About the white anodization. It appears to be matte on the pictures, is it matte?
It should look like matte silver in real life.
How about the feel? Is it like the desert tan S2+?
Might have to consider getting my first light in white.
My MT02 in silver/white appears to be matte/satin. You can feel a very fine rough surface compared to the standard black anodisation lights. It looks and feels very nice.
Thank you for that explanation, just what i wanted to hear :+1:
I like the way MF01 button clickie work is perfect.
i think increase in pin diameter and the length will reduce the squishy problem
Group buy has started.
Order placed
Thank you for the groupbuy!
Just curious, why this version with 70.2 LED has the same lumen as in Version 1,
Why not Haikelite increase more lumen with this 70.2 version ?
I've wondered that too... I have one on the way. It is still at least 10 days away but once it gets here I plan to check output first.
I do know it is possible they just kept the power at just the level for the same output as it would take less power with the 70.2's which means less heat.
If it’s the same constant current driver as before, then there is not gonna be any power increase.
You may get better efficiency or less heat. You may also get a smoother beam pattern with less dark spot in the middle. Plus it’s now cheaper to upgrade to a fet driver for more output because you don’t have to upgrade the 3 emitters.
Given specs is base on regular MT03II gen1. [quote=flybird] Just curious, why this version with 70.2 LED has the same lumen as in Version 1, Why not Haikelite increase more lumen with this 70.2 version ? [/quote]
order placed.
Thanks
Ordered. Thank you!
Too expensive but thanks for organising
ordered thanks.
Interested cw
i interest. please input me down
Interested in NW (White)
Cost price for 70.2 is high, no choice.
