You have to use the code while on the shopping cart page. It doesn’t work if you are already on the checkout page.
If you leave the stock D1’s fet you’ll be OK whatever battery you use , even VTC5A (lower ir i know) .
Is there something unusually fragile about the 7135 chips after they have been added to driver boards?
I’ve now had three of them fracture when flashlights were dropped a few feet onto a wooden floor.
Each time, the chip on the spring side of the driver apparently took the impact transmitted from battery tube to retaining ring to the side of the chip closest to the edge, and the 7135 broke.
A couple of these were cracks without any obvious separation until I poked at the chip after the third one broke and I could see the problem. But they fell apart under slight pressure.
These were drivers where I”d just tightened the retaining ring down and it pressed on the 7135(s) on the spring side of the driver
I consider this my fault for not notching the retaining ring to go around the component, which I used to do regularly.
(discussion and pictures of that in prior thread: Driver retaining ring that clears Nanjg 105c in Convoy S series? )
Lesson learned. Now I have to learn how to solder these itty bitty components, which so far I’’ve tended to mess up.
Or buy new drivers ….
Can I just heat up that broken 7135 and pull it off the board, and have a functioning 4x7135 driver?
Or am I in danger of melting something else important?
Not sure what the little rectangular thing between the 7135 and the ground ring is - part of the 7135 or another component?
Part of the 7135, it is the same metal as the middle pin on the opposite side. If you have a hot air gun with a small nozzle you can use that to heat the component and remove it. If you only have a normal iron you can just blob a bunch of solder across all 3 pins and remove it then clean up after.
It will work fine as 4x7135.
Hm. I pushed the broken bit back toward the middle of the board, and cranked the retaining ring down past it to contact the ground ring — and the flashlight works again.
So, could I have just filed off the corner of the 7135 to clear the retaining ring?
Obviously I have no idea what’s inside these little black boxes.
It’s a mystery to me why the light still works even though part of this 7135 is broken off. I’d guess I’m just getting the other four 7135 chips working and this one not doing anything.
No magic smoke leaking out, anyhow.
Looks like there’s enough room toward the center of the driver that that 7135 could be positioned further from the edge so the retaining ring doesn’t hit it. But that might disconnect whatever contact is being made by that rectangular piece on the ground ring side, I guess. Fiddlesticks.
Is there a picture anywhere of the innards of a 7135 so I could try filing off those endangered corners on other drivers before I install them, to clear the retaining ring, and know how deep it’s safe to go?
You shold file the inside of the retaining ring larger
Or use a Dremel to cut the edges of the 7135 round so there is some distance between the black compound to the retaining ring
Your pictures show the 7135 already damaged by the retaining ring so they are under static pressure, a bump gets at top a big dynamic pressure and they crack
Yep. I’d been notching the retaining rings for a while. As pictured here, in the prior thread about this:
That approach has the annoyance of having to “de-twist” the driver wires, then fit the driver into the retaining ring, then twist to tighten. The retaining ring in that picture isn’t fully screwed in.
Someone somewhere suggested it was reasonably safe electrically to just let the retaining ring press down on the top of the 7135s, so I tried that for a while — and when I dropped the flashlights, this was the result.
I know, “then don’t drop the flashlights” is the conclusion.
I’m wondering how much of the innards of the 7135s is at risk if I start rounding off the corners, as those would be easier to file than the retaining rings.
Got the D4 heads today Richard, thanks for doing that for me, you are the man for sure.
Anything I can do for you just holler, maybe wash your truck.? Buy the plane ticket from WA and I’m on it… ha ha,
Always will be loyal to Mt. no matter what…!
Hank, you can probably do some of both for a good result…. file out the retaining ring a bit AND round off the corners of the 7135’s. The little box with the brown middle is the capacitor, allowing the retaining ring to touch that ground side of the cap is ok.
The 7135’s are pretty forgiving, but you have to keep from exposing the internal metal bits to the ground of the retaining ring. That retaining ring looks unusually wide, is it a shelf at the top and the sides are not that thick? You can always leave the retaining ring completely off on those brass pills and simply solder the ground ring to the brass pill on 2 sides, or 3 points, you’d just have to desolder that ground connection to remove the driver. It’d be cleaner without the retaining ring, pretty easy to do.
> do some of both
Good advice, thanks.
Yes, those Convoy retaining rings (I asked Simon to sell me extras a while back, and also got a bunch from Fasttech) have a thin cylindrical sidewall and a fairly big shelf — the shelf is the part pictured that has been notched with a file.
It overhangs the 7135s or whatever other component is near the edge of the driver.
The sidewall contacts the ground ring around the edge of the driver and clears the driver components.
Hi NewLumen, I was catching up on some posts and noticed your L2 questions so realizing I’m just a bit late I didn’t see any mention of the fact there’s a huge L2 thread here by J-Dub and if you don’t know who that is that’s alright, I’d say he’s one of the best of the best at modding the L2 or so it seemed to me, here is that huge thread for you friend, Convoy L2...Guess who's back???
By the way there’s some links in the OP to a modding thread and some others as well.
Good luck Great Light for sure…
J-Dub works closely with Simon in the development of his Convoy lights, J-Dub doesn’t do modding himself, he’s got me and Kawiboy for that.
Ah, thanks for the tuneup, I knew he was working with Simon and has came up with some great ideas for Simon, but just sort of assumed I guess on his overall mod abilities.
You my friend are most certainly one of the best if not the most fully well rounded modder here and even more so since you got the lathe to work with, that really up the game for you.
You are impressive, Perhaps someday I will have to see if you still remember how to mod a Ti C8, someday, maybe… ha ha
Thanks Dale
Thanks , but you’ll have to remember it’s a Ti X6 first. lol
The lathe changes one’s perspective tenfold, being able to cut threads and mate two pieces together without worrying about standards to create a one-off is one of the most fun parts about it, and of course virtually nothing stands in the way of creating whatever your need demands. Currently making a rather large heat-sink/tube extender. It’s not as glamorous as it might seem though because there is a tremendous amount of repetitive work making mounds of shavings to get where you wish to go. This translates to a lot of time standing at the lathe, cramps in the back, and sore feet. Grueling, but so satisfying in the end. (nothing fun about boring a 32650 tube) Barring the finances to buy the proper tools, one must make do with what one has…. in my case that is a large quantity of time. The lathe becomes a black hole for your extra time, absorbing you past meal times and family outings. (I’m hoping it’ll carve some extra weight off my frame, in the heat that seems so prevalent here.)
At the end of a dream project, you sit back and look at the initial investment in a host, materials, emitters, reflectors, cells, and then you start thinking about those hours… nothing budget about the process, that’s for sure! Still, hoping to build my first honest 20,000+ lumen achievement.
(If I can just remember where I was when I stopped…hate it when parts come in and I’ve forgotten why I ordered them!)
I generally either do a mod right away when the parts come in… or I wait until I don’t remember what the parts were for. I’ve got a lot of parts now.
You only THINK you’ve got a lot of parts! You should see what happened over here when I bought Old-Lumens out. Still trying to wrap my mind around what I have on hand and am constantly finding things I didn’t know I had. lol
I started making an extension tube for the massive TR-J20 last night, and when I got inside I realized I had taken a tangent with the emitters I have coming in and planned to do a different light with them, so I got started on the big extension with the wrong idea in mind. Now I will probably use it to make DBC-06. (I seem to be a glutton for punishment, 06 will be a lot of work)
That’s fair. I shouldn’t complain about a puddle getting my shoes wet… to someone who is up to their neck in a lake.
Hey, I just noticed you’re now selling batteries on the international version of your site
It says that the buyer assumes responsibility for confiscated packages with more than 4 batteries, does that mean that if the order has 4 batteries or less, MTN electronics will refund it if it gets confiscated?
Or is there no problem with <=4 batteries? (I’m in canada btw)
Also, when you ship the batteries, I assume that you are forced to use ground shipping, correct?
Hahaha, I’m not organized, not at all, and I got some 8 compartmentalized boxes from Justin with all sorts of bits and pieces. One is dedicated to emitters, one is all driver components, copper rounds, copper sheet, MagLite parts, and a bin box with lenses, reflectors, o-rings and 2 full boxes of standard and metric o-rings as well. Epoxy, Arctic Silver, Thermal Paste, soldering equipment, a hot air/soldering station that got me hooked on hot air guns (and then it QUIT) Even a shop sink with legs for hot dipping to get a flame design or whatever, and 2 bench top drill presses as well as a portable band saw with different blades. Stuff on top of stuff on top of all my mess of stuff.
I should take inventory some day and get it all merged and organized. I’ve got DigiKey boxes holding driver parts, maybe 5 of em, and even Flat Rate post office boxes with bits and pieces. If I ever get my Mom’s clothes folding table cleared and freed she’ll probably swoon. Yep, I’ve semi-invaded the laundry room.
Seriously, when you get to the point that you yourself realize you’re adding Insane to Mad Scientist, it’s gotten bad…
See back in the right, the stacks of clear compartment boxes? Some of the stuff from Justin…
And Mom’s surger and sewing machine? Inaccessible. My bad, really meant to clear all of it up before surgery, then the day came that I had a Dr.s appointment and he said he was booked through October, but had a cancellation tomorrow, are you ready to do this? Boom! Suddenly I was plunged into months of recovery and well, my mess is still a mess.
Yeah, bet you thought I was exaggerating about the stuff on top of stuff, huh? Gotta get on top of this….
