard to find in qty 2,000. Want to check/confirm with other Narsil lights and Q8 protos...
Miguel_79
Last seen: 2 days 2 hours ago
Before the factory reset, when I was doing a click & hold at the same time on both flashlights, the D4 was turning ON on moonlight almost instantly and after the “moonlight + pause” it was ramping up. The Q8 was turning ON after a longer delay directly to ramp up without “moonlight + pause”.
I probably disabled the moonlight (but there is no way to do it in the manual) so I probably set it to the lowest level by mistake. It seems that the emitters weren’t even emitting light at this lowest moonlight.
It happened to me too. And that’s exactly what I point to in bold.
When I selected level 1 for the moonlight mode, exactly the same thing happened to me.
And not only does it change the fact that there is no pause in moonlight mode and that it takes longer to turn on the LEDs. What also happens is that if you release the button before the LEDs turn on, you will have the flashlight turned off with the button light also off. At that time, if you press the button normally, button led will light, another press will turn on the flashlight.
Tom E
Tom E's picture
Yep, all normal stuff unfortunately. Sorry, didn't check the protos yet. Think if we would have spotted that and talked bout it, it would have sunk in I shouldn't even allow a level of 1 to be selected in a Q8 frown.
Tom E
Tom E's picture
Miguel_79 wrote:
Tally-ho wrote:
I did a factory reset and now both D4 and Q8 are fonctionning the same way with a click & hold from OFF. Before the factory reset, when I was doing a click & hold at the same time on both flashlights, the D4 was turning ON on moonlight almost instantly and after the "moonlight + pause" it was ramping up. The Q8 was turning ON after a longer delay directly to ramp up without "moonlight + pause". I probably disabled the moonlight (but there is no way to do it in the manual) so *I probably set it to the lowest level by mistake. It seems that the emitters weren't even emitting light at this lowest moonlight.*
It happened to me too. And that's exactly what I point to in bold. When I selected level 1 for the moonlight mode, exactly the same thing happened to me. And not only does it change the fact that there is no pause in moonlight mode and that it takes longer to turn on the LEDs. What also happens is that if you release the button before the LEDs turn on, you will have the flashlight turned off with the button light also off. At that time, if you press the button normally, button led will light, another press will turn on the flashlight.
Ok, checked & verified on 3 protos and 1 production light. All of them light up the LED's, yes, all of them on moon level 1. How are you guys checking it? In room light or are you goin into a dark place? Very obvious what's goin on in the dark on moon mode level 1. It works, it ain't bright... smile
Flashlights are for the dark. Oh, and is setting 1 useful for anything? No, not really. laughing
fuzun
Last seen: 21 hours 50 min ago
Still waiting at “Back Order”
Order no: 1000-1010 (Maybe 1004) . But who cares, I am not in a rush Smile .
DavidEF
DavidEF's picture
Last seen: 1 day 16 hours ago
teacher wrote:
For those of you in the USA that do want to check Tracking of you Q8, but DO NOT know how… here is the proper procedure.
This procedure is only valid for USA orders that were shipped Priority Air Mail. The FREE Shipping option for this light. (It ‘might’ work for other counties… but I have no idea about this & cannot address that.)
  • 1. Get the Tracking Number of your order either from your Banggood Account or the Shipped email they will send you.
  • 2. Go here https://www.fedex.com/apps/fedextrack/ and enter the Tracking Number from step 1. Click Track. At this point it will probably say LABEL CREATED.
  • 3. Scroll down to SHIPMENT FACTS & get the Reference. This number will most likely begin with YT
  • 4. Then go here http://www.17track.net/en and enter the Reference from step 3. Click Track. Scroll down to see movement.
Once the package actually ships, movement will show in the tracking information on 17Track.
Do not be alarmed if your package sites in one place for 1 to 3 or 4 days, this just happens sometimes. It is just the way it is. Nothing to worry about.
DO NOT worry about what it says on the FEDEX Tracking. It will not show there until Fed Ex actually has the package, if then even.
17Track has been very reliable for these packages sent to the USA… all of mine have been 100%. More accurate then FedEx tracking by far.
While writing this I checked my last 2 Pre-Orders…. both above #1680… AND much to my surprise & shock they both actually show movement. It appears they have actually shipped, as in “left the building shipped”….. Shocked .. Wink
Will know for sure in a couple of day though.
So there it is if anyone likes to see where their package may be……
Enjoy.
Smile
Oh yeah. You guys talked about this before (500 pages back?) but I forgot. I just checked mine this way, and it says that it has departed the facility in Shenzhen! Woo-Hoo! It’s really moving! Party
Meanwhile, Fed-Ex still says “Shipping label has been created. The status will be updated when shipment begins to travel.” Flat Stare
- The YKK Philosophy
Miguel_79
Ok, I just checked it and it they turn on in setting 1, if that can be called turn on ...
I was doing the tests in a room in the dark, but not completely in the dark, so that it was impossible to observe that there was a slight brightness in the LEDs, in fact, with the room completely dark, you almost have to intuit that they are emitting some kind of light.
It is obvious that level 1 of moonlight is useless. I just selected mode 2, and this yes, this is usable. Although I would like it to be part of the ramp, but the ramp I see that only reaches level 3, if you select 2 or 1, they are off the ramp, in any case, not a big inconvenience.
Lazy-R-us
Tom E wrote:
Yep, all normal stuff unfortunately. Sorry, didn’t check the protos yet. Think if we would have spotted that and talked bout it, it would have sunk in I shouldn’t even allow a level of 1 to be selected in a Q8 frown.
I’m glad you did! One of my lights actually does light up in Moonlight PWM=1. It is a ridiculously low moonlight. I have no way to measure, but I am fairly sure it is less bright than the switch indicator. Tests in the bathroom at work laboratory indicate that unless you have dark adapted eyes, it is very hard to even tell if the emitters are ON – short of looking directly at them.
Lazy-R-us
Tom E
Tom E's picture
Yea, it's a definite "feature" innocent
Anyone run a Q8 without the switch boot on? I get this feel'n a little green eyed monster is staring at me.... Okay, only after a 1/2 beer - I can't drink any more, or any less...  Beer
ToyKeeper
ToyKeeper's picture
Last seen: 4 hours 7 min ago
I’ve found that PWM=1 can still be useful with a slower clock speed. I’m getting about 0.2 lm at that level now on my D4, or 0.05 lm on my SRK-Q8-proto.
What I found works reasonably well is to adjust clock speed based on PWM level at the bottom of the ramp:
  • PWM=1, PWM=2: 3.9 kHz
    MCU power = ~1.5 mA
  • PWM=3 to 10: 7.7 kHz
    MCU power = ~2 mA
  • PWM=10+: 15.6 kHz
    MCU power = ~3.5 mA
What I started with was 15.6 kHz always, MCU power = ~5.5 mA. So the underclocking and idle states help quite a bit at the low end, even if it’s meaningless at higher levels.
OTOH, this makes the ramp settings even more hardware-specific, so what looks good on one type of light may appear a little bumpy on another light. Instead of a 2-segment ramp, it acts like a 4-segment ramp… and each segment boundary is an opportunity for a “bump”.
alternety
Last seen: 9 hours 13 min ago
I have not gotten mine yet, but listening to various discussions, I am getting rather nervous about the usability of the Q8. I realize I have a limited primary use for the Q8 (emergency lights rather than an exciting toy) and am on a web site that is the epicenter of modding and cool things flashlight. And I may also be seriously over reacting. I am sure that will be noted in any replies.
I am not sure if I will be able to use it every so often (or never) without having to read the manual. If things go well, my Q8s may never be called upon to emit light. I will touch them only every so often to rotate the batteries. I have a TK75 that lives like that aside of the bed. In an emergency, reading the manual first is not going to happen. I have enough trouble remembering which button controls which lights in the house. I am particularly concerned about the timing sensitivity of button pressing. Some of these things can be seriously confusing to the casual user.
One aspect of an emergency light is that people other then myself may need to use it. I strongly suspect my wife will simply not be able to use it. She has problems with some relatively simple lights I have scattered around the house for when the power goes out. Handing one to a neighbor, without requiring them to read the manual, is not helpful.
I would like to ask if someone with the skills might consider making a set of firmware that makes the Q8 dead simple for an untrained user. Personally, I would buy the things necessary to reflash the firmware just to avoid confusion in an emergency. And that includes me. If the emergency is more than just losing power (e.g., earthquakes, Tsunamis, forest fires, and recently tornadoes – we have them all), I want it simple for anyone to use.
If someone is willing, we could start a thread about Q8 firmware for dummies. And when there is a reasonable set of functions, distribute the firmware.
Tom E
Tom E's picture
TK, you are sobering me up here... frown  DEL explained it to me, not sure if posted, but pretty much as you are describing. We are pushing the specs on the 7135 on these high PWM's rates and low PWM LED output values. I thought of implementing it in v1.1 of NarsilM, just no time, and the PWM value of 2 is a really nice low low moon.
cheesecheeks
Didn’t someone say it was possible to update the firmware?
ToyKeeper
ToyKeeper's picture
Noted! Big Smile
alternety wrote:
emergency light … dead simple for an untrained user
In stock form, the Q8 is already pretty simple. Click to turn on or off, hold to change brightness.
If the click timing is too fast, code is available and there are already several nice firmware options.
In any case, this is all philosophical until after you’ve tried it in person. So wait until then to decide what you think about it.
ToyKeeper
ToyKeeper's picture
Yes. Click the Link in my signature for much, much more information about that.
Tom’s Narsil code is available as a starting point, if you like the Q8 but want to make a few changes. There are also other options available if you want a different starting point. The BLF Q8 and Emisar D4/D1 have compatible drivers, so firmware for one works on the other. The only logical difference is the Q8’s indicator LED.
DB Custom
DB Custom's picture
Last seen: 11 hours 1 min ago
FWIW, I ordered my 3 on Sept 8th, 12th and 26th. All 3 show backorder status on banggood as of about 1 minute ago.
Clearly, there is no favoritism on this site as I have ordered in excess of $3000 worth of goods from them since I came to BLF. Wink
Tom E
Tom E's picture
ToyKeeper wrote:
Noted! Big Smile
alternety wrote:
emergency light ... dead simple for an untrained user
In stock form, the Q8 is already pretty simple. Click to turn on or off, hold to change brightness. If the click timing is too fast, code is available and there are already several nice firmware options. In any case, this is all philosophical until after you've tried it in person. So wait until then to decide what you think about it.
+1 with TK. The idea was make the default simple basic usage:
  • click to turn ON to last level
  • when on, click to turn OFF
  • or click&hold to ramp up, let go where you want to stop and leave it at
  • once the light is ON, click&hold to adjust it up and down
  • double click from OFF or ON to go to turbo/max without effecting the saved last level
I'm not sure if everyone agrees to this, but this basic operation described above came about directly from BLF user input, not from me or the Q8 team, least as best as I recall from early on in this thread.
the criteria here that the UI meets is:
  • quick, no frustrating delays to turn the light ON or OFF, always one click
  • quick access to the lowest setting, quick access to the max setting, quick access to last level used
  • ramping - seemed to be desired by all, and make it smooth and quick
  • get rid of poorly chosen output level sets of modes (Low/Med/Hi, etc.) - ramping has effectively an infinite # of brightness levels (~150)
The problem is of course do it all with one switch, but i think we worked that out. Now most of the talk about click timings was related to the switch LEDs, unrelated to basic operation of the light. But for those reports of the switch not working, there's two type:
  • intermittent click not working
  • any click not working til the power is reset (tube loosened)
For the intermittent issue, I think most of the the time the switch is held too long, so ramping starts. I designed ramping to be quick, so one click has to be pretty quick to differentiate from ramping. If I slow down the one click, then I'm adding delays to when ramping starts - it's a tradeoff. I thought it was a nice compromise, but others may disagree.
For the "any click not working", not sure of the detailed circumstances, how often/repeatable, etc., and certainly I've never seen it,and I believe no one on the team has seen it, prototype or production Q8's. I believe/think the reports were just a one time thing, not repeatable.
ToyKeeper
ToyKeeper's picture
If an even simpler UI is desired, that can be arranged. I could take some things out of my FSM ramping example and make a Q8 firmware which only has on, off, a reversing ramp, and maybe a 4-bar battcheck. Call it “dead simple” or something like that.
With a bit of extra plumbing, maybe it could even forget the memorized level after an hour so it’ll be more predictable after sitting idle.
Plus safety stuff like LVP and thermal regulation, but those aren’t really things the user should have to care about.
Flomotion
Flomotion's picture
Mine just got shipped!
Shipping Method:Priority Air Mail
Ship From:CN
Order Placed Date:2017-09-07 22:08:26
Shipped Date:2017-09-29 21:51:00
Expected delivery date:2017-10-22 00:00:00
Mobile:
Flomotion
Ag76
Ag76's picture
Last seen: 11 hours 24 min ago
Mine also just shipped!
Shipping Method: Priority Air Mail
Ship From: CN
Order Placed Date: 2017-09-12 22:57:13
Shipped Date: 2017-09-29 22:49:31
Expected delivery date: 2017-10-22 00:00:00
Majoroverkill
Majoroverkill's picture
Last seen: 1 week 2 days ago
NICE!!! my Q8 is finally on its way. Sweet Cool
Doug S.
Terry White
Terry White's picture
Lol mine just shipped as well.
In 14 days (maybe less) it will finally be here...
Then I can find a tutor for the UI...lmao
Terry White
Skype terrywhite1@live.com
Flintrock
Last seen: 2 years 3 months ago
For simpler UI's  I also intend to get bistro-HD working on it (might already, but ..) and probably even add a lockout command .  I've seen that Narsil has fixed modes which is very neat, heck a of a firmware with tons of features packed.  However, the click commands for ramp I guess limit the remaining commands for modes if I'm reading it right (I'll definitely give a whirl before I decide), and the one that overcomplicates it for me in modes is the lock in.  I suspect this is because long click has other uses, so you need lock in to then have an off command available?
So in bistro-HD e-switch, it will be short click forward, medium click back.  Long click off, almost as it's always been for bistro.  No lock-in, any click back on (with memory or not, no fancy double click commands to select on-the-fly like narsil).    I don't know, Tom, maybe this is something that can be worked into Narsil still? The lock-in is something I'm sure I'd rather avoid.  The thing that changes slightly for e-switch bistro is you'll need a long click-off followed by a quick tap on to get what used to be a long click in bistro, ie, with no memory, a reset to first mode. But I think that's fairly intuitive.
Tom E
Tom E's picture
I'd never care for a UI that has a long click for off, sorry. I've seen lot of posted complaints on long click ON/OFF UI's, and there's quite a few lights out there with it. Some could argue for symmetry - long ON/long OFF, and I think I've seen long ON, short OFF. Suppose all possible combos have been done.
I'm very interested in the direction TK is goin with her latest e-switch driver, but don't know all the details yet. I believe though it has, and will have many possible options for UI preferences though. That's part of the goal - give the user what they want, whether it's 60% of users, or 2% - it's all a matter of personal preference.
2 switch lights of course would give us more options, but we would probably need to jump to the next level ATMEL MCU's that have more I/O pins.
hank
hank's picture
I’ve always wondered why nobody making flashlights builds tailcaps with 4 or 8 DIP switches.
Flintrock
I can certainly see why short off would appeal to some.  For me, quick access to mode change is more important.  If I need more light NOW I need more light now.  I can always worry about turning it off later.  But I could imagine there could use cases where the opposite is true.
hank
hank's picture
That’s a lot of options/combinations/modes
And an 8-switch board offers a heckuva lot more.
You know how to count to 1024 on your fingers, right?
