Luminus SST-40, a N4 BA bin tested
If the reflector didn’t come loose with thinner MCPCB it doesn’t matter. What does matter it is the led centering ring.
Yeah. Of course… :person_facepalming:
I think I need some sleep…
Ohh, wait! You got that FET to work? Oh boy - I got one working ok with the modded MT03, but yanked it thinking it might be causing 7135 issues. Turned it wasn't the FET, but never installed it back. Then the other day I tried one in a Q8, and it dodn't work at all, nothing - 7135 rmaping would work, and as soon as it got up in the FET range, it stayed at the max 7135 level. 2X click to turbo produce no light at all -- all consistent with the FET simply not working.
Maybe I got a bad part, or messed it up on the reflow - it all buzzed out ok but maybe I fried it. Will try another one though seeing you got good results with it.
Yeah Tom, I’m running it on a 20mm Mtn. FETDD driver with that guppydrv. rev1 UI, no 7135 at all, just piggy backed it on the X3 driver board. I was popping the 404DP, I thought it was due to the re-flow heat, out of 5 I got 1 to work??? :person_facepalming:
I think Dale got 1-2 messed up 404DP’s also?
Hmm? This is the first I’ve heard of this. How is the 404dp compared to the 440dp?
I got 3 SIR404DP's in Q8's now - no problems at all with the reflow. Seems to be a nice bump over the stock FET, stock FET is the NXP, same as MtnE sells: http://www.mtnelectronics.com/index.php?route=product/product&path=25_76&product_id=758
I use the SIR404DP's pretty much exclusively now - pretty cheap at Arrow, qty 10 @ $1.67 each. got a ton of them in lights.
Big advantage of the SIR800DP or 404 is they run real cool, cranking a lot of amps. Richard posted bout it way back. You get over 6A or so, and 800 or 404's is the only way to go.
I like/use the 800’s for what I build, I can’t see any difference, and I have plenty of them. :smiley:
How about Hyperion?
I just don't have enough experience with them yet, or heard enough about them. I'm one for two, and KB has one working well?
you may need to bake them a while to drive out moisture if they are popping during reflow.
i salvage lots of these fets from junk laptop boards without problems so you may simply be getting them too hot.
edit.
these are msl 1 so unlikely to popcorn.
Dale and I pm'ed bout it. I can't recall one SIR404DP I've blown actually, and I've done a ton of them. I use them for every multiple LED light, or multi-die light that has full FET max output. The difference of 30 cents or so from an SIR800DP is a drop in the bucket.
But I understand hesitancy in using them if you've been popping a couple - not sure why though.
You guys probably know this (I did not though when I started reflowing) , but for reflowing any board, you can't just use hot air from above - you have to have a heat source below (according to all the pros, otherwise you don't get properly formed bonded solder bridges) - I use a coffee mug warmer that brings it up to close to 100C. Let the board sit on it for a few seconds - prefer getting the solder paste to spread, then to turn dry, and then apply the hot air from above, and want to use the minimum heat needed, so it will take a few seconds at a min to get the solder flowing.
I think for parts like a FET, the heat from below is important since it has the big hidden pad under it.
yes the heavy copper pad it sits on must reach soldering temp.
i use a homebrew preheater.
its an electric griddle powered by a variac.
Yep, electric griddles must be common to use. My EE buddy here also uses one at home with an adjustable temperature for doing his own boards. He upgraded from his coffee mug warmers because he needed something bigger, so he gave me his old warmer. If I was doing a bit larger scale batches, I would definitely invest in one.
If you want to catch a FET, you must think like a FET.
Confusion
For those in the NY metropolitan area, I was in Ace Hardware (Massapequa Store) and spotted Ace brand toluene in 1 Gallon cans marked down from $19.99 to $6.50. I don’t know if this a chain-wise clearance or local the this particular franchise owner or just this store. This was old stock with rust on the cans so possibly this store manager decided to move them out.
I graduated from Massapequa High, grew up there by the "All American" It's about 15-mins aways, I should check it out. Thanks!
I was at the Hicksville Rd store, not Merrick Rd. Good luck!
Gee, a gallon of Toluene for 6½ bucks…
I finally got my 1 Liter in today, 24 bucks shipped from Germany.
Had to fill out a signed end user declaration and a copy of my ID before they sent it.
But i got the >99.5% stuff.
The smell even creeps through the bottle cap… :person_facepalming:
Good Luck! :+1:
What’cha going to try and de-dome first Jer?
2x SST-40.
I bought them to dedome them basically. :smiley:
One will go in a modded Solarstorm SC01 (8x 7135) 14500 ‘mini thrower’.
The other one in an aspheric, probably my B158 on 4.5 Amperes CC FET driver.
I have a bunch of XP-G2 LEDs too, old and new, and a bunch of XM-L2, also some XP-E2.
Good to have the stuff in stock for future plans.
