Hi
it is possible to add the other firmware if you supply me the hex for it
as I am not familiar with Anduril I cant calibrate it like I am used in Narsil
I can build you the drivers and add 8 loose AMCs
Hi
OK, I’ll ask around if there is a Anduril hex file for the Q8. I’ll let you know as soon as I got it, if not I’d buy them anyway flashed with latest version of Narsil. Cheers.
Bookmarking this for future mods. Nice stuff!
It doesn’t look like there’s a HEX file for a FET+N+1 availlble for Anduril. So the latest version of NarsilM will do.
Do the siwtch LEDS blink while crossing from 1AMC to N AMC to FET?
Also, from what I understand (wich is as good as nothing) I cannot just add extra AMCs without recalibrating the driver software?
The Indicator LED blinks out after you stopped ramping which bank is active
You can add extra AMC7135s
The ramping table is a good start and gives good results on most lights,
it depends also how much the FET current is, like a single LED can draw on 17mm 2.45A from AMCs and 6A from FET
while a quad board draws 2.45A from AMCs and 12-15A from FET
for quads the ramping in FET will be proportional bigger,
the SRK sized have 5.6A AMCs to about 20A FET
but the steps in FET are the same its still smooth
ok thanks for explaining.
So I’m stil up for
(1)46mm Q8 Narsil no calibration, PO=(2B), SD=2.8V, 16AMC
(1)46mm Q8 Narsil no calibration, PO=(2B), SD=2.8V, 8AMC
Now that I have read through things a bit more, I am liking these even more.
When you can get to them,
(2) 30mm 2S NarsilM LDO 65°C, SD=6V, PO=(NO), lighted side switch, LED wires, no spring
shipped w/tracking please.
Not sure on the wire length, as I dont have the hosts (Convoy L6) in hand yet. Seems common enough I trust your judgment on that, just let me know.
Thanks,
Jim
I can do this in this batch, but I have to wait to stock up parts and 30mm boards
Sounds good. I am in no rush. Got several others in the works right now to play with.
Lexel, on the 2S boards for the L6, are you still using the 4700k resistor for the switch light?
4.7K ?
I use 20K
20K~30K are fine?
Yeah, I use 15k to 30k.
I was just gonna suggest Lexel increase the resistor value for these 30mm 2S L6 drivers since everyone usually uses 2 leds.
I had another question. Is this accurate?
When it comes to NarsilM and a 2S driver, you can only have 2 of these 3 options:
Temp protection
Low voltage protection
Indicator function
Could you sacrifice temp protection in order to get LVP and the indicator function?
temp does not need a pin, the other 2 does
The 4.7k is the minimum resistor, other values are possible, of course rewire the switch board for diodes in series increases the efficiency
Temp doesn’t need a pin? Is that only in NarsilM?
I remember on the older Narsil that I had to choose between temp or lvp.
I chose lvp and no temp. I’m a little confused about this.
The Convoy L6 switch LEDs are parallel. It would be a major undertaking (cutting traces and adding wires) to make it series.
This was the choose between v1.2 and 1.3, 1.3 does not support LVP in 2S, but got a lot of functions like temp sensor readout and use
Just a heads up, Lexel. It looks like the 2nd generation of Astrolux MF01 have a new wiring pattern on the mcpcb (along with a new driver design). We will have to see if the TA driver can be compatible with it.
[image] [image] I just got a my nichia 219c out of the mailbox.Looks great not a mark on it.Here are pics of the new driver and mcpcb. Alot different that’s for sure.Igot 10701 lumens with 10100@30s. on fresh vtc6.I’m going to check again after while to be sure i got it right.
you would have to modify the MCPCB
Narsil can be set up for modes with different mode groups
21mm fits my H03
OK today 200 AMCs got delivered, so we can start to build drivers
