The differnce from 9 to 12 klumens is visible with the eye when you ceiling bounce
but in use its as bright as the Nichia has about the same lux number because of the smaller LED die size
So the Nichias beam is tighter
The tint of the LEDs in my Nichia is very nice pure white
Also the Nichia has almost no visible tint shift within the beam
Personally I prefer less lumens if the deal / trade off is for better colors rendition, no hesitation, not even once !
I’m still using a flashlight that outputs 100 lumens in the highest mode and never found a rival to its particular beam and color rendition = high CRI seoul P4.
For outdoor activities, high CRI is a necessity for me. Less lumens but better lumens.
I hope they are using the same Nichias, second round, because that is what I just ordered. No question in my mind, as to which I prefer. But there also some sad Nichias, the ones in my first batch S41 were very disappointing to me. Maybe I need new ’specs.
Basically, with the XP-G3 the light is going to have the cool white “LED look”. Most everyone will assume the light is from an LED source, without even seeing it. However, with the Nichias the light looks more traditional, as if from a “million+ candlepower”-style halogen spotlight. If you were to have it on, those who would not know better might expect to see a few glass bulbs in the light head, whenever you turned it off.
From the few that have splurged and bought both versions, most have said that while the XP-G3 was indeed visually brighter than the 219C, it wasn’t really that big of a difference.
I have ordered both variants and kept the Nichias. My thinking - I coudn’t see much difference in quantity of light side by side. Anyway in both cases the light is very bright at max level, but that lasts for a while, while the quality (High CRI) of the Nichias is present also on the lower levels. I also have Q8, so decided to go with high CRI on this one. Anyway tough to choose, I like both variants.
I would advise by the same lamp with two different LEDs. Sell the unwanted.
I tried that out with the Lumintop IYP365.
The Cree is 200lm
The Nichia 219B is 140lm but CRI 90, around 4000K.
I carried both a week and used it both every time. After two days I knew I want Nichia high CRI and don’t care about less lumen in real live.
It was important to use the lights, based only on 5 minutes playing it would have been the Cree.
With a coupon you should get the IYP365 for arround $12 each. Ask M4dm4x
That lamp makes also a nice gift for relatives if you won’t sell it.
You had to do that once to know if you are for lumen or nice tint.
Same lamp, same optic to keep other factors out.
You get also a clue if you’re more NW or CW.
ahhh so you got both and the output difference is small? I just ordered the Nichia version and it’s on my way! And if I really like this light maybe I’ll see if they have any specials on the coming Holidays (Black friday, Christmas, New years/ Chinese New years etc.) Then get the XP-G3 version
Tempted on getting this light, but I’m a bit apprehensive as to the 2S2P setup (Capacity and Voltage). Besides the danger of inserting batteries in the wrong polarity, what other dangers could potentially exist from this configuration using non protected cells? I’m aware that a 4p setup (Capacity) is generally safer using non protected cells, but so far all of my lights use 2s and 3s configs and they all run protected cells.
the production lights have modified battery carrier to allow protected calls and handle reverse protection with plastic discs
4P battery carrier is even worse if you insert one battery reversed while 3 normal are already in it
Mixing full and empty cells in 4P also leads to bad things to happen, while in 2S/2P you wont ever reach reverse charging like in 4S possible, just if you over discharge a cell recycle it
Ok. Thank you for the information. I’ll most likely get this light sometime soon. I have some friends who are afraid of flashlights that use Li-Ion cells because of the bad rep of exploding. I tend to think the technology is generally safe, so long as you know what you are doing, and respect the tech. Safety first!
Seen the Nichia measured from as little as 8000 lumens, my XP-G3 MF-01 measured around 10,500 lumens, but it appears brighter as there’s not much spill. Just a big wide hotspot.
It seems that banggood is selling the LED’s MCPCB separately for 30$ but the picture is showing the spring side of the driver.
Is it a sign that BG is also going to sell the (lastest) TA’s driver ?
Wut the? They must have shlapped something up quick for someone... Probably to appease someone that had a defective LED and/or MCPCB. Can't imagine them charging $30 for a driver, but they could have provided a coupon code to a customer.. Strange though.
they are violating the open source license for sure
And this is my edited SRK design and noone asked me about it
even worse that design is so old that its missing also the ground only coming from one source so noise on LDO is reduced and it does not freak out
additional caps missing stabilising the Batt voltage
AMCs dropped for small FET and resistors
and they even do not tell if it fits V1 or V2 of the driver
but seriously a MCPCB for 30$ that you already got, no other optic will fit, so it is kind of pointless
still the question is why a BG employee has my driver picture from Oshpark
