Bistro firmware question
Hello all,
I’ve got an Eagle Eye X6 with the FET + 7135 driver and the Bistro firmware. I’m having trouble activating the mode memory feature. All other configuration options seem to be working correctly,
Sometimes it will go to the next higher mode or it might even start in a lower mode the next time I turn the light on.
How long should I have to leave the light off before the mode memory will be activated?
Any ideas what’s going on with this.
Thanks
Sounds like it may be an issue with the Off Time Cap or the bleeder resistor for the lighted tail cap
ToyKeeper will most likely know, or pilotdog68.
Too drugged for a pinched nerve in my shoulder to remember things clearly, but that bleeder resistor seems to be flagging my memory…
i want to ask-bistro driver i can program from 7 modes to four by the 15 tap tap method?thanks
What you want is here:
~toykeeper/flashlight-firmware/blf-x6v2: Contents of ToyKeeper/bistro/bistro.txt @Latest Revision ie:208 (ToyKeeper) (Rev 206 used by Manker for BLF X6/X5)
http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/blf-x6v2/view/head:/ToyKeeper/bistro/bistro.txt
Best Regards,
George
ok.i did 15 times of tap tap…i want 4 modes group.low mid hi turbo…
when it starts to blinking and strobo…what to do? iam waiting for 4 times blinking,which should mean,iam in 4 modes group….how to fix it please?iam mad of it….
If you want 4 modes without moon you should select 5 modes group and turn off moon
1.- To enter to config mode: tap tap until light not respond
2.- To enter to change mode group: wait until the 5th group of blinks (5 blinks), then, during the buzz, tap
3.- To select the group: wait until the 5th group of blinks (5 blinks), then, during the buzz, tap
4.- To turn off moon: you should enter to config mode again, then wait until the 3rd group, then, during the buzz, tap
Now your light have 4 modes without moon: low, med, high, turbo and hidden modes as BLF A6
Does this Bistro firmware have “.5 or 1 lumen moonlight”?
