Review and disassembly: Sofirn C8F
You mean LEDs overheated?
There was even more pressure with SS bezel. It even doesn’t screw all the was down with thick o-ring I used.
I don’t think it could overheat in a minute even with low pressure, but I may be wrong.
maybe the driver can’t handle the current
Mine looked like this when I turned it on first time :
I don’t think the XP-G3 likes the heat, the MCPCB isn’t DTP.
XP-L HD/HI works fine :
With XP-L HI V2 4B it pulls 12.3 A on a VTC6 on high, it does get very hot before the 3 min step down, I have been using it for walking the dog the last two evenings drained two VTC6 batteries so far no problems with XP-L HI
You did reflow yourself? On stock pcb?
Looks like there’s some room for improvement :laughing:
Did you bypass the springs too ?
Yes I re-flowed the emitters on the stock MCPCB myself, the XP-G3 has a low Vf so they pull a lot of amps, if the just used XP-G2 instead it would be fine.
The springs are bypassed from Sofirn.
Ok, looks like I have to order some XP-L HI :smiley:
Can you post some beamshots? I want to know how does it look with XP-L HI.
White wall would be ok :slight_smile:
Sofirn C8F Triple XP-L HI V2 4500K LED
I sent Sofirn a message on Aliexpress trying explain that the XP-G3 is the wrong emitter for the C8F, it’s of course fine if you use a low drain battery, but high drain battery and bypassed springs is not going to end well.
Thank you. Looks great :slight_smile:
Maybe I killed it because I used LG HG2…
If using high drain cells, you may try lowering the cell voltage. You could, for example, start at 3.7V with a 30Q and measure current flow. Maybe the overall Vf off 3 XP-G3 emitters in parallel is a bit low, this way there's a very good chance the emitters will survive by limiting the potential current avalanche.
This looks maybe like design fail and if it is it needs to change.
No battery should cause leds to die in any flashlight.
That is what regulated drivers are for.
Cheers :-)
I guess you are right :slight_smile:
Turning blue means catastrophic levels of current being pushed through the chip.
I had a “3V-22V” drop-in that I wanted to test to make sure it could handle even only 2 cells, so put in 2 18350s. Got really blue and really dim. Didn’t have it that way for more than 1-2sec tops, pulled the plug. 1 cell back in, the bugger survived.
1 cell?? Dunno how a trip could go blue from only 1 cell like that, even if just crowbarred right across the LEDs.
Unless they separated from the mcpcb and were just floating? Could make electrical contact w/o much thermal contact. That might cook ’em.
It was on no more than a second after turning blue but no help. I don’t understand how would they get so hot that fast. I was using it max 2 minutes before they died but it wasn’t constant on as I was playing with modes.
Interesting is moon didn’t work at all (before it died), leds were off in that mode.
It’s before my time here, but I believe OL did pretty much only DD lights: LED and Li cell and switch, that’s the whole circuit. Don’t think they could cook so fast unless there was some serious thermal upset.
’Though now with continuous-38A cells…
Turning blue means that solder under led is bad and melting at low temperatures. Try to reflow same xpg3 with better solder and flux, worked for me couple times even with DTP boards and XHP70…
You think they could work again?
I did led reflow only one time before, so no experience with that and no tools for that.
I am 99% sure they will come back to life…
Probaj nemas sta da izgubis :beer:
