Donāt think so, they are clearly visible in the large image. It does look like a head and the threads like retaining ring threads for a driver. Then I suspect the ring actually goes on the other end, to hold the optic, not as pictured. But the replacement head theory was brought up before and not acknowledged so we must be missing something.
That is amazing. Is onboard charging still supported with that setup?
And I need to fix the heat transfer with mine. It remains distressingly cool to the touch even on turbo, which I think just means the inside is broiling itself. That foil looks like a good idea.
Q8 parts progress:
Extended height positive driver rings - will be ready soon.
1.5mm thick brass tail board - machining will be ready in a month. Searching proper way for some coating that will protect board from extra solder and specify place where springs should be placed. No simple ways to do this.
12x led kit - does anyone need it when MF-01 is available? - aluminium sample #1 will be ready soon, aluminium sample #2 in work, thinking about copper version, thinking about optics holder (upper part) coating, trit slots etc.
A 12x mcpcb? Thatād be great if it only requires one pair of wires, and if itās direct thermal path like Noctigon mcpcbās. Obviously copper is preferred, but Iād be okay with aluminum if itās thick and direct thermal path.
No, just regular 4x 3xp boards.
Hank wants $18 for one bare m43 pcb, boost driver could probably cost $30 and this two parts would make Q8 mod too expensive.
In my opinion, four single-die leds is little less than 4x high-drain cells with Q8 driver can feed. So my kit (if it will be ever made) will be defenetly made to use with stock driver.
Any ideas?
I can try to order most cheap thin fr4 boards (same size as tail pcb but with holes at spring base places), so customer would be able to use it as pattern while soldering springs. But this will increase cost by few $.
Another way, I will make a more solid template to be able to solder springs myself. But I still dont see proper source to order them.
Yeah, it would certainly be a nice mod but it will still be a fairly expensive one once everything is added up (MCPCBs, LEDs, your parts, optics). I would not go for copper as the Q8 is already quite heavy but perhaps others would.
No use for a tail PCB as Iāve bypassed it directly to the tube. So itās only a spring holder now with no electrical purpose.
I have made very limited quantity of M1 quad sets. 15 or 20pcs. They were made to fit Khatod optics because some members wanted to test it and I had to choose one host for it. All were sold in the beginning of this year. This is very unpopular mod, sorry, Im not going to make them anymore.
I could probably found some suitable spacer in my stocks, but main part (in difference with Daleās mods) of my quad kit is ring that holds optics (and allows to make spacer shorter and shelf surface smoother). Now I even dont have material to make it (ring).
The only thing I can offer - I still have several M2 kits and various VG10 kits (all for Carclo optics).
