Ok sounds good. Nice review btw!
I have an Lumintop SD26 that is of comparable size. The Lumintop has a fancier X patterned knurling and a slightly larger head diameter but theyâre pretty close to the same overall size. The hot spot from the Sofirn SP33 is smaller but both are well defined. The Lumintop emitter color is blue-white, as compared to what is a now noticeable pink or slightly rosy hue in the Sofirn. I had thought the Sofirn hue was around a 3C, and that may well be, but itâs either that or a 3D.
The Sofirn has the lighted side switch cover, a nice touch, and also a SS bezel, again a nice touch. The Sofirn also comes in around half the price of the Lumintop, so all in all itâs a nice deal on a well made light.
Great review Dale, and really interesting light, Sofirn also have some new C8 models with 5,6Amp on highest level in stock with XPL , and 1700+ lumens they claim⊠Also driver have two setup with moonlight, and without blinking modes. They look good as Thorfire C8, so I am tempting to order one from Ali store.
Hello Khas,
The C8âC8F are ready on Aliexpress.com. If you are interested in testing the torch with 2 light groups, please feel free to contact us on Aliexpress:
Have a good time
Tracy
I have ordered one itâs currently :
âWaiting for pick upâ Since : 2017-09-15 09:26:11 [GMT+8]
Hope somebody will pick it up soon
SP33 works fine with light diffuser for Convoy M1/M2. Good camping lamp with lot of light :+1:
Cool info, thanks for posting⊠I really like this one a lot, used it last night and am just really impressed with itâs coverage. This is one of those that a person would do well to have if only having a couple of lights. This and a Klarus G35 or an Olight M2X-UT Javelot and a guy would be pretty well fixed. (or gal)
Not really. The side switch design is all wrong. You need a light with a seperate switch, not one built into the driver.
I was searching this forum for a 26650 flashlight and settled for the sofirn one but apparently that model has been recently upgraded.
Those are the notable differences I found.
â» Emitter: CREE XHP50.2 LED
â» Working Voltage: 2.8V-4.3V
â» Battery Options: One 18650 Li-ion battery or single 26650 battery
â» Dimension:128mm (length)*37mm (head diameter)
⻠Weight: 150±2 gram (without batteries)
â» Aerospace grade 6061 grade aluminum alloy, CNC manufactured to hard-anodized anti-abrasive finish to get solid built body, anti-crash geometry and better heat exchange.
â» Toughened mineral glass lens; Orange peel reflector
â» The waterproof level: in accordance with IPX8 (Ingress Protection X8- resistant to submersion up to a maximum depth of 2 m underwater for up to 30 minutes)
â» Mode Memory: It memorizes the last brightness level used in the general modes (except Strobe and Turbo)
â» Advanced Temperature Regulation (ATR) technology: ATR will adjust the brightness automatically when the temperature reaches 55â (131 °F) to prevent overheating.
â» Automatic Step-down: Turbo mode steps down to High mode after 2 minutes of working to prevent overheating.
Step-down and Advanced Temperature Regulation (ATR) coexist.
â» Power Indicator: The LED indicator on side switch displays Green for 5 seconds if remaining battery power is good. The indicator is Red, if battery power is poor. Red Flashes indicates extremely low power - replace or recharge battery as soon as possible.
â» Reverse polarity protection from improper battery installation.
â» High Voltage Protection: The light cannot turn on if the voltage was over 5 Volts
â» Low Voltage Protection: the light turns off automatically when the voltage was lower than around 2.6 Volts; The Turbo will be disabled autocratically when the voltage is lower than 3.4 volts; It steps down to lower modes automatically when the voltage is lower than 3 Volts
Has anyone else noticed or reviewed the updated version ?
Thanks for your time
Yes, I recently became aware of this updated version when Sofirn asked me to translate the new manual into German language. AFAIK it's more or less some kind of a "silent relaunch" with the new XHP50.2 version and according to their webshop on AliExpress it has started to roll out this month. I have purchased it for something like $ 23,- which is in my opinion a really nice price. They might also offer it on Amazon later on both with and without battery and charger just like they did with the C8F 21700 but this is yet to be confirmed by Sofirn.
Thanks for the heads up, hadnât seen that.
About how many lumens does it put out with the new XHP50.2?
What do you think the change in emitter will do to the hotspot?
Iâm becoming more and more interested in 26650 lights. This could be a nice addition.
Ehhhh, about that.
The XHP50.2 is going to be a tint mix of the rainbow. Not as bad as an XHP70.2, but still worse than the XHP50.
So around 2250 lumens that it would output I reckon.
Yeah, Iâd rather have an XP-L Hi pushed hard but nobody asked. The XP-L2 and XHP-50.2 are flip chip technology, as such they can be sliced and diced to improve the beam profile but itâs sort of tedious work⊠not horrible but better to not have to.
What about cut the dome of 50.2 will the tint get better beside more throw?
Thanks for the info.
Iâll still keep this one on the radar.
You have to slice the dome off close to the phosphor and then cut the phosphor and silicone off the sides, where it overlaps the substrate. This is the part I call dicing because itâs a vertical cut. This leaves the bare die on the substrate with no extra phosphor to pollute the beam, pretty much eliminates the bad aura, but costs some lumens in the end as is typical of a de-dome or slice.
Thanks DB ,I will take this SP33 50.2 may be on 11.11 sell.
Iâve thought about leaving the dome on, but dicing off the corners of the led where you have extra phosphor (or at least extra yellow stuff). I wonder if that would reduce the yellow corona any?
I like the dome, but not the yellow.
I havenât tried leaving the dome and just clearing the substrate, might be a little tricky to not push the dome off and remove phosphor but a really sharp blade helped with some silicone grease so it doesnât grab might do it. A guillotine style vertical chop down beside the die and then an outward flick, should do the trick. Try it and see how it worksâŠ
