Nice! I’m finding more and more to like about Olight. The little S1A I got recently in all copper with PVD coating is really well made, their small lights are special, their big lights are really nice too but on the expensive side.
Very thorough review, like the beamshot differences that really show what to expect.
I like the Olights so far for the most part.
I do like a lot of their small lights also.
I don’t think there has been the “perfect” light made yet to be honest , but things are getting closer to it all the time with these lights.
Something I just learned with the M2R, I had it in my mouth holding it while my hands were full, my tongue touched the magnet and button. I got shocked. I’m not sure if this is an isolated incident with my light only, or all the M2R’s do this.
I am just wondering if you got a little trickle of saliva down in there somehow that cause a short?
I checked with a Key, a penny and even a piece of Turnigy wire when I did the review , from the center of the switch button to the edge on the outer part beside the button trying to get a short and never did.
Well with heart rhythm problems and having had a heart attack already , I think I will skip possible shocking for now.
I just tried to get mine to turn off by putting a piece of wire against the outer ring and the tail switch button itself and I cant get mine to go of when it is on . nor get any kind of short when it is turned off either.
EDIT: A wet Q-tip laid across there don’t do anything with the light on or off either one.
Yeah, mine will shock me with the light on or off. Also when I touch/arc the magnet and button. With the light on moonlight, when it shorts it goes to turbo, then BAM, out. It will come back on like normal though
Just a thought (or 2) is the insulator inside the tailcap damaged or rolled on the edge anywhere? and also try putting the end of your finger inside the tube and kind of spin it a bit to see if that may stop the short.
EDIT: Also make sure the plastic wrap on the cell itself is not peeled off on the edges anywhere as that could possibly let contact be made that shouldn’t be inside the light?
Not real sure with the double tube design which way to go to check things.
That could be the problem with the tube.
It is supposed to have a lip so that it does not come out and only rotates with very little up and down movement at all. On mine I can barely feel the tube move up or down although it moves easily to turn it round inside the outer tube.
That’s interesting! Hmm
I’m on the smartphone. Battery about depleted. Power outage going on. I got out thr MI boxer C4-12 and popped a freshly charged cell in slot 4, then con ected my phone with the charge cable. VIOLA….charging!!
I haven’t been able to get mine apart other than the bezel and tailcap so I don’t know for sure what is down in there or how it is supposed to sit……lol
Yea all my Olights are glued pretty tight , other than a bezel here or there. You can get them apart without damage sometimes , but always a risk of damaging something when you start forcing them apart.
