I have used this solar charger with great results. It has charged (and even sustained running power while running) my small ASUS netbook, and charged a phone at the same time while in remote wilderness areas. I also built a custom adjustable voltage regulator box to use with it, and it powers my Opus BT-C3100 charger with no issues. There are many good solar chargers out there, ust make sure you do your research and read customer feedback on them.
I do have several different solar chargers and portable off-grid power systems, The photo below shows 6 of them. (the Poweradd 40-watt is the one on the blue chair to the right.)
That is the plan. to build a simple, reliable, low cost compact lantern that will do what a lantern is supposed to do, ( which what is lacking at the moment in the lantern industry from any store-bought & most online bought LED lanterns.
I’m back from a long hiatus away from BLF. I saw this thread when I checked in now and then. Here’s a simplistic idea that I’d like some feedback on.
My simple idea is to re-purpose a commercial household LED light bulb and replace the AC power supply with a DC power supply. The ideal bulb should already have good CRI and beam profile for lighting a room or 360-degree open space.
Durability during transport would be an problem. It’s not rugged enough and maybe wouldn’t weatherproof.
Also power source would be a problem, since this would cause three components to use (powerbank, cable and lantern/bulb).
A dedicated lantern makes sense for outdoor use.
For indor use an DC bulb could be an option.
sadly i didn’t do a build post, but here is a photo of the modified lantern with the Philips 11-watt household bulb. The Lantern draws less amps from the batteries with the LED bulb than it did with the CFL bulb it originally had, (for more run time) and its brighter on high mode. Also it has much better tint with the 3200K bulb. (i used the original remote-control lantern’s control circuit) A also added a 12 volt-in port & power source selector switch so it can be powered by a car cig-lighter cord, a wall adapter, or with a battery clamp cord to run from a boat or car battery for continuous running.
The Fenix lantern is a well-thoughtout thing.
But the light it emits looks very cool and 1x18650 does not have the runtime of 4x18650.
And it is quite ugly of course, a lantern should be pleasant to look at
I also had one of those, They are ok, but feels cheap for the price paid, (entirely plastic) low run times on higher modes with single 18650 cell, and tint is a bit too cool for lantern use.
