Convoy L6... XHP70 Beast!
The budget soldering station of choice is Hobbyking’s Hakko 936 clone. $23 is hard to beat and it works great if you are not a professional.
The shipping on these lights is actually pretty fast from Simon. Mine arrived several days ago much faster than I expected. Even on just two batteries it is pretty bright. However, I ordered a short tube also thinking it would add length to the tube, but I obviously didn’t see that both ends were threaded in the picture. I saw a picture of one that was longer than normal somewhere, but there is no extension tube listed on ali. Does anyone know where to get one?
I can send you an extension tube, just cover shipping. Should be able to put it in a small bubble pack for a few bucks. BUT, not sure the original driver can handle 3 cells if you’re planning on adding an extension to the 2-cell tube, of course, there are other mods you could be doing as well, like Kawi using 4 26500’s and an XHP-35….
I’ll take you up on that deal via pm.
Yes, I will be making major changes at some point in time. I had the idea to replace the driver with a h6flex, but I will have to be super creative to make it work. It will also take some removing of metal. At this point, I am just gathering ideas and options.
Still to jump onboard and buy a Convoy L6 (I must be one of the few on here lol)
Any idea if this will be updated to come with the XHP70.2 soon (direct from Convoy)
Also is the SMO reflector a worthy upgrade for outdoor use? Is that much spill lost?
I haven’t heard anything about it being offered with a 70.2.
The reflector surface has no effect on the spill lighting since all that light does not even touch the reflector. The Smo basically tightens up the corona.
Whether it’s worth buying will be up to you. I always felt the beam was a little too wide for my tastes and would like to shrink it a little and gain some extra throw.
It’s currently the right size hot spot for me. If I were to slice the dome and get a smaller hotspot, it’d be too small and throwy. So it’s all personsal preference. The SMO is cheap enough that I would get it just to try it out.
Wow, that’s a great idea for me.
Where I can bought those kind of extension tube so the flashlight can handle 4 battery in series?
DBCUSTOM has a few extra.
It would probably be much cheaper to order extension tubes from Simon (Convoy) on AlliExpress to ship to Indonesia, shipping would be quite high from here as the USPS get’s really pricey exporting anything.
Hi guys.
My L6 seems to have died, and I can’t work out why. It’s been sat in its box for a couple of months since I last used it. I put in batteries, tried to turn it on, and nothing.
I’m not great at trouble shooting, any suggestions where to start? I’ve had the light for less than a year, and it’s probably only seen 30 minutes of actual use!
I charged the batteries before I tried to use them so no issues there. I’m using a disc with springs device I got to allow the flattop batteries to work in series.
Thanks!
Edit - I took off the tail cap and tried connecting the edge of the body to the bottom of the battery. It works! It seems the tail cap is the issue. The click is a bit spongy, but seems to be working. Can I test if the switch has failed?
Edit 2 - Broke out the continuity tester, and the tail cap switch is working
Edit 3 - I just needed to tighten the tail cap hard, and the connection is made and working. I don’t remember having the problem before. All’s well that ends well I suppose :slight_smile:
Make sure the spacer ring that fills the gap for the lanyard ring on the battery tube is tight. If it gets loose, the tail cap won’t tighten all the way.
Right, what Jason said… that spacer ring is threaded on and can be replaced by the tactical ring, the spacer is so well made that it’s easy to forget it’s actually a threaded removable part. :wink:
I don’t see any extension tube for L6 on Simon’s store.
Could you please give the link for it?
Or I need to contact Simon directly?
You’ll need to ask directly.
I see. No wonder can’t find it anywhere in his store.
Thanks for the inforrmation, Jason.
Anyhow, where’s I can find 26350 battery?
Seems this hard to find. Only seen on BG or GB, but they can’t send to me.
You can also ask him for a clear switch cover if you need it.
You might try Fasttech for 26350. In the US, Mountain Electronics has them, but I don’t know if he ships to you.
Daneel: Or if you putted on the tactical lanyard ring reverse it can touch the tailcap and you need to screw on the tailcap hard.
Received mine today. Hopefully those KeepPower will be charged by the time it gets dark! :slight_smile:
Sounds like you need an Xtar SV2 Rocket charger. 2 amp to each cell. Charges fast.
Does anyone know if Convoy is the only place to buy a new tail switch?
