there are still enough parts to build more drivers
I have ordered more 30mm from Oshpark that should arrive here soon, then i can build more of 30mm size
Still have parts for a 30mm driver for a Convoy L6? If not, what is the ETA for the parts?
What temperature would you set for a L6 and what stepdown time? Do you enable both step down times and a temperature stepdown, or do you usually enable just one?
Looks like for the convoy L6 with two batteries, I would need a 30mm driver with a zener and LDO mod as well as a large spring. Anything else needed? Could I just use the existing wiring? If not, could I pay to have some wiring thrown in?
do you still have some driver replacement for the H03? It is my second Skilhunt and both (h03 and h03) failed after a small fall on the ground. I checked the led, it works fine. Driver’s dead…
I would be interested in a 30 mm for the L6, still available?
please follow the 4. Batch topic
[Reviews] Miboxer C4-12, C2-4k+6k, C2, C4 / Astrolux K1, MF01, MF02, S42, K01, TI3A / BLF Q8 / Kalrus G35, XT11GT / Nitefox UT20 / Niwalker BK-FA30S / Sofirn SF36, SP35 / Imalent DM21TW / Wuben I333 / Ravemen PR1200 / CL06 lantern / Xanes headlamp
[Mods] Skilhunt H03 short / Klarus XT11GT, XT12GTS / Zebralight SC50+ / Imalent DM21TW / colorful anodisation
[Sale] TA based drivers NarsilM or Bistro OTSM 17-22mm, S42, L6, Q8, MF01, SRK, TN42 / Narsil based buck driver for 20-30mm MF01/02, TN40/42, GT, MT09R / Remote switch tail DD board with FET
Would I still be able to get a 21MM for my Skilhunt H03?
I got here 1 21mm for skilhunt already assembled left
Excellent! I sent you a PM.
Hi,
I have ordered today more parts from Mouser
This week there should be a delivery of 30mm boards from Oshpark
A L6 I would set to 60°C or 3 minutes step down time
NarsilM got temp or timed, not yet both at the same time so far
30mm LDO for e-switch lights
existing wires work well
This thread is dead. We are on the 5th batch now.
http://budgetlightforum.com/node/56618
KSGER STM32 2.1S Soldering Station Videos - Review Soon
Convoy L6 thread with XHP70.2, TA FET driver, Narsil v1.2 ramping firmware (old), lighted side switch, SMO reflector.
Supfire L5-S thread with XHP70.2, TA FET driver, NarsilM v1.0 ramping UI, 2 x 26350 cells, lighted side switch. My mini L6!
Thorfire S70S with MTN FET driver, RampingIOS (D4) and custom lighted side switch.
10 NarsilM user videos for BLF Q8, GT, GT70, GT Mini, Astrolux S43 and ROT66
Texas_Ace BLF Calibrated Lumen tube and Maukka Calibration Lights for DIY Lumen Measuring Devices
Headlight List with prices, specs and features - Jaxmnve M1 Stainless 10180 Keychain light Review - Lumintop ODF30 Review - Sofirn C8F 21700 Teardown and Review, Sofirn SP33 v2 XHP50.2 Review - My Sofirn Q8 Results - Astrolux S43S 219C Test Results - Lumintop GT Mini Test Results
