I just sold a modded m3. I have two of these clones with charging on the bench ready to mod. I’ll post them for sale here first in case anyone wants one. I’m not sure yet if I can save the charging option. I am going to fight tooth and nail for it though.
Hum, guess that’s going to be a tough mod
Let us know what you’ve done, when you’ve done it
Oh boy…this UI… :person_facepalming:
From the video, on the stepless dimming, it doesn’t appear to go down to low lumen levels, does it? How low does it go, if you have an estimation?
Thanks :+1:
I took apart the clone today. I ended up relying on an aluminum rod and a hammer two sizes larger than the one I started with. It deformed the brass ring some and broke a couple solder joints, but the brass can be reformed to shape and after some extra solder on the broken connections the driver still works. I’m quite surprised though, I gave it some pretty good pounding.
My end goal does not include the original driver circuit, but I’m hanging on to the charging circuit. The charger used is labeled, HXN-MH. The charge port is remotely mounted directly to the pill with a rather heafty screw. I believe the rest of the charge circuit is contained on the back of the vertically mounted switchboard. After some digging through my parts bins the good news is that I believe I can mod it with a triple channel board running Narsil and retain the charging function. The bad news is, it is NOT going to be easy.
For anyone wants to open their’s up, the reflector is not screwed in like the m3 but be prepared for a fight to get the pill out of the head! I would recommend pounding using something solid that fits tightly in the battery tube with minimal wiggle. If you need to pound with a punch or screw driver try to avoid both the end with the switch and the side with the charge port. focus on the part of the pill on either side between the two as this is where the brass touches the aluminum of the pill. Pounding the other areas will result in deforming the brass ring and possibly loosening parts on the driver. Also, I would remove the charge port cover ahead of time. I ended up shearing off the tab that keeps the cover from completely coming off when charging. With the tab gone it will be more easily lost. I have a solution in mind though.
I would have posted picks but my camera/phone quit on me. So I’m out my lifeline till I can figure that out.
Oh yes, emitter swaps should be doable. Only trouble is that the mcpcb is glued to the pill. I scraped around the edges with an exacto knife and still had to twist pretty hard with my needle nose pliers. I’m not sure what emitter is going in this one but I am sure it’s going to be nice!
Thanks jon_slider for the information on the On The Road M3 :+1:
Despite the different “appreciations”/measurements, it is a really great light!
However, I was asking about the levels of the Jaxmnve M3 (aka, “the clone” ) as from freeme ’s video about the UI it is possible to see that it goes to low levels, but doesn’t seem to go to moonlight levels.
I may be wrong, but it doesn’t seem to go that down! I already have one on the way, so it won’t weight on the decision, it is just to be aware what I (or other buyers) can wait !!
Yes, you are correct. It doesn’t go as low as many would like. The lowest level is maybe 40lm? That is a very crude guess only from memory and not by direct comparison. But it’s definaltely not a moon mode and more like a moderate low mode.
Thanks for the answer LightRider!! Well…that is not what I expected when I saw stepless dimming, but ok, we’ll survive this UI
It will always be a nice BUDGET light as long as it works well in the modes it has, once that modding it is not an easy option, as you and TomE said!
Eheheh, at least it is funny :partying_face:
Maybe - I’m just saying - maybe the manufacturers would be open to use one of the mentioned firmwares, Narsil, NarsilM, others, if we “advise” them to do that!
Do you think this was a good option, or was it desirable? If these firmwares are open source, it would be interesting to get to these manufacturers and tell them about it.
I don’t have much experience contacting manufacturers. Sofirn and Amutorch are just 2 of them to whom I provided some feedback on the flashlights I bought (through AliExpress).
- Sofirn - represented on BLF by Tracy Wan - incorporated some feedbacks given here about their AA lights (were from H to ML, now are L to H, and strobes were “dismissed”).
Amutorch contact, despite didn’t make the changes (yet?) took the given suggestions to their responsibles.
This Jaxmnve manufacturer already uses a “ramping UI” (+ clicks). Maybe they are open to make some changes on their drivers and UIs and make a more “nice” light.
I’m just saying! Sorry if I completely ignore how things can happen on this manufacturing world, as I have no experience on that :person_facepalming:
As a user, I would just like to have the best flashlights possible, keeping the budget side on it! :money_mouth_face:
BLF firmware, whilst wonderful, is not the be-all and end-all.
Neither are simple FET drivers, necessarily.
And is predicated on relatively expensive MCUs.
And is an acquired taste, maybe more than many will ever want, or use fully.
Plenty of good stuff being done commercially with much more humble stuff, E.g. I have a huge 4D cell “10W Cree LED” torch that cost £12 (reduced) from Lidl/Aldi last year, with simple high, low, then for more control a great ramping UI, up and down, flicker at each limit, hidden strobe, perfect.
All good, genuine Cree XML LED in good neutral white tint, driven well, good reflector, the metalwork alone weighs over 700g, when loaded with included x4 Ds (a few quid themselves), 1.3 kilos. Fit, finish, o-rings, anodisation quality, all great.
Bought it having a project for the chassis in mind, but so good I never bothered. Perfect for walking the dog, or investigating “bumps in the night”.
The driver is pretty simple. However it looks like there are some things hurting the efficiency. Idk?
The driver uses two large limiting resistors that have a total resistance of 1.32 Ω.
It is interesting that the driver uses the same fet for reverse polarity protecton and for the output mosfet. So the current travels through an fet twice before it reaches the led. I believe this is less efficient than using a diode for the MCU only like the BLF drivers do?
However the reverse polarity protects both the driver and her charging circuit. So after the rpp mosfet the batt- is isolated from the rest of the driver. The only other part connected to the host is the switch.
All of the charging circuit is contained on the vertical switch pcb apart from the rpp fet. I am unsure if the charging uv has rpp or not. I’m assuming not.
The charger has a program resistor of 1.5k Ω. This should give a charge current of .66 amps. This is assuming that the charging ic closely resembles the MCP73831/2 as I couldn’t find a data sheet for the HXN-MH. Someone somewhere mentioned a connection but I’m not sure. The pin layout seems a little different so there might not be any relation st all. Idk?
