Yeah, thats how I read it as well. Sad it would not work for higher voltage LED’s, if it supported outputs up to 16V like the input it would be great.
The output voltage is limited to 5.5V, good catch, I didn’t see that. In that case, the MPQ8632-20 Is probably the better candidate, up to 13V output and similar in other specs. Little bit larger footprint though. The MPQ8632-12 has the same size footprint as MPQ8633B but a 12A limit (still probably enough).
Hmm, 13V is not quite enough for a 12V LED at reasonable currents but at least it would handle 6V LED’s.
Who knows maybe they have some wiggle room in the voltage tolerance and could handle ~14-14.5v, kinda like how we push everything else past the datasheets as well lol.
There are certainly plenty of high powered Boost-Buck controllers out there, but many require 4 external MOSFETs which makes space a problem. Using some super small surface mount FETs it might be possible to build something in the 30mm range. LTC3780 comes to mind here.
I’m willing to bet the MP8632 would output beyond 13V by a bit, similar to how the TPS61088 will actually max out around 13.7V instead of 12.5 like the datasheet says. We do tend to operate a lot of things outside of specs here. Haha.
Yeah, those FET’s really eat up the space which would already be tight without them. Thats what makes these chips so attractive. Plus the lack of FET’s reduces the complexity which is always good for small designs.
Maybe I can get an ATTiny13A on the MP3431 board, for biscotti-HD. To control the IC I would use the method used in the H2-C.
How about ATTiny85 for e-switch?
Though either would be lovely…
The 85 isn’t available in a package small enough to fit the underside of the board, I need 3x3mm, even 4x4mm is too big.
Which parts list for this one
I need it fot 1.4A UV LED with 4.1V forward voltage in 17mm
OK, I thought you meant the usual SOIC-8. Anyway, there are many great uses. :+1:
Though I think there are uses for 20+ mm variants with e-switch too.
Forgot that, the inductor is 1.5uH.
But I haven’t tested the circuit myself, so I just can hope it works. I will check the pinout one more time. I can recommend some Opamps, but I need the input voltage range for that. To get 1.4A, your resistor R3 should be as close to 5932.2 Ω as possible. Less resistance for less current, more resistance for more current.
I too would like to build a UV light. Looking for a boost driver for 2x26650 to get 15V 1A to LED. Doesn’t need anything except on/off.
Input is a single cell 3.7V
this 20Mhz one OK?
http://www.mouser.de/ProductDetail/Texas-Instruments/OPA322AQDBVRQ1/?qs=sGAEpiMZZMuUbyQTl9BuV63CpDOSJaNbsqa6U%2FwQSlo%3D
Yes this OpAmp will do it. Due to the 2mV maximum offset the current could be between 1.3-1.5A.
If you only want on/off you can just use one of those buck converters from AliExpress.
I use one too for my 3*26650 light with a 100W COB in front.
Those better?
https://www.mouser.co.uk/ProductDetail/Texas-Instruments/OPA365AIDBVR/?qs=sGAEpiMZZMuUbyQTl9BuV5RTXIcMxZggHHJtoxXnn3c%3D
Take the OPA365, the microchip parts seem to have a really high input offset drift when the supply voltage changes.
could you share that board?
Kinda crying out in the wilderness here, but I need a high discharge FET drive that will allow these five conditions simultaneously;
- always on momentary signaling switch,
-adjustable frequency and duty cycle strobe only,
-momentary only,
- adjustable thermal step down,
- ability to lock out programmability with
closed solder junction.
