I can send you an extension tube, just cover shipping. Should be able to put it in a small bubble pack for a few bucks. BUT, not sure the original driver can handle 3 cells if you’re planning on adding an extension to the 2-cell tube, of course, there are other mods you could be doing as well, like Kawi using 4 26500’s and an XHP-35….
Yes, I will be making major changes at some point in time. I had the idea to replace the driver with a h6flex, but I will have to be super creative to make it work. It will also take some removing of metal. At this point, I am just gathering ideas and options.
I haven’t heard anything about it being offered with a 70.2.
The reflector surface has no effect on the spill lighting since all that light does not even touch the reflector. The Smo basically tightens up the corona.
Whether it’s worth buying will be up to you. I always felt the beam was a little too wide for my tastes and would like to shrink it a little and gain some extra throw.
It’s currently the right size hot spot for me. If I were to slice the dome and get a smaller hotspot, it’d be too small and throwy. So it’s all personsal preference. The SMO is cheap enough that I would get it just to try it out.
It would probably be much cheaper to order extension tubes from Simon (Convoy) on AlliExpress to ship to Indonesia, shipping would be quite high from here as the USPS get’s really pricey exporting anything.
My L6 seems to have died, and I can’t work out why. It’s been sat in its box for a couple of months since I last used it. I put in batteries, tried to turn it on, and nothing.
I’m not great at trouble shooting, any suggestions where to start? I’ve had the light for less than a year, and it’s probably only seen 30 minutes of actual use!
I charged the batteries before I tried to use them so no issues there. I’m using a disc with springs device I got to allow the flattop batteries to work in series.
Thanks!
Edit - I took off the tail cap and tried connecting the edge of the body to the bottom of the battery. It works! It seems the tail cap is the issue. The click is a bit spongy, but seems to be working. Can I test if the switch has failed?
Edit 2 - Broke out the continuity tester, and the tail cap switch is working
Edit 3 - I just needed to tighten the tail cap hard, and the connection is made and working. I don’t remember having the problem before. All’s well that ends well I suppose
Make sure the spacer ring that fills the gap for the lanyard ring on the battery tube is tight. If it gets loose, the tail cap won’t tighten all the way.
Right, what Jason said… that spacer ring is threaded on and can be replaced by the tactical ring, the spacer is so well made that it’s easy to forget it’s actually a threaded removable part.
None of my chargers can supply more than 1A per channel (Nitecore i4, Xtar VC4 & Liitokala Lii-202), so I’ve been looking at MiBoxer’s range. But I’m pretty impressed with my Xtar, so it seems that I’ll need to give their rocket charger some consideration. I’ve got several lights that take 4 18650 cells though, so I might be better off getting a 4-bay charger. (or both?)
Currently got my 26650s in the Lii-202 hooked up to a 2.4A USB charger (Orico 4-port), so it should be charging with 1A per channel. But my (cheap) USB meter is only showing me a current that is varying between about 0.5 and 0.7A, and the light for 0.5A charging is lit up on the charger … I can see myself ordering a YZXstudio meter soon, so I know I’m getting accurate readings. And then I’ll need to find a multi-port USB charger that actually supplies what it promises!
I bought a Rocket especially to charge my L6 batteries. I actually bought 2 at $18 each since I have other lights that use 26650 as well.
The new I4 charger only does 0.375A x 4.
The VC4 charger only does 0.5A x 4. I have my VC4 hooked up to a good tablet usb charger rated at over 2A. Sometimes it seems the connection is not good and I’ll see the charge rate on the charger drop down a little. That’s worrysome. I’m going to avoid usb chargers from now on.
Have you looked at the lii-500 charger? It does 1A x 4. Thats pretty good.
I am on the lookout for a 4 bay charger that can do 1.5 amps each for 18650. That’s about the most a good 18650 can do. I’ve looked a little, but haven’t seen one yet.
