It has no name on it! I did try to clean any residue but still can’t see any name on it.
By the way, my C8F version “XP-G2” with Samsung 30Q get hot quickly, I scared to keep it on high mode too long to test for step-down automatically.
So, I will use low drain current battery with it, may be Walmart 18650 (Westinghouse).
Stacking FETs (no, they are not “MOSFets” these days) is not, In my opinion, an avenue worth pursuing.
The one being talked about here looks like a very good one. Each of the two FETs inside has under 18 mOhm on resistance, and whilst each is rated at 8A continuous, data is provided to four times that.
So the original dual package should be quite happy to at least 16A continuous. Dissipating no more than 2.3 watts at that current. Dropping 0.144 volts maximum.Which if properly laid out on a footprint with lots of copper plane, is well within spec. (Case temperature de-rating allows about 65C at that power)
Nevermind these numbers, this dual FET package will have, datasheet, passing 16A, under 9 milliohms resistance. I would suggest looking elsewhere to improve the overall resistance in the current path before worrying about the FET.
All you get by stacking on another one is a (theoretical) halving of Rds on. From maybe 9 to 4.5 milli Ohms. Vanishing returns, and very little more thermal dissipation in a stacked configuration.
Then again, I confidently expect it will carry on working at much higher current levels and temperatures, except that it is off the published datasheet.
Little buggers at the factory trying to hide the component markings?
It was curious for me to see the C8F advertised with XP-G2 emitters inside, to find these user samples here with XP-G3 units and overcurrent problems. Usually happens when non-knowledgeable people takes the decisions.
A spring de-bypass or two would help for XP-G3 (and Nichia 219B/C) emitters.
Tom Tom, the Si9926CD datasheet lists a maximum of 8A per package. The thermal resistance is too high and the little FET bugger will end up like a roasted burger. I'd stack another package just because of reliability.
Stacking another one on top will make almost no difference to thermal dissipation. You would have to lay them out on separate bits of the PCB, for the heat to be conducted through the leads into separate areas the PCB where it gets dissipated.
We are agreed, this little package would be toasted without any decent thermal path into the board. Stacking another one on top won’t improve anything there.
I think the two FETs inside the one package are quite capable of handling the current, and the power. And the PCB, presumably so.
The rest is over to you, if you think e.g. reducing from 9 to 4.5 milliohms is of any consequence…
$8.99 on e-bay.
$2.09 for SST-40 when buying 1, $1.6 when buying 10.
These are on stars, though I don’t know if they are DTP. Most likely not copper…but if it’s DTP I would stick with it for such cheap light. If it’s not DTP then this light won’t be nearly as cheap….
I can recommend those with experience. First fried two cheap SST-40 with poor star/MCPCP. Then ordered those and they handle amps at least up to 5.5A in my setup. Edit: Someone told me that he drives those at 8A.
“according Cissy from Sofirn driver is direct driven.” That I updated today and I measured tailcap amps of C8A: I got with freshly charged NCR18650GA after some spread 6.10A @ High. Have anybody measured amps with different/ better batteries from any other model (or same) of those C8:s?
Edit: Peak was around 6.3A.
Edit2: Now there is in add that driver is direct drive.
Edit3: Led gasket have been chanced but only for XP 3.5mm footprint leds:
Just talked in other matter with Cissy from Sofirn. She asked me something, I answered but maybe here are also people that could say their opinions. It’s about new C8F. There are two kind of driver groups and Cissy asked which one would be better. I quote Cissys message straight here and do tell what you think.
“Switch: one side switch
3 groups modes
One click enter group1 : Low- mid-high
Double click enter group2: LL-Low-mid-high
Three click enter group3: firefly-LL-Low-mid-high
In any groups when light on, double click enter hidden mode:strobe-SOS-bike -strobe. three click enter turbo mode 1950 Lumens
2. 3 groups modes:
Turn on enter group 1: low-mid- high
When light on, four times quick press switch to change groups, cycle from group1- group2-group3-group4
In any groups when light on, double click enter hidden mode:strobe-SOS-bike -strobe. three click enter turbo mode 1950 Lumens”
And like Jackie said above C8F is coming with DTP MCPCB because of problems with heat.
Cissy/ Sofirn needs help to decide from 2 groups. She gives everyone who respond to this query 2$ discount QR code from at least 15$ purchase from Sofirn AE shop. I sent it via PM to all who gives their opinion which group would be better.
Copy of what Cissy said about double click after I asked could it be modified:
“Double click to turbo 1950Lm and three click to strobe-SOS-bike-strobe.”
And also assumption from Cissy: “also may use 3 pieces XPL instead of XPG3”
I vote plan 2 now when it’s only 3 groups you can switch between.
It’s easier for “normal” people to get right.
Double click for turbo should be standardized.
3 fast clicks for strobe…
Changing groups should atleast be 5 fast clicks so it don’t accidently change group instead of putting on the strobe to blind an attacker or whatever strobe is used for.
If I was in that situation and I panic and try to put on the strobe and accidently changed mode instead of getting the strobe I think I would have gotten more panic.
If i just did a double click when panic I think ~2000 lumens would still blind the attacker.
How do animals react on high lumen strobe when attacking?
Should I strobe an attacking bear, wolf and such animals?
Does this Sofirn driver have any hidden turbo?
It says 86%PWM at high, can’t find any info about any turbo.
I guess it’s the driver that’s in the Sofirns right now?
No thermal stepdown?
Sofirn New C8A C8F C8T Driver 2 Groups Circuit Board Anti-reverse LED Driver Chip mode memory
Protection:Reverse polarity protection, low voltage protection, Memory mode function
Input voltage: 2.8-4.2V;
Current: Directly-drive
Suit for : Cree XM-L ; XP-L, XP-G
2 Groups:
Group 1:Low 5%PWM> Mid 30%PWM > High 86%PWM,Double click strobe 86%PWM.
Group 2 :Moonlight > Low 5% PWM> Mid 30%PWM > High 86%PWM> SOS 86%PWM,Double click strobe 86%PWM
Low voltage protection: Yes. The light is automatically turns off when the voltage is lower than 2.8 volts. The signal is that the light slowly flashes for 1 minutes
Group Set Operation: When on, 3 click continuously, the light flash 2 times and then automatically goes to next mode group.
