Wrist watches. Post pics, if you EDC one!
Ven, what’s your wrist size? To prevent your pins to falling out, put a tiny drop of removable loctite on the trailing end. Wipe any excess off before it dries.
About 8” with a quick measure now(had to use a fatmax tape measure lol )
Checked the other screws and all secure, so nipped this one up good………….if comes loose i will use some loctite from work :+1:
Ven, I used Loctite on my Movado Valor’s band. One pin kept creeping out so I put a tiny amount on the trailing edge of that pin. I’ve never had a problem again. I’ve since sold that watch. I do miss it.
BTW, those are finger prints, not scratches. It’s the only picture I have of it.
Cool!!!
Thanks glenn, thats the 1st time i have had a pin come out……………maybe 6+months(cant even remember when i got the bracelet). Will keep an eye on it, if persists it will get a dab of loctite :slight_smile:
Why did I sell this watch? I’ll never know. Biggest mistake I ever made in the watch world. It’s a Fortis Spacematic Automatic.
Hello everyone. Sorry to derail this thread a little, but I need some help from the watch guys
(I’m more into knives and I try not to get interested in other stuff like lights, lighters, fidget tools, watches and whatnot… :wink:
Anyways, I own a Skagen watch (809XLTBLN) and I’m kinda bored to repair the leather straps every half year.
I was considering making a new one, sewn, not glued, but I have more other projects to finish.
The metal band is well above € 50, maybe one of you watch pros knows where to get it cheaper or maybe a China made version.
Thanks in advance :wink:
(If you can’t see photobucket links, try this: Photobucket Hotlink Fix. It’s available for Firefox and Chrome
https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ )
I'm not sure if this will help, but...
I get stainless steel mesh bands from "goodcheapman" on eBay:
http://stores.ebay.com/jrrs7777
I learned about him on watchuseek.com:
http://forums.watchuseek.com/forum.php
I bought from him somthing like this and it lasted little less than 2 year EDC. It was OK
This is my latest purchase from goodcheapman:
http://www.ebay.com/itm/20mm-stainless-steel-watch-mesh-bracelet-black-0-8mm-wire-wristband-JRRS7777-/192118577402
I've had it about 2 years, and I love it.
According to my research, if you want higher quality stainless steel mesh than what goodcheapman has, it's going to be quite a bit more expensive.
I have the exact same opinion: this may be the Rolex that pleases my eye the most….
Thank you :slight_smile:
The biggest problem is that the wristband is not held with pins like usually but the strap is held with 2 little screws.
On the leather version there’s a thin metal sheet with 2 holes for the screws between the 2 sheets of leather.
I guess I will write to this shop in the evening :slight_smile:
^ That’s a serious collection of key chain gadgets! :slight_smile:
Love it weklund, the orange malk and deep blue is simply awesome :sunglasses:
As an aspiring watch-collector, with only 2 Citizens and 1 Seiko :), does anyone know of a chronograph watch that you can just turn the outside bezel to 30 minutes, for example, and it chimes an alarm when the time is up?
Don’t really want to use a digital watch if possible.
Thanks for any suggestions
Lou.
I’ve never seen that, I think the separate spring and bell would double the size of the watch.
It’s sad because most quartz watches have alarms that are too quiet, especially if they are also waterproof.
(Speaker is inside the waterproofing, plus usually in the back against your wrist.)
wle
I would be shocked if any of you had the honor, privilege and the pleasure of owning this classic.
I’ve never seen it either but had just a glimmer of hope, thanks for squashing it. :slight_smile:
i could be wrong.
wle
Hi Lou,
I’ve been collecting watches for some 30 years and never seen a wrist watch with rotating bezel alarm. The Seiko Bell Matic with internal rotating alarm set bezel ring is as close to what desire that I have seen. Although not a chronograph it is automatic. Rather small on the wrist (36mm) compared to most of today’s 40mm plus diameter watches.
One of my vintage Seiko Bell-Matic’s Mdl 4006-6010
Youtube links:
https://www.google.com/search?q=seiko+bellmatic&safe=off&rlz=1C1NHXL_enUS706US706&source=lnms&tbm=vid&sa=X&ved=0ahUKEwiHtLHxovrWAhULr1QKHdCCCdAQ_AUIDCgD&biw=1280&bih=592
Although a digital …. the Casio G-Shock GD-350-1D is a very cool vibrating wrist alarm with several alarm settings.
G-Shock GD-350-1 Review
