Results: Testing XM-L, MC-E, SST-50, and XP-G emitters **Updated**
Thanks Match! Been waiting for this info to build my XP-G project. Question now is, is it worth the sacrifice of runtime to get a little more light. I'm looking at 600mA to gain about 50 lumens. I don't think it's worth it. Still seams like 1.4A is the sweet spot for runtime vs. output.
-Garry
2.2A xpg is exactly what the N-light B2s stainless steel lights are running on the 14500 ..
always got a ..."WOW that's bright".... from the crowd ...
ooooohh....aaaahh.
And what would be a similarily "bold" current for an XR-E?
oldbobk,
So are you saying the affect on runtime is negligible between running 1.4A vs. running 2.1A? That doesn't make any sense to me.
I also don't know if I'm up to the challenge of removing two of those chips! I'd probably look into the newer KD driver (and deal with a lousy low, or go 2 mode).
-Garry
The difference in run time with a 2400mah battery would be about 100 minutes for the 1.4 and 70 minutes for the 2.1 amp high, but I never use high when I am concerned about runtime.
Send me a PM when you are ready to remove the chips I can walk you through it or I can send you one premade if you want.
Thanks for the offer Erik! I am definitely keeping you in mind for a custom P60 drop-in or even just a custom programmed driver (think I'd like Medium a bit higher than the usual 30%, or even 4 brightness modes) for another mod.
100 minutes vs. 70 minutes sounds considerable (for my application), so therefore I don't see the gain of 50 lumens worth the 30 minute trade-off.
-Garry
Don't want to be a spoilsport but please remember that Match's curves are only valid for a heavily cooled emitter. The top points for the curves in real life lies at a much lower amperage because of the generated heat .
[EDIT]: Calculations using Cree's derating curves give me for a "normally" cooled flashligt a top on the curve at an LED output of:
370-400 lumen @ 1.8A for XP-G R5 and
730-780 lumen @ 3.5A for XM-L T6
but the top 30% of the current only add about 12-15% of light output.
OTL (out of the lens) output normally are about 80-85% of the LED output.
Yet another reason for me to stay back to 1.4A / 1.5A!
-Garry
Possibly the most informative post for us modders on this forum. I've actually photographed the charts to my phone for easy reference.
Thanks Match!
yeah XR-E q5 Wink one day when time permitts
Can't a few of us donate $1 or $2 to Match so that he can test a XR-E Q5 and R2? (I'd be willing )
I’m in if Match is willing to do it. I’d love to see what an XR-E can put out and what difference there is between an R2 and a Q5.
don't worry guys, it is in the works (well, at least the R2)
What about the newest Cree's, any plans, I realise they may not be power houses so maybe not much interested?
Yup. Thanks to dthrckt graciously sending me an xr-e r2, it will soon be tested along with a direct to copper mounted xm-l.
Gentlemen,
The initial star mounted test for the xr-e r2 is complete. The first post has been updated to include the graph. One of these days I'll go through and clean up that first post.
Thanks again to Dthrckt for sending me the emitter for testing....and yes, I'd like to someday get around to testing the new Cree flavors too... I don't need the money, but if y'all could somehow paypal me "15 minutes" that would really help :)
-NeedsavacationMatch
Thanks Match! So it's not worth going over 2.0A. Guess you didn't test it to the point of "pop, burn, fizz, fizz". How was the heat generated at 2A? Manageable for a decent heatsink setup?
-Garry
Thank you Match!
Overdriven XR-E lights seem to be quite popular right now.
Thank you (again ;-) ) Match. Those last results show why xre are still all the rage in flashlights. And a super duper reference as always.
