Interested
Please sign me up for a NW. Figure I'll save $45 on upgrading the LED's.
I just hope they improved the switch boot - I got a MT03 II and the center post inside the boot is way too narrow, so you have to press it dead on in the middle to get it proper.
Pleaseeeee ask them to look at the switch boot and fix if possible. For ramping UI's, it's a pain.
Thanks for the deal though!!
Interested if it has Narsil ramping type UI.
If you change the driver out, then yes. Is that what your asking?
Interested if CW available... and the price is decent.
I should add I love my MT03 II! It's built like a tank, anodizing seems very good, and I do like the styling. Yes - mine has a FET+1 driver replacement running NarsilM with XHP70.2 P2's and does over 25K lumens.
It's overall smaller than a Q8, but wider head, and weighs 50% more at 600g vs. 400g for the Q8, but every gram is worth it.
Tom, are you referring to this right? Do you want them to increase the diameter or overall length?
MT03 II group buy will start in about 24hrs time.
Yep, that stem or plunger, whatever we want to call it. It's too thin, and you can tell it bends over easy, so if you don't apply force in the center and straight down, it doesn't engage the switch as well. I even tried adding a dab of a good epoxy to the tip of that stem, thinking it was just short, but it made little difference. Maybe lengthening it a bit would help as well.
My preference is for an easier activated switch, but some may want it stiffer to avoid accidental activation's, which is fine, but the full depressed distance to activation should be short. I got ramping UI's on some stiff switch lights - it works, but it concerns me how well it will hold up. Some are known to fail like the Manker U21, and other Manker models. They tend to fail and they also are stiffer than average.
Also the switch rubber boot is big, really big - think that's part of the issue why the stem has to be thicker. Love the easy 4 screw mount though - no scratching a ring!!
Way better!!
So I ended up ordering replacement LED's for this new MT03 II anyways :FACEPALM: . It's hard not to get the best out there available. Bought 3 XHP70.2 P2 5700K 70+ CRI LEDs from Arrow - for under $10 each, link here: https://www.arrow.com/en/products/xhp70b-00-0000-0d0bp20e2/cree
Look at the 500+ price, wow: $6.86
Interested depending on price… (neutral white)
Is the turbo run time correct at 2.5 min?
About the white anodization. It appears to be matte on the pictures, is it matte?
It should look like matte silver in real life.
How about the feel? Is it like the desert tan S2+?
Might have to consider getting my first light in white.
My MT02 in silver/white appears to be matte/satin. You can feel a very fine rough surface compared to the standard black anodisation lights. It looks and feels very nice.
Thank you for that explanation, just what i wanted to hear :+1:
I like the way MF01 button clickie work is perfect.
i think increase in pin diameter and the length will reduce the squishy problem
Group buy has started.
Order placed
Thank you for the groupbuy!
