making a small batch of Texas Avenger "TA" Drivers fully tested running Bistro or Narsil, Clicky or E-switch, SIR800
249 posts / 0 new
LEDtec
I would be interested in a 30 mm for the L6, still available?
Lexel
Lexel's picture
Last seen: 11 hours 39 min ago
please follow the 4. Batch topic
there are still enough parts to build more drivers
I have ordered more 30mm from Oshpark that should arrive here soon, then i can build more of 30mm size
dragunbayne
Last seen: 1 year 6 months ago
Would I still be able to get a 21MM for my Skilhunt H03?
Lexel
Lexel's picture
I got here 1 21mm for skilhunt already assembled left
dragunbayne
Excellent! I sent you a PM.
geofox784
Last seen: 1 year 2 weeks ago
Still have parts for a 30mm driver for a Convoy L6? If not, what is the ETA for the parts?
What temperature would you set for a L6 and what stepdown time? Do you enable both step down times and a temperature stepdown, or do you usually enable just one?
Looks like for the convoy L6 with two batteries, I would need a 30mm driver with a zener and LDO mod as well as a large spring. Anything else needed? Could I just use the existing wiring? If not, could I pay to have some wiring thrown in?
Lexel
Lexel's picture
Hi,
I have ordered today more parts from Mouser
This week there should be a delivery of 30mm boards from Oshpark
A L6 I would set to 60°C or 3 minutes step down time
NarsilM got temp or timed, not yet both at the same time so far
30mm LDO for e-switch lights
existing wires work well
JasonWW
JasonWW's picture
Last seen: 1 hour 46 min ago
FireFlyMod wrote:
Hi,
do you still have some driver replacement for the H03? It is my second Skilhunt and both (h03 and h03) failed after a small fall on the ground. I checked the led, it works fine. Driver’s dead…
Thanks
This thread is dead. We are on the 5th batch now.
http://budgetlightforum.com/node/56618
