I’ve got some 70 vs 70.2 in an L6 with SMO comparison pictures here.
If you look at the darker shots you can see the improved beam pattern of the 70.2. The dark hole is much reduced. When viewed at normal brightness levels the 70.2 appears very smooth. I got 830 meters on my light and I know my numbers are a bit lower than average.
My MT07S stopped working after one day.
Work dwo modes, in one flicker, I can not turn off the flashlight.
The flashlight (the reflector) probably I see smoke rising.
Hey how are you man? No I’m not from Haikelite, hehe. From what I know, the MT07S is 4S (4 cells in series), so you do need all four cells for the light to work. This is not the case with the larger MT07 which can operate with just two cells.
Both Banggood and Gearbest have a DOA (dead on arrival) warranty. Within three days for Banggood and seven days for Gearbest (IIRC), if you report a defect, then you don’t have to pay for shipping to China. So it’s best to upload video to Youtube and report problem within this period.
Got it, mine is NW, very impressive and brighter than my RC40 3500lm. 4500lumens heat up whole light fast even the batt tube. I took battery out and batteries are not as warm though.
I used small magnet to make contact. Don’t feel like to remove the +ve batt plastic yet.
My guess was it’s XHP35 HI, stating it’s 3000 lumens just like Astrolux stating MF02 is 3000 lumens. I’m interested in actual throw figure, as 1200 m is probably not the case.
Yeah I think your right. A sliced xhp50 or 70 would show the seperating lines between the dies. A sliced 50.2 or 70.2 would still have the yellow around the edges. It must be a XHP35-HI.
The original MT07S is a pretty impressive light with huge output. It also throws incredibly well considering the relatively small diameter and overall size/weight of the light. An XHP35 HI variant must result in amazing lux value… (but not 360k lux I think…).
I don’t have K40M to compare side by side, but my MT07S NW measured around 70kcd. I think it out throw K40M by around 10% comparing to online review of K40M.
