will do.
yeah the light had potential on paper, nice boost driver with 3S input
The thickness of the shelf is not too bad, the LED should have on no serious problem on a non DTP copper star @2.54A
but without heat path to body good it wopuld probably kill the LED, which has a good light color at lest
but they definitely need to learn how to machine a part that gets press fit, so that the shelf outside has a small rim where it is a bit thinner than the body, and then the rest of it is a bit bigger than the body, so the “hollow” part of the shelf tube gets compressed
I am going to order a 20mm Sinkpad-II for XHP 50
http://www.leddna.com/pre-order-sinkpad-xhp50-21mm-copper-12v-or-6v/
I have gotten 3 Sofirn lights to review, the first was a big showerhead and while it didn’t meet output claims it is a decent robust light.
The 26650 SP33 is a really nice light, I like it a lot. Well built with nice features it does what they say and is very reminiscent of a Thorfire light. Side switch with the partially covered lit button, like the Thrunite TN42. Beam is a big hot spot with small aura and nice spill, this light is well done no matter who’s name is associated with it. It’s directly comparable to the Lumintop SD26, which I bought not too long ago, and for the price difference the Sofirn probably wins but the Lumintop is a more svelte light overall.
The third is a little AA light with a warm white emitter, it’s nice and works fine but it is way too warm for my taste. This is the SF31, a tube light with fins at the shelf area. It’s regulated output and you see a slight delay when shifting modes, smooth in use and likeable as an EDC, it has 4 modes with a very decent moon. I swapped out the LED to a whiter XP-L2 1D and the beam is much more to my liking. This small reflector light has a very mild orange peel, transition between hot spot and aura/spill is softer, less defined.
The only one of the three that seemed not well thought out is the big shower head SF22. Finish is a nice matte black and the 18 emitters actually do a pretty nice job, it just didn’t make the claimed output out of the box. A bit of work and it’s functioning at a pretty nice level. I’m using it with 2 cells instead of 4.
Just ordered the new C8F triple XP-G3 today, so we’ll see how that goes. I’m betting it’ll be sweet with the emitters swapped out for XP-L2 1D’s.
The 20mm SinkPAD for XM-L works perfectly for the XHP-50, same footprint. There are large diameter Maxtoch MCPCB’s in DTP copper that are made for the XM-L footprint as well, one of those may work best by covering the entire emitter shelf in that light. Of course, 20mm Noctigon’s for XM also work.
That “press fit” emitter shelf may not have had a fit side to side, but the aluminum shelf was still sitting on the aluminum body so heat transfer was still taking place even if not optimal. There are simple fixes for that, all P60 modders know how to take care of that problem really quickly.
I just (last week) ordered SF10 and SF12, both AA lights, hope they turn up nice, I like WW tints 3500-4000K is nice
that is the problem here
The shelf sits on the driver, which is not a MCPCB
I checked the current with 2.45A, but you are right its a 6V board, not a 12V,
so the claimed lumens cant be reached even with a J4 bin and 12% losses they are
they not even driving the LED to its rated current
Topped-off 30Q right out of the charger, lit up a tree outside like it was on fire, almost like that NKVD comic.
SP10A, really nice and EDCable, even for me, and I’m not really a fan of eswitch-only lights.
In your video, you show the emitter shelf as a cup, with the sides being well below the shelf the emitter sits on. You also show bare aluminum inside the battery tube which holds this cup, so the emitter shelf/heat sink is in fact in contact with the bare metal of the battery tube thus heat sinking the emitter through contact. No? Did I see your video wrong?
That sucks! Maybe install copper tape and a small amount of Arctic Silver 5 around the base to help transfer the heat tot he body…
Review ongoing
The shelf rests on the driver!
worst case is when the bezel gets tightened the shelf has almost no contact to the body
Where did you check the 2.45 A current - at cell or at LED?
Lexel, I dont get it, you talk about press fit and using a tool and force to get it out but then it rattles and drops out…huh?
Does this mean that BEFORE yu used the tool and applied force it was firmly in, thus not floating, thus giving a good heatpath to the housing? And if it was floating why the need of using the tool and force?
puzzling, for the topic title make it seem like there is no heat path and just a floating thingy, but why why the tool and force and speaking of “hammered in there with a lotof force, hard to pull it out”?
The Miller, I had to watch the video several times until I understood that he used this tool with the Klarus flashlight and not with the Sofirn.
Ah hahaha that makes sense
Fairly easy to understand the pill is press/friction fit inside the housing it has no way of attaching to the body. It does not screw in place or is not glued down. It is held in place by the force of the reflector and bezel!
Yes there is a lip/shelf around the pill that may touch the light in some areas. But if it fits in so easy and is so easy to pull out how good is it connecting to the body? How much contact area do you have? Like it can rattle around in the light and not make proper contact. Even with that lip its still a fairly small area of contact to the body when it is actually making proper contact? Could be a gap of a hundred of a mm around the pill to the body?
I have similiar built lights with the same design they dont have much of a heat path.
This light is a fairly under driven headlamp compared to the XHP50 that is in the Sofirn which is meant to be running at 30w
Ah! I see, the video didn’t show the driver installed so it was unclear the relationship.
Yes, I too wondered about the talk of the heavily indented wood as to how difficult it was to pull the emitter shelf/heat sink. Misleading a bit there, placing the wood on top of this light and explaining it.
Of course it would be easy to foil wrap it and reinstall, but the factory should have a proper fitment not requiring intervention. I’ll ask Tracy about it, see what she says…
The inside of the battery-tube (where the shelf-cup sits) might be slightly cone-shaped, and ideally the shelf-cup too. In this case there could be good thermal contact when pressed in by the reflector (and the shelf-cup would be lose and rattle if not pressed in). Perhaps SOFIRN uses this construction. Can the shelf be moved sideways when pressed down by hand?
I asked Tracy to check into the matter, we’ll see if her engineers give an adequate explanation…
Is it just me? Why do they make a nice metal pad on the driver where the screw holds it down and then NOT use a panhead screw? Wouldn’t a brass pan head make much more contact and carry better ground current? Most lights are this way, how do the engineers miss that important little detail?
