CRX Stratis Lumina - 2017 5th BLF Scratch Made Light Contest Winner
171 posts / 0 new
Persechini
Persechini's picture
Last seen: 6 months 1 week ago
I don’t quite get it, but it’s beautiful!
In my Tree
My collectionEmisar: D4 / D1 / D4 (broken) ― Convoy: C8 Clear / S2+ Clear / S2+ / S2+ UV / S6 ― Nitecore: Tube / Thumb / Concept 1 / HC30 / HC33 / TIP / TIP CRI / TINI ― Lumintop: Tool AAA / Tool AA / HLAAA / EDC05 ― Sofirn: SF10 / SF12 / SF12 / SF14 / SF14 / SF14 / SP10A / SP10A (gifted) ― Jaxman: E3 ― UTorch: UT01 ― Trustfire: Z2 ― Skyfire: SF-065 (trashed)
MRsDNF
MRsDNF's picture
Last seen: 19 hours 4 min ago
Persechini wrote:
I don’t quite get it, but it beautiful!
You have many friends in the same boat. Party
CRX
CRX's picture
Last seen: 16 min 39 sec ago
Hey guys, a bit more magic done on this today Wink
First I rounded off the front plate window as good as I could get it by hand then sanded and polished the front & back copper face plates. Note to self - Don't mark the lines so deep next time Facepalm Tired
Next up I had to take 0.5mm off the bottom of the quad MCPCB and optic legs so they fit under the glass nice n snug when assembled. I used 600 grit wet & dry silicone carbide sandpaper to first sand down the board using an old optic on top, continually checking the depth in the light. Once I was happy with that I put the optic I will be using into the MCPCB and gently sanded down the protruding legs then finally flipped the sandpaper over, put on some metal polish and shined it up some.
I got the switches installed and the wiring in place for the quad and UV array. I measured out the position for the quad then flowed the emitters & jumpers onto the board using a butane jet lighter and long nosed pliers to hold the board while heating then fixed in place, soldered the wires & gave it a quick test Thumbs Up
I then wired up the UV array which is potted now with cyan GITD tape on top, although it is not fixed in place yet and gave all systems a preliminary test Thumbs Up
Today's Tune:
- LEDs & Other Stuff -  - UI CheatSheets -  - CRX Mods & Builds -  - Stuff for Sale -CRX Hand Made FlashlightsThe only place that fear can exist is in our thoughts of the future.
It is a product of our imagination causing us to fear things that do not presently and may never exist. Fear is a choice.
MtnDon
MtnDon's picture
Last seen: 34 min 9 sec ago
Cool!! Thumbs Up A lot going on in a small package
MRsDNF
MRsDNF's picture
I agree Don. There would be no hope at all of me making something like this work. My thumbs are to big. Smile
FmC
FmC's picture
Last seen: 3 weeks 4 days ago
That is one crazy little light-maker! Thumbs Up
The build, that is, not the builder… maybe both?? I don’t know… Wink Facepalm
CRX
CRX's picture
Both for sure Big Smile
CRX
CRX's picture
Got the 34mm x 2mm ARC front glass installed with some B7000 glue and attached the front and back plates with felt and kapton tape in the appropriate places on the covers.
Still waiting on some brass screws and have some sanding & tidying up to do but we're getting closer now Smile
The bottom centre picture shows the lights next to a credit sized card.
Today's Tune:
Agro
Agro's picture
Last seen: 1 min 50 sec ago
If you submit both lights to the competition, I’ll vote for the smaller. Cuuuute! Smile
MRsDNF
MRsDNF's picture
If anyone wants to be dazzled open the images up in new tabs and have a look at them in their original size. The finish and detail is amazing especially for the size of these lights. The whole build is simply orsm from start to finish. Well done CRX. Smile
MtnDon
MtnDon's picture
More than awesome!! It is a craftsmans superb effort. Amazing work. Sigh… Wink
-X3-
-X3-'s picture
Last seen: 4 hours 36 min ago
Well done mate ! Truly a piece of art, as always !
I love the tiny one, but the bigger one is such intricate design that I would vote for it !
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
FmC
FmC's picture
Man, that’s really shiny…. I’d be happy if Jack can polish mine up half that good Cool
CRX
CRX's picture
Thanks very much for your comments Beer
The M2 brass screws came in today so might get them installed later
CRX
CRX's picture
I figured the SL needed a protective/ carry case for clipping to a belt etc or be able to hang from a neck chain so I made this today from an old leather wallet I had.
I cut the leather to size and hand stitched the sides with 0.25mm dyneema line.
There is a kydex backing which I tapped for the M3 clip bolts and I used an old clear plastic aftershave package covering to stick on the inside with 3M double sided tape for the window so the light can be operational while carried but also help protect the glass of the light. There are felt strips to protect the finish from scratches.
The kydex and plastic help to add rigidity to the thin leather.
The light slides very snug in the case as I had the leather turned inside out and stitched with the light inside then reversed, the clip is from a Kershaw knife, due to the design of the clip it looks off centre but is central where a belt would be.
Showing the light working on low mode inside the leather pouch.
Using the neck chain.
Any Iron Man fans here?  Big Smile
Couldn't help myself putting the light inside my t-shirt there LOL  Facepalm
It's a bit rough but I am quite happy with how it turned out  Smile
MascaratumB
MascaratumB's picture
Last seen: 11 min 40 sec ago
That is sweet Shocked
Awesome job CRX!! Is it already complete ? Party
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
CRX
CRX's picture
Thanks mate, not quite finished yet. I got the brass screws fixed in to the copper plates yesterday, took ages countersinking them to the correct depth as I had to keep removing and replacing them individually to get it right without making too much of a mess of it.
Today I got the electronics potted, arctic thermal grease and sealant applied with a piece of diffuser film over the optic.
All I have left to do is sand around the edges and polish it up... again... Smile Will post pictures of that later Thumbs Up
MascaratumB
CRX wrote:
I got the brass screws fixed in to the copper plates yesterday, took ages countersinking them to the correct depth as I had to keep removing and replacing them individually to get it right without making a mess of it.
This was the reason why I asked, I saw the picture before and thought that they were probably missing somewhere! And I imagine how hard that might have been Facepalm
But, it’s almost done, and it surely is a really gorgeous flashlight Thumbs Up
Hopefully we’ll see it soon! Keep it up, Iron Man Big Smile
OL Contest 2019
GIVEAWAY: 1 / 2
CRX
CRX's picture
Big Smile
MtnDon
MtnDon's picture
Looking great!!
MRsDNF
MRsDNF's picture
lawallac
lawallac's picture
Last seen: 9 hours 59 min ago
CRX wrote:
Got the front glass installed with some B7000 glue and attached the front and back plates
Very cool love the copper, GITD, and UV to charge it up. This light screams keeping it away from airport security.
CRX
CRX's picture
I used some ferric chloride to etch in my username on the back of the light today.
I marked out the letter spacing then using a black pentel marker and tape created the letters.
The etching process took about one hour whereby I applied new fluid and agitated every ten minutes.
This has left a fairly shallow subtle etch which doesn't stand out too much Thumbs Up
Today's Tune:
MtnDon
MtnDon's picture
Very cool!
CRX
CRX's picture
Thanks mate. It was a bit of a scary decision choosing to go ahead with it as I haven’t really done this before but it should look good when it’s polished up some more Thumbs Up
Ronin42
Ronin42's picture
Last seen: 6 months 3 weeks ago
Show us the mini build?
Its what
zippo sized?
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
CRX
CRX's picture
Yeah, about that size.
Did you miss it on page 3 Wink
MtnDon
MtnDon's picture
Cute!!!
MRsDNF
MRsDNF's picture
I like it a lot better when its undressed. Smile
Tally-ho
Tally-ho's picture
Last seen: 2 months 46 sec ago
I already noticed your attention to details, here all 8 screws are “aligned” symmetrically at 45°. Wink
