Ramping starts after 48 frames by default. The first 24 frames allow for a regular click to happen (instead of holding to ramp). The next 24 frames are the window for long-press-for-moon. After that, ramping starts.
Look for EV_click1_hold in off_state, and remove the part about “if (arg >= HOLD_TIMEOUT)”. This should make ramping start about 24 frames sooner. However, it will also eliminate the ability to long-press from off to go to moon.
You could also try reducing the value of HOLD_TIMEOUT or the value of RELEASE_TIMEOUT to speed up the entire interface, but it’ll mean less time to do each click.
Or you could even make it start ramping before it hits HOLD_TIMEOUT, but that will also eliminate the ability to do any clicks of any type from off, unless you’re clever and do some much bigger changes.
You could also just give it a smaller value, like 6 to allow a 6-frame window to stop at moon before ramping.
And to make the timing easier, you could make it not turn the light on until that window starts. Slower feedback from off, but it gives a timing hint for the shortcut. Tradeoffs…
It runs at 62 frames per second, or 0.016 ms per frame. So a value of 12 is just barely under 1/5th of a second.
People have had difficulty with a window of 18 frames on the Q8, and I’ve found that 31 frames feels too long, so I used a default of 24.
Zebralights, IIRC, use a window of 0.5s or 31 frames:
Frames 1-31: Light is at low, release to go to high.
Frames 32-62: Light is at low, release to stay at low.
Frames 63-93: Light is at med, release to stay at med.
Anyway, I just wrapped the definitions of HOLD_TIMEOUT and RELEASE_TIMEOUT to make them definable from the UI code instead of having to dive into headers. So, after this update is pushed, just stick an extra line in the main UI file and it’ll override the toolkit’s defaults.
The HOLD one is how many frames it takes to go from a “press” to a “hold”, or how long a single click can be. The RELEASE one is how many frames it waits after a click to see if another click will happen. To cause a full click event to be sent to the UI code, what happens is…
User presses button. “EV_click1_press” event gets sent to the UI code.
Anywhere from 1 to HOLD_TIMEOUT frames happens. Let’s say 12 frames.
User releases button. “EV_click1_release” event gets sent to the UI code.
Light waits RELEASE_TIMEOUT frames, and nothing happens. Now we’re at frame 36.
“EV_1click” event gets sent to the UI code, indicating that it was only a single click and it’s too late for a double click to happen.
The events aren’t quite immediate though… they go into a queue and get sent/processed later when the MCU is in an idle loop. In normal circumstances, this only delays things by a few microseconds… enough for the current interrupt (WDT, PCINT, ADC) to finish. I’ve generally been very careful to avoid anything time-consuming during interrupts, because those need to be serviced quickly and then go back to the regular code flow as soon as possible. The queue offloads the time-consuming parts to a safer part of the code.
I’m kind of just rambling now though, twiddling my thumbs while waiting for DHL to show up with new lights.
Hang on there a minute. On a bright sunny day blinking out temperature or voltage might be rather hard to see if done at moonlight levels. At the risk of adding ANOTHER configuration, it might be nice to be able to select the intensity of these blinks.
With moonlight configured to be really low, maybe, I don’t know. On my D1 / D4 with stock firmware moonlight is easy to see during a day. Actually with D1 it’s well above the threshold of being painful to look at, even during a day.
Though it may not be moonlight. My complaint about the current level is that the amount of light is disturbing.
If I shine it at my hand to avoid disturbing others, the reflection blinds me.
It doesn’t take moonlight to avoid the issue.
The nitecore MH20’s e-switch is blinking the battery voltage when tightening the tailcap, so why not doing the same with the D4’s front emitters and use the 3 clicks for something else ? A shortcut to 7135 100% for example.
Is there a hex file available of Anduril for a TA FET+1+16 (or 8AMCs) driver? I want to order 2 drivers from lexel and would like em to be flashed with anduril, Lexel can flash them for me with any kind of firmware but he needs/wants the hex file as he “can’t calibrate Anduril like he’s used to in Narsil”.
I myself have no clue what a HEX file is used for or if there is any difference between the hex file for a FET+1+8 and a FET+1+16 driver :person_facepalming:
Thanks goshdogit, yes I’ve downloaded all the files there and add to the AS project, I think the error is the fsm-adc.c file or its comments, never have this issue when compiling Narsil.
It’s already massively sped up compared to RampingIOS, and IIRC dimmer too… and only blinks once. It’s basically using the same boot blink I used in Ferrero Rocher, just a quick blip to confirm power is connected… without causing any meaningful delay. But if you’re in a dark place and trying not to be noticed, it’s still a good idea to cover the light before connecting power.
