It was 3P-2S3P, so 6V for the two leds in series, with 8.4V input voltage.
Now they’re saying they’re changing to 3P6S? You need a different (boost) driver or not?
How uneven does it need to be in order to qualify for a replacement? I do love my MF-01 and will be ordering a second one in the next few days, and the differences between the brightness levels aren’t as pronounced as what I’ve seen with some others. But the problem seems to have got slightly worse over time, and I’m worried that this fault might turn into something more severe, especially as I like using my lights as candles.
Since I’ll be having a backup fairly soon, I don’t mind sending back the head for one that works correctly. What should I do - get in touch with BG CS?
I’m trying to figure out the same thing. I would have already sent mine back if I’d had been asked. At this rate, it’ll be mid-November or even December before this is resolved. :person_facepalming:
2017-10-11 20:30:21
Status:Item in transit
Then over to Royal Mail:
Track and Trace - Track your Item
We’re expecting it
Tracking no. xxx
The sender has let us know this item will be with us soon.
Royal Mail Tracked 48™
Updated on: Wednesday 11 October
09:08am
Item expected
So it looks like Banggood shipped from their EU (UK) warehouse, I might even get it in a couple of days
If indeed changed to banks of 6 LEDS in series, with a boost converter (or one converter per bank), that could be very interesting.
If well regulated it could be superior to the existing buck converters (running 2S LEDs from 2S cells), once battery voltage drops. Less loss in LED wiring and MCPCB traces too.
If it was down to me, I’d also arrange one bank to be the inner circle of 6 LEDs, and switch off the other two banks at lower levels. That would eliminate problems of uneven illumination of banks, and allow finer control of lower light levels.
Fingers crossed for something along these lines, rather than just a minor tweak. Should soon know.
Guess mine counts as extremely ‘uneven brightness’ - one bank always 100%, can’t be turned off at all (have to unscrew the tail or head).
By the way, Chinese holidays ended already? because I still don’t have any response from BG. And after that, it will be waiting for the light to be shipped back, then shipped again to me…
disappointing a little.
Just so everyone is aware Banggood can not ship batteries to the US for some unknown amount of time due to a battery related fire at the Hong Kong airport. They are issuing refunds if you placed an order for batteries. Same with most batteries at Gearbest.
That is to be expected from Banggood page. Mine still shows “not found” there. This is normal behaviour for Banggood. IME. Usually nothing ever shows there until I have actually received the item.
You have to take the tracking number from BG and paste it into e.g. E404 to get results.
