Newbie here. I would like to do a bare bones AAA light made from the innards of an existing one-mode light.
The goal is ultra light weight, at the expense of shock/water/dust/etc. protection. I do want at least a reflector and probably a lens.
So far my idea is to use a large diameter straw as the case, have a wire of some sort running from the end to the bulb end, and possibly even omit the switch, worst case scenario just jamming the wire against the battery when light is needed.
I realize this sounds sort of bonkers. And I understand it won’t be blast proof, or water proof, or very durable at all. But the idea is sort of a fun challenge to myself to see how light it can get and still be a nice little neat or almost-neat package. Ultimately it will be carried in a small EDC kit (EDIT: as a backup, not a main EDC flashlight). Existing tiny lights don’t fill the bill because I want both AAA and absurd lightness.
I picked up a Coast G10 with this project in mind but it doesn’t seem to want to open. If anyone knows how to open it, I’ll start there. If not, I’m looking for suggestions as to which flashlight might be easy to work with (and maybe a worthy sacrifice, not something I’d want to keep intact) for the purpose I’ve described. I’m set on AAA because of the ease of buying them almost anywhere.
Not set on having a lot of lumens… anywhere from 20 to 100… higher is better, but on the low end of that is fine.
My question for the forum is: what are some good single mode lights to start with, assuming I don’t want to build everything myself, but prefer to take something that is working and just repurpose the insides (the “pill” I suppose it is called?)
Edit: And by the way, super excited to find this forum! Hoping to do or get in on some other projects here in the future!
This doesn’t answer your question, but have you considered using a 10mm LED?
Sure, the output would be at the low end of what you’re looking for, and it would probably be more complex, and maybe even more expensive once you bought a driver, but it would be bonkers.
I’m not opposed to doing the whole thing from parts… just thought re-purposing an existing light might be easier as a first project.
I do have a soldering iron in case I go that other route, but I could do with a refresher on basic electronics.
Might be fun to do it that way too. Maybe I’ll do that… or if not right away, maybe as a second project. Thanks for the suggestion!
Yes the bubble tea sized straw was what I had in mind. They are easy to find around here even without ebay . The AAA fits nicely inside with just enough wiggle room for a thin metal strip or wire.
The SingFire SF - 348 seems to be about as thin as a AAA light can get, and it has a single mode click switch. I don’t own one so I have no idea how hard it would be to disassemble, but if you can’t get it apart or you break it you haven’t lost much.
If it’s really hard to disassemble you could try cutting the battery tube just below the driver. There will be a bit of extra weight from the tube that’s left, but it would keep the lens, reflector, emitter and driver together.
Thanks, yes that does look like a thin and simple flashlight… great suggestion! Not sure how hard it would be either but I ordered one and am going to give it a try. Will try other lights too in the meantime if I find any promising ones.
Olight I3e-eos is barely bigger than a AAA, weighs almost nothing, and can take a lot of abuse. I would check that out before thinking about building anything.
The 348 is the slimmest AAA light with its 12mm diameter, but it’s 90mm long and not light weight because it’s stainless steel.
The Olight i3E is the shortest AAA light as far as i know, it’s only 61mm long (when turned off, 60mm when turned on), the head is 14mm wide.
The Olight is hell to modify, because it has the LED soldered on the driver PCB…
The 348 is a lot easier to modify, it has a brass pill with a driver PCB in the rear and a tiny LED board on the front.
The Olight i3E is absolutely not the quality of the i3S.
In fact, it’s a bit of a POS…
I killed the original Luxeon LED by twisting the head too tight (turning it on).
The Luxeon LED has a ridiculous footprint, so i was forced to spend hours fitting a 1mm XP LED board…
I had to sand down the driver PCB to about 0.25 mm thickness and had to make through holes for LED wires, etcetera…
A nightmare that fortunately ended quite well.
It now has a XP-G3 behind its TIR optic and reasonable thermal path to the battery tube when turned on.
I have the ‘silver’ i3E version (has a bit more power) and it’s pretty bright.
Anyway, some weight was added, but it’s still only 8 grams (0.28 oz).
They’re sold as Thorfire too by the way.
Have just checked on my scale, olight is 8g, aaa Nimh Duracell is 12g, and an AA alkaline is 24g. So the Olight with battery is lighter than a bare AA battery and looks like it is possibly smaller in volume, though slightly longer.
8g, that is pretty good for off the shelf. I’m using ultimate lithium batteries which are 7.77g on my scale… (are they well regarded in the flashlight world? …not exactly budget, but maybe they are when you factor in the value of long shelf life.) My hope would be to eliminate most of that 8g and bring the total weight including battery down to around 10g but we’ll see.
Just for perspective on weight, I recently made (well girlfriend did most of the work) a string backpack that weighs 10.61g including its carrying bag, and is capable of carrying my laptop, which is sort of a medium laptop in terms of weight (old 13” MacBook Pro). In its carrying bag it’s about the size of a walnut… outside of its bag it’s a little bigger than a laptop. Yeah I’m what they call a gram weenie.
If you take the head off the olight it probably weighs 4g, can’t check it right now.
That gives you everything you need except a return path for the negative at the back of the battery.
If you can make a spring mechanism that holds the battery in by pushing the back end, you have a functioning light at about 4g. The positive end of the battery will sit 1cm inside the head so it will be quite secure, and if you splay the head apart by 1-2mm an AA will also fit, giving you much longer battery life, but heat dissipation might be an issue unless you add resistance to reduce the current.
Yes that’s actually what I’ve been thinking! I got the copper one today, not going to destroy that one (it’s also heavy), but have an aluminum one coming in another day. Another idea is to cut away all but a couple thin rails of metal, just enough to hold the battery contact in place, and replace the missing material with light fabric.
This won’t be a light for daily use. It will be more just a lightweight part of a small kit… more as a backup than an everyday light.
