mcpat
(mcpat)
October 13, 2017, 8:20pm
88
maukka:
Perfect, got it working after a couple tries with your instructions. Thanks a lot!
The ZL1100 uploads data via its micro usb port (which also powers the unit) with an inbuilt CH340G usb-serial converter. One of the unfortunate features of the load is that it updates at a ridiculously high rate. It would be handy if a software could limit the log writes to one sample per second for example.
Perfect. I will implement a sampling rate of 1second (or variable in settings, Not finished)
mcpat
(mcpat)
October 14, 2017, 7:43am
89
Zl 1100 should work if it has a com Port?
maukka
(maukka)
October 14, 2017, 12:08pm
90
Its output is a bit different from the meters, but I’ll send you a sample tonight.
maukka
(maukka)
October 14, 2017, 3:43pm
91
Here’s what the ZL1100 outputs in one second.
050171,010000,0000000016,0000000079
050171,010000,0000000016,0000000080
050176,010000,0000000016,0000000081
050176,010000,0000000016,0000000083
050176,010000,0000000017,0000000084
050178,010000,0000000017,0000000085
050178,010000,0000000017,0000000086
050178,010000,0000000017,0000000088
050182,010000,0000000018,0000000089
9 lines per second and the columns are:
Voltage (V*10000),Current (A*10000),Capacity (Ah*10000),Energy (Wh*10000)
Baudrate: 115200
Data bits: 8
Parity: none
Stop bits: 1
mcpat
(mcpat)
October 15, 2017, 11:31am
92
Thx, on monday I will update the app.
Nice weekend, mcpat
angerdan
(angerdan)
October 15, 2017, 3:32pm
93
angerdan:
POWER-Z family:
Who knows which device the golden one in the top left corner is?
And where is it available to buy?
Recently i found out about the round shaped device in the lower right corner, It’s the POWER-Z wireless charging receiver board (BG001):
maukka
(maukka)
October 15, 2017, 6:03pm
94
Much appreciated, thanks!
angerdan
(angerdan)
October 16, 2017, 4:08pm
96
I found YZXStudi products on eBay from >14 different sellers.
About which seller are you talking?
staticx57
(staticx57)
October 16, 2017, 4:26pm
97
Is there some table that lists all the options and which each product has? Hard to keep track of, especially in english.
mcpat
(mcpat)
October 16, 2017, 6:30pm
98
Thank you for your data. Need one more day, but it already works here for the zl1100, but chart need one day for developing…
angerdan
(angerdan)
October 17, 2017, 4:56pm
99
Yes, Franky Tong helped me translate!
translated values
Model,ZY1276,ZY1275,ZY1273,ZY1272,ZY1271,ZY1270,ZY1266,ZY1265,ZY1263,ZY1262,ZY1252,ZY1231,ZY1230
Nickname,Power-Z,?,?,?,?,?,?,?
Display Type,TFT,LCD,OLED
display size,1,44",0,96",1,3",0,96",0,91"
Appearance...
Also check out the feature list:
https://docs.google.com/spreadsheets/d/1Dt—1kYYWxLFXcx3aZOOw8ely4mi9wtXAj397A9XvdI/edit#gid=696514437
staticx57
(staticx57)
October 16, 2017, 11:46pm
100
Ah, thank you thank you thank you!
I do believe the second link is broken though. Looks like the 1276 vs 1275 is a lesser model except for amp capacity
RobertB
(RobertB)
October 17, 2017, 12:09am
101
I can’t seem to find the power banks anywhere. Does YzxStudio still make them?
RobertB
(RobertB)
October 17, 2017, 2:17am
103
I guess that means no, the YzxStudio power banks are no longer available. Unless someone has a link to one
mcpat
(mcpat)
October 17, 2017, 10:53am
105
Hello there,
Updated the app:
should work with the ZL1100 load?
sample rate can be defined in settings, also path and logformat
But chart is not finished yet, therefore I removed the icon until finishing this function.
Download here
Regards
Patrick
maukka
(maukka)
October 17, 2017, 11:09am
106
Nice! I’ll give it a go tomorrow when I get back home from the Netherlands.
mcpat
(mcpat)
October 17, 2017, 2:56pm
107
Please download again, I fixed a small bug… Forget the chart icon, it displays something, but it is not working.
angerdan
(angerdan)
October 17, 2017, 5:03pm
108
staticx57:
You’re welcome
I updated the second link again, no idea why it doesn’t work. Checked all permissions at google sheets, everything the same as the file in the first link.
But you’ll find the information here too:
https://aliexpress.com/item/YZXstudio-color-meter-USB-current-voltage-capacity-fast-charge-QC4-0-PD3-0-PPS-trigger-tester/32829743426.html
I got the last one from Franky, but sad to hear this great powerbank isn’t available anymore.
Hi! Franky Tong here I’ve known about this forum through my customers for a while and finally decided to register for an account so I can post directly
I contacted YZXstudio just now and they told me there’s no plan to stop producing their power banks (perhaps it was another product KAAYEE was referrring to?). They will continue to make and improve them. I’m not sure who else would sell and ship them outside of China though.
d_t_a
(d_t_a)
October 18, 2017, 3:41am
110
Second link doesn’t seem to work for me too. Possibly because the first one is “usp=sharing” while the second one is not?
