REVIEW Acebeam L16 + FR30 Diffuser
8 posts / 0 new
Anthon
Last seen: 1 hour 14 min ago
This is my review for the Acebeam L16 tactical flashlight, which was bought by myself and for myself without any compensation from manufacturer.
INFO of the light here = http://www.acebeam.com/l16
I consider myself a fan of Acebeam products, I’ve had many models like K40M, EC50 Gen II, EC35 and willing to buy the new K30 in sand and 5000k.
I wanted to buy a tactical flashlight with XHP35 led, rear forward switch, more than 400m throw and 1500+ lumens. After looking at all the options (Klarus XT12GT, Armytek Predator Pro XHP35) I decided on the Acebeam L16 because of:
-More than 1500 lumens and without quick stepdowns
-600m throw while opening more degrees in the spill than Armytek Predator Pro
-Built in fast micro USB charging
-Rear forward click that only runs turbo
The specs looks promising, let’s see the reality
The Acebeam L16 comes in a strong discrete cardboard box, well protected with foam inside.
It brings some accesories such as:
-Spare orings
-Spare rear switch boot
-Micro USB cable
-Lanyard
-Nice nylon holster, molle compatible
-High drain 3100mAh 18650 cell, with PCB protection (I’m told it’s a Sony VTC6 cell)
-Manual
-Warranty Card
The light looks very well made, good quality semi matte anodization, knurling is kind of aggressive and it’s very grippy, it feels very confortable and solid in hand, like a “premium” flashlight should. It has a pocket clip already clipped in the tube.
At the end of thee light there is a cigar grip, with helps the use of the real switch, lanyard attaches to it. It’s removable by unscrewing it
The tailcap has a forward switch, with momentary on function, tailstanding isn’t posible in this light
The XHP35 HI led sits perfectly centered at the bottom of the very smooth deep reflector that makes a very bright beam
Lens is AR coated
The flashlight isn’t glued, so let’s see the different parts
The threads of the tailcap end are square and deep, but not anodized, this is also needed for the rear switch. The threads of the head end are triangular and anodized.
The light has a very fast built-in micro USB charging, it can’t charge 2xRCR123, only 1×18650.
I’ve measured the charging current at 1.96A, which should charge the included cell in around an hour and a half. Once the charging ends, the cell was at 4.20v.
Unlike other manufacturers, this light doesn’t require propietary cells, so you can charge any cell inside and also charge the included cell in a external charger.
The light has a led that will light red when charging and green when finished. This led is light enough to see it easily, this has been improved from other older models like EC50
I’ve measured the standby current at 103.6uA, which seems a litlle high, but it’s more than 3 years to discharge the included 3000mAh cell
UI
Let’s talk about the UI
The rear forward button will only run the light on Turbo, it has momentary on function. If you are in low mode an the press the rear switch, it will go to turbo, and when you press again the rear switch it will turn off. I don’t really like this, as the light should have some kind of memory and go back to the mode you was using before pressing the tailcap switch instead of turning off.
The side swich controls all the modes, and the UI is a well known from Acebeam and Olight users.
From off:
-Long click: moonlight
-Long click for more than 3s: electronic lockout, you’ll have to click again for more than 3s to exit lockout mode
-Single click: last used mode with memory. It will remember moonlight mode but not turbo
-Double click: Turbo
-Triple click: Strobe
From On:
-Single click: Turn Off
-Long click: The light will cycle through modes, it won’t start from the lowest mode every time you long click, it will go up from the level you are in that moment
Measurements
I’ve measured this lumens, current and throw from a fully charged cell
Runtimes
The light stepdowns from turbo to 800lm when it reaches 67º in the head. It won’t stepdown from High (1000lm) so temperatures are high, I’ve seen the head reach +75º
The provided protected cell shuts down the flashlight at 3v, but if you use a non protected cell it will discharge to 2.75v so runtimes will be longer.
Beamshots:
I’ve also bought the Acebeam’s FR30 white diffuser.
It comes in a cardboard box similar to the flashlight’s one.
The black ring it’s made of aluminium, and the white translucent lens is made of glass. It screws onto the front bezel, it suits the flashlight perfectly.
After screwing it, the beam fully changes, totally flood as it’s impossible to see any hotspot, all the light is diffussed from your feet. It’s very confortable if you use the light for walking, but it won’t reach much distance.
Diffuser OFF
Diffuser ON
Conclussion:
I’m very happy with this flashlight, nice construction, good quality electronics, very confortable in the hand and you get a lot of throw while still having some flood, but I won’t call it a multipurpose or EDC light. The option of the FR30 diffuser makes possible to turn it in a floody light.
Nice flashlight for law enforcement and tactical purposes. I’d buy it again!
The only thing I miss is the no memory from the tailcap switch to go back to the previous mode you was using, and it would be great if Acebeam offered the option to buy a 21700 cell compatible tube
Edited by: Anthon on 05/03/2018 - 14:50
Trevi_lux
Trevi_lux's picture
Thanks a lot for this great work Anthon.
Nice Pics, beams and very useful information with the runtimes!.
I like this regulation and the design of this optional diffuser…..and wow!! charge speed!
CheapThrills
CheapThrills's picture
Last seen: 4 days 13 hours ago
Would probably be about perfect option for my worklight needs but that clip…
should be more aggressive outward from the body for easy use, hmm
Anthon
Thank you Trevi_lux for all your work
Yes, regulation is very flat and charging speed is very fast, I think it’s very well thought because you normaly charge cells in an external charger, built-in charger is only used as an emergency charger so it’s better if it’s fast
CheapThrills wrote:
Would probably be about perfect option for my worklight needs but that clip… should be more aggressive outward from the body for easy use, hmm
It gets the job done, it’s a tigh fit in your jeans pocket, but it’s not a deep carry clip..
RobertB
RobertB's picture
Last seen: 9 hours 49 min ago
I want one of these L16’s bad. I have the EC50 G2, and a full set of the FR30 filters. The L16 looks like the perfect light to mount on the varmint rifle
stephenk
stephenk's picture
Thanks for the review. What is the strobe frequency, and can strobe be memorised so that the momentary can be used for strobe?
Maiden666
Last seen: 4 months 1 week ago
Good Job Thumbs Up
Thanks
Anthon
Sorry I don’t know how to measure strobe frecuency…
Strobe can’t be memorised, momentary only works for turbo and the side switch won’t memorise it
