groupbuy (ALIVE) NEW Lumintop Tool AA
If the light have no problems with the lenght, I have not problem in buy 14500 protected. 18650 are very common and realiable, but there are not a lot invested in create top quality 14500 (I think), for 14500 I always prefer protected batteries.
In any case, probably I will use my tool AA (when arrive) with NiMH P. Eneloop of fujitsu (the most reliable for NiMH) or with Primaly Lithium. For Li-Ion there are nice and compact EDC 18650 today :smiley:
Got mine
It’s not really compact, the same size as a T10.
Low mode should be lower, tint is really cold white, with hints of green around the spot and some purple hue in the outer spill (due to AR glass I would guess).
High mode on Eneloop is not impressive, lower than my T10.
On 14500 it’s impressive, I think this one will run on li-ion :slight_smile:
The clip is not sturdy (same quality than AAA tool), but is sturdy enough to stay on the light firmly.
Tailcap is good, the clicky switch is precise and gives a good feedback.
I will not use the magnetic tailcap, because I don’t like AA twisties.
It should find a place in my EDC rotation, after a Nichia swap :wink:
Does it have the raised ring around the positive contact on the driver which mandates button top cells?
219C swap
So, 14mm aluminum LED board, non DTP.
I don’t know what the SMD component is, but I guess it’s just a shunt (0 ohm)
Anyway, much better now with the 219C 5000K
It seems very similar to the Pineapple Reylight driver. Seems to have a little “top” to make contact with the battery, right?
Did you use 14500 with or without button top? Any “rattle” with the battery?
Thanks for the review, just saved me money.
Don’t need another AA Flashlight with cold tint that needs an emitter upgrade.
Was hoping they would be at least a neutral white and also think you are spot on about the AR glass making things worse.
Later,
Keith
That was with a button top 14500, and the battery rattles a bit, tolerance is a bit lose in diamter
Thanks - X3-!! Mine will arrive the next days! Gonna see how the cells I have work ! :+1:
thank you for the extra info
Tja….
Today I received the Tool AA, and quite unfortunately (for Lumintop) today I also received a Utorch UT01 (my first), both lights have a Cree XP-L led and both are suitable for use with NiMh and alkalines. I got them for a comparable price.
Let me start with this: nowadays the only reason for me to buy a AA format flashlight is for use with Eneloops, since the Aspire 18350 has become available I hardly see rationality for 14500 lights anymore unless the capacity will at least double. In that perspective here’s my impression:
So I placed an Eneloop Pro cell in both flashlights, both were at 1.33 V. Here’s how they look side-by-side on a white wall, ToolAA on the right:
That output difference is so huge!!! the ToolAA is roasted by the Utorch, nothing can make up for that anymore, mind that the Tool AA is a brand new light with a Cree XP-L, how hard can it be?! In numbers, with these reasonably charged up Eneloops, at 30s: 248lm for the UT01 (flat regulated. Very nice!), 84lm for the ToolAA (slowly dropping). Swapping the batteries did not change anything. Btw, the tint of the Utorch is quite a bit better (plain white with a hint of rose) than the tint of the Tool (slightly greenish yellow).
Waving the two lights in front of my phone camera shows the low frequency PWM (<1000Hz) of the ToolAA, while no PWM can be seen with the UT01.
Conclusion: Lumintop listen, I really like the form factor of the ToolAA but your boost drivers are lightyears behind the competition, the ToolAA is a nice upgrade for an ancient Ultrafire C3, but even with its XP-L it has nothing to do with a modern flashlight.
Left to right: Utorch UT01, JaxmanE2L (my EDC, 1200lm of 97CRI), Lumintop ToolAA, Ultrafire C3
Thanks Djoss for the info…Sadly I bought this light because I wanted some AA flashlight. And I have the Utorch UT01 but if your picture is right I will bury this light and never buy a light from lumintop anymore. This is disgusting.
I would not call it disgusting, Lumintop has work to do! I like almost all of their designs, now they need to get their electronics in order.
How is the runtime on NiMH? It might not be bad if it does not pull much on the cell?
How does it do on 14500?
Mine should show up soon…
I will measure current and calculate efficiency tonight, not expecting anything special there. I’m sure the ToolAA will be useful if not much light is needed, but for that I can use my old C3 too.
Is it from me or they have the same kind of UI in almost all their small lights? L-M-H, no moonlight, nothing “outside the box” from some years now?
I don’t have any LT, this will be my first, but their look always get my attention, but then, reading the specs, I usually refrain from buying as they seem to be very similar.
I’m not saying that they should have lots of things - I normally prefer simple ones - but their lights deserves a better “electronic” part as you say!
Maybe the cooperation with BLF for the FW3A can open their “horizons” and maybe they import some of the “savoir-faire” from here!
This or the next week I’ll receive the Sofirn SF14 and SP10A and gonna compare them with the LT Tool AA, just to perceive how the brands are doing things…
L-M-H is okay, IMO but should be better spaced…
1 lumen is enough for L
50 lumens will suit any everyday situation for M
200 lumens as a bonus for H
Basically, this is Thrunite UI on the T10 and it’s why I keep mine in my Pocket.
Hmmm… does Tool AA have PWM? that’s strange, because I have Tool AAA (Nichia one) and can’t see and hear PWM on it* . is it a step backward?…
*maybe something over 15 kHz, thats my hearing range.
UT01 is still the king in AA battery format and I own 3 of them but none lumintop Tool AA.
UT01 did have bad switch issue in earlier days but now i think they fixed the problem. :slight_smile:
Happy flashaholic :smiley:
Hum, but the Low on the Tool AA is higher than 1, right? (At least from the specs…)
The 1 lumen is what you say it would be good? If so, I agree with you as the mode spacing is not the best!
The Amutorch S3 you also have has the same problem, the lowest mode is higher than expected, and that light only gets a better mode spacing when a 14500 is put inside (as the Tool AA seems to be too).
Thankfully there are many options we can get, test, like and dislike, that’s the best on this situation :smiley:
