USB power meter/tester thread - YZXStudio, Power-Z, RDTech and more.
312 posts / 0 new
mcpat
mcpat's picture
Thx, on monday I will update the app.
Nice weekend, mcpat
angerdan
angerdan's picture
Last seen: 6 hours 5 min ago
angerdan wrote:
POWER-Z family:
Who knows which device the golden one in the top left corner is?
And where is it available to buy?
Recently i found out about the round shaped device in the lower right corner, It’s the POWER-Z wireless charging receiver board (BG001):
https://translate.google.de/translate?hl=de&sl=zh-CN&tl=en&u=http%3A%2F%...
maukka
maukka's picture
Last seen: 11 hours 23 min ago
Much appreciated, thanks!
KAAYEE
The YZXStudio products now listed on eBay with technical support. Looks only one seller for it now.
angerdan
angerdan's picture
I found YZXStudi products on eBay from >14 different sellers.
About which seller are you talking?
staticx57
Last seen: 1 hour 15 min ago
Is there some table that lists all the options and which each product has? Hard to keep track of, especially in english.
mcpat
mcpat's picture
Thank you for your data. Need one more day, but it already works here for the zl1100, but chart need one day for developing…
angerdan
angerdan's picture
Yes, Franky Tong helped me translate!
https://docs.google.com/spreadsheets/d/13_A0ntuk7x-vVV3tSLLZVfPk_eCfBVkC...
Also check out the feature list:
https://docs.google.com/spreadsheets/d/1Dt—1kYYWxLFXcx3aZOOw8ely4mi9wt...
staticx57
Ah, thank you thank you thank you!
I do believe the second link is broken though. Looks like the 1276 vs 1275 is a lesser model except for amp capacity
RobertB
RobertB's picture
Last seen: 22 hours 47 min ago
I can’t seem to find the power banks anywhere. Does YzxStudio still make them?
KAAYEE
While, check the one from KAAYEE Direct, same name as the one selling on Amazon.
RobertB
RobertB's picture
I guess that means no, the YzxStudio power banks are no longer available. Unless someone has a link to one
KAAYEE
Have called the manufacturer just now and confirmed that he has stopped producing the power bank due to several reasons. So there is no more YZXStudio power banks available now.
mcpat
mcpat's picture
Hello there,
Updated the app:
should work with the ZL1100 load?
sample rate can be defined in settings, also path and logformat
But chart is not finished yet, therefore I removed the icon until finishing this function.
Download here
Regards
Patrick
maukka
maukka's picture
Nice! I’ll give it a go tomorrow when I get back home from the Netherlands.
mcpat
mcpat's picture
Please download again, I fixed a small bug… Forget the chart icon, it displays something, but it is not working.
angerdan
angerdan's picture
You’re welcome Smile
I updated the second link again, no idea why it doesn’t work. Checked all permissions at google sheets, everything the same as the file in the first link.
But you’ll find the information here too:
https://aliexpress.com/item/YZXstudio-color-meter-USB-current-voltage-capacity-fast-charge-QC4-0-PD3-0-PPS-trigger-tester/32829743426.html
I got the last one from Franky, but sad to hear this great powerbank isn’t available anymore.
iloveelectronics
Last seen: 1 year 8 months ago
Hi! Franky Tong here Smile I’ve known about this forum through my customers for a while and finally decided to register for an account so I can post directly Smile
I contacted YZXstudio just now and they told me there’s no plan to stop producing their power banks (perhaps it was another product KAAYEE was referrring to?). They will continue to make and improve them. I’m not sure who else would sell and ship them outside of China though.
d_t_a
Last seen: 15 min 47 sec ago
Second link doesn’t seem to work for me too. Possibly because the first one is “usp=sharing” while the second one is not?
d_t_a
mcpat wrote:
Hello there,
Updated the app:
Download here
Regards
Patrick
Thanks! Was wondering if the DataExplorer opensource app can also be configured to work with the ZL1100 load tester?
MRsDNF
MRsDNF's picture
Last seen: 7 hours 12 min ago
Hi and welcome to BLF Franky Tong. Thanks for the update. Thumbs Up
mcpat
mcpat's picture
I‘m not the developer of Dataexplorer, and I don‘t prefer Java. So do you miss a feature in my app?
maukka
maukka's picture
Not working for me with ZL1100. Says time out after trying to connect, same as with the original version.
mcpat
mcpat's picture
I will add variable timeout setting, now it is fixed 2 seconds.
But the other zy is working or also broken? Can you please try to connect with putty? So when putty is working, then my app is fault, otherwise it‘s your zl1100. Anyone else here with a zl1100 for testing?
Regards
Patrick
Edit: my zy only times out when I display the chart screen on it, other screens don‘t cause a Time out
maukka
maukka's picture
Putty or any other terminal program works fine with the ZL1100. ZY1270 also works with the new version.
RobertB
RobertB's picture
Welcome to BLF Franky. If you happen to find out who could sell the power banks, let us know. I would think someone could sell quite a few of them if there was a solid place to buy them from, especially if they were converted to English.
angerdan
angerdan's picture
Yea, great to have you here Franky Crown Thumbs Up
d_t_a
maukka wrote:
Hooked up a serial usb adapter to the 1271 and your software works fine. Gonna do some more testing after soldering the pins on the board.
!https://i.imgur.com/TlH89bS.jpg!
1)
Pardon my ignorance, how does one connect a serial-USB adapter to the ZY127x meters? Does the ZY127x meter have to have the bluetooth module installed for this to work? Or just need to buy some kind of serial-to-USB chip and (temporarily) connect it to certain contact points of the ZY127x meter?
2)
I also have the ZL1100 load tester, and getting same error message as maukka above.
I actually haven’t tried to connect the ZL1100 tester to the computer yet before, so it’s my first time to test it connected to the PC.
(I’m not familiar how to use Putty, but I searched and downloaded a free software called RealTerm, opened the correct COM port, and it started to log results on the window); I had to use “Run as Administrator” to get RealTerm to work:
The above image correspond to reading of 5.0097v, 0.1000A, 0.9869Ah, 11.3322Wh
The “CPS” status window fluctuates between 740 to 1110 cps.
Not sure if this will help in debugging your great app.
iloveelectronics
1)
Find the 4 solder pads near the edge of the main PCB. Starting from the square one, connect the 1st, 3rd and 4th solder pads to the GND, RXD and VCC of your serial-USB adapter.
d_t_a
d_t_a wrote:
1)
Thanks for your reply! Just need some more clarification… somewhat newbie here.
Let’s say I purchase something like this (PL2303 USB to RS232 cable adapter)
https://www.lazada.com.ph/standard-pl2303-pl2303hx-usb-to-ttl-uart-cable...
Then I connect the pins:
“1” = GND
“2” = (no connection?)
“3” = RXD
“4” = VCC
Is that right?
