ENEDED
I got one of those too. Ordered 2 of the holsters, one had astrolux, the other has mateminco on it.
I see, that’s good to know, thanks a lot for the explanation and for your awesome work! :wink:
Any chance we could get new deal for Astrolux S41S SS ?
This is the one I know: Banggood : Global Leading Online Shop for Gadgets and Fashion
Thanks g_sintornillos ,
anything I should be aware before ordering? I see that many people were not satisfied with QC, mostly damaged emitters, leds with different tint etc!
I wanted to go for Nichia version.
First batch was for oblivion, high failure rate and DOA, then improved
I do not know what’s happening with the current batch, Astrolux is not characterized by having a minimum quality control, it can be a lottery
Mine, from second or third batch, bought at the end of 2016, works fine from out the box
check out post #366
Thanks, I wanted one for a long time but all this hiccups turned me off, hope they improved the light, wouldn’t like to get faulty nichia led, don’t have those at hand.
Astrolux S41S SS - from $32.26 ($64.95)/ Coupon: 8A955D
Nichia 219B / CREE XP-G3 / CREE XP-G2
S41 22.99$ in the app
also colored aluminum 18650 tubes availiable now
Which is the lowest price for black S41, i only get 24 usd on BG with a discount code FLSTNE and in android app a price is the same not lower.
And which high drain 18350 batteries from aliexpress would be the best for turbo mode, those from litokala probably will not stand the drain https://www.aliexpress.com/item/2PCS-ICR-18350-lithium-battery-900mAh-rechargeable-battery-3-7V-power-cylindrical-lamps-electronic-cigarette-smoking/32390812333.html
For those interested, I bought the Mateminco S01, which is the same as the S41S except they use the 5000k 219B emitters. The tint is better (less green) than my Astrolux S42 5000k 219c, and both MF01 with 5000k 219c. I asked the seller and they confirmed it is still the 219B. The quality is awesome. Very heavy in weight and good heat shedding from the copper. I hated the Astrolux S42 but I love the Mateminco S01. It has memory mode same as BLF A6 but its much brighter than the A6 from ceiling bounce test.
https://www.aliexpress.com/item/Stainless-Steel-Flashlight-Mateminco-S01-4-CREE-XPG3-Nichia-219B-max-1600-Lumens-waterproof-outdoor-torch/32851883631.html
I don’t have an account there, but could you let the seller know they’re legally required to state that the product uses open-source code and provide a link to (or copy of) the source code?
https://code.launchpad.net/~toykeeper/flashlight-firmware/blf-a6-final
The details are all covered in the “COPYING” file included with the sources.
Ok I relayed the message to the seller
Astrolux S41S SS - from $14.49 $64.95 / Coupon: AC20
Have to omit free gift for this price.
Ugh, I really didn’t need that… but there’s one on the way now :person_facepalming: Thanks freeme!
says 219C on the site
Hmm.
$14.60 US works out to $27.69 AUD.
I ordered a Cree G3 to go with my Original 219B, 18650 tube.
I run that one at 4 or 5 out of the 7 settings. not more.
Gives good walkabout All over light. with decent range
and doesn’t heat up TOO much there.
With another coupla clicks for a few seconds to check something out.
We’ll see if the G3 gives a little more range hey.
Good price but I already have 4.
I will resist the deal :slight_smile:
me too :person_facepalming:
