Air Cooled 4x XHP50.2 UPDATE: Videos, Willing to sell
48 posts / 0 new
Kourtinoksylo
Last seen: 3 hours 16 min ago
UPDATE AT THE END OF THIS POST
I present you my latest flashlight. Its been a while sience I uploaded a mod, I hope this one will make up for it! The reflector design is inspired by Old Lumens, the heatsink and active cooling design was all my ispiration. I wanted to build an active cooled flashlight, as raw power is not everything if you cant use it more than 10 seconds. Its a little “Frankestein” looking, some will find it ugly, personally its not my favorite looking piece, however 100% innovative…
This time I have some photos of the building process too:
The host is a SRK. I used a second tube to accomodate the 8 cells.
This is the template I used to drill the holes for the heatsink. Firstly I drew it on a piece of paper and then scaled it down with a computer and printed the right size. In this way it came out more accurate and the work of drawing in bigger scale was easier.
114 holes for 114 rods, of which 64 go through all 3 copper plates.
Drilling 1mm pilot holes, and then enlargen then to 2.9mm for a tight fit with the 3mm copper rods.
The heatsink is composed of three 2mm copper disks connected with 3mm copper rods. In the middle disk I cut a 30mm hole to accomodate a 30mm fan, normally used to cool RC cars. It reaches a maximum of 23.000rpm, it moves a huge amount of air. There are videos of it on youtube. Its called WTF 30mm.
The switches and resistors are used to regulate the speed of the fan. I chose 3 speeds that thought were useful, one quiet, one middle and one almost max.
The reflectors are from KD, 36mm in diameter and were cut with a hacksaw and shaped with a file to fit together nicely. Epoxy was used to glue them together.
This is the driver I am using with Narsil firmware/ramping, 0.3mm copper sheet solderedused on the spots where the cells and carrier are contacting to prevent wear on the gold contacts. It also increased the mass of the driver, improving its heatsinking.
And some numbers…
The design of the heatsink allows a clamp meter to be connected direclty at the 13awg cable that goes to the leds. I am reading with 8 LG MJ1 3500mah cells almost 40amps, which translates to 10 per emitter and theoretically almost 20.000lumens. I suppose OTF I get 18.000lumens, maybe 17.000. The surface of the heatsink alone is calculated to 380cm^2 or 59in^2. Roughly an area 20cm x 20cm, not bad. Heat at those levels (40A and 8.4v) is still a problem but active cooling helpes immensely on middle levels.
Measurment of xhp50.2 from djozz here on this forum:
Wall shot next to a C8 with XML2. C8 on the right CW 3amps. Frankestein on the left NW around 5amps. Brighter and bigger hotspot.
Hope you like it! Comments/advice/questions always welcome!
UPDATE……………..UPDATE………………UPDATE…………….UPDATE…………….UPDATE………………….UPDATE……………
Beam shot location:
Beam shot video of my flashlights:
Active cooling demonstration:
For further information please check the video descriptions.
Some numbers:
From 23C to 52C in turbo 41sec without fan. With fan 50sec. Ambient temp 23C. (indoors)
From 7C to 52C in turbo 1:13min without fan. With fan 1:30min. Ambient temp 7C. (outdoors)
From 23C to 52C in 50% 2:23min without fan. With fan 4:41min. Ambient temp 23C. Sabilizing around 55C.
So in turbo the difference is very small, but in 50% which is more than 8000lm it almost doubles the runtime, and please note it was indoors. Outdoors I believe you can run it below 52C for ever at 50-60%.
As I say in the title I would be willing to sell this flashlight if I get a generous offer. I put a lot of work in it, around 60-70 hours and as a reference the matterials alone costed me more than 150$. If you want to make an offer with PM feel free.
-Air cooled 4x XHP50.2: http://budgetlightforum.com/node/56829
-SkyRay King 4x XPL HI, TN40 clone: http://budgetlightforum.com/node/55195
-XHP70.2 Maglite 2D: http://budgetlightforum.com/node/54791
-SkyRay King 7x XML2, TIR, 8x 18650: http://budgetlightforum.com/node/54886
Edited by: Kourtinoksylo on 11/01/2017 - 18:33
Nicolicous
Nicolicous's picture
Last seen: 6 hours 8 min ago
wow it look cool man Thumbs Up
Nico -.-
robk
Last seen: 1 week 2 days ago
Awesome. I expect Justin’s spirit is smiling. Lovely work.
pinkpanda3310
pinkpanda3310's picture
Last seen: 1 day 3 hours ago
“Its a little “Frankestein” looking, some will find it ugly, personally its not my favorite looking piece, however 100% innovative…”
For a fan cooled light I think it looks pretty good Sushi
Nice idea and well executed Star
The Miller
The Miller's picture
Last seen: 11 months 6 days ago
Awesome!
Think it looks very nice
Can you tell more about temps?
MRsDNF
MRsDNF's picture
Last seen: 1 day 43 min ago
That is one very creative build Kourtinoksylo. OL would be very happy to know you inspired him and of what you have made.
That fan you have used looks like an amazing item. A little different to the one I’m using.
Thanks for posting it up and looking forward to seeing more of your creations. Thumbs Up
KawiBoy1428
KawiBoy1428's picture
Last seen: 10 hours 13 min ago
That is one bad mamma jamma there! Beer
Your like riding the ragged edge of POOFDOM at 10amps per LED!!!!
BRAVO!! Thumbs Up
I wouldn’t run 8-30Q’s or VTC5A’s !
KB1428 “Live Life WOT
WillyD
Last seen: 6 months 7 hours ago
I think this is one of my favorite builds in a long time! Any way you would be able to create a youtube video with the fans running? I’d like to see it all in action. And, excellent use of your tools as well.
pommie
Last seen: 3 hours 19 min ago
Nothing to see here folks, move along...
leroycp
Me like! One of the best I have seen. Two thumbs up.
AlexGT
AlexGT's picture
Last seen: 5 days 15 hours ago
AWESOME BUILD! Justin (Old Lumens) is smiling at you! Smile Beer
lostheplot
lostheplot's picture
Last seen: 2 months 4 days ago
Thumbs Up
sorry all images down
thanks photobucket
bwings
Last seen: 1 week 3 days ago
Awesome!
very creative build, looks like a badass weapon from ‘Doom’ Big Smile
Next project: Water Cooling LOL
____________________________________________________________________________________
Sorry for my poor English
xxx
xxx's picture
Last seen: 1 year 6 months ago
Creative
Like the way you cut thats SRK
Majoroverkill
Majoroverkill's picture
Last seen: 4 weeks 19 hours ago
I like it! I like it a LOT!! Great job Big Smile
Doug S.
Jtm94
Last seen: 1 month 1 day ago
Really interested in what this pushes the maximum safely sustainable output to.
Box
That’s amazing! Love very creative
FPV
FPV's picture
Last seen: 1 year 1 month ago
such an innovative way, very nice mod.
The_Driver
The_Driver's picture
Last seen: 1 week 8 hours ago
Very nice! Thumbs Up
southland
southland's picture
Last seen: 1 month 4 days ago
Really great build and I also like the looks.
gregor
gregor's picture
Last seen: 7 hours 5 min ago
Amazing, very nice Thumbs Up
djozz
djozz's picture
Last seen: 20 hours 26 min ago
Extremely nice and effective build! Thumbs Up
Flashy Mike
Flashy Mike's picture
Last seen: 1 week 5 days ago
Great build!
Would you mind to elaborate which SRKs you used and how you connected the tubes?
solRNY
Last seen: 1 month 2 days ago
that’s way cool!
Sukoi
Last seen: 7 months 2 weeks ago
beauty and the beast….thanks for showing off Beer
Kourtinoksylo
Flashy Mike wrote:
Great build! Would you mind to elaborate which SRKs you used and how you connected the tubes?
I inserted some 3mm screw rods in the exsisting holes of the spring board and let them stick out around 12mm as you can see on the picture. I then drilled four 5mm holes roughly at the appropriate spots at the second tube as you see on the same picture. 5mm allows some room to play and find the perfect fit. I filled the 5mm holes with epoxy and placed the tube with the screws on top of, with the screws being inside the epoxy. After it hardened they became inseparable. I suppose if i heat the pieces a lot and melt the epoxy I can separate them if needed…
The SRKs I used where the cheapest I found on aliexpress that had the smooth type tube. Were around 15-17 dollars a piece. They are I think 10 or 11x XML.
Thank you all for the kind words.
Geuzzz
Geuzzz's picture
Last seen: 3 hours 9 min ago
Fantastic build!
FmC
FmC's picture
Last seen: 6 months 3 days ago
Cool build. Would be nice to see more pictures if you have any. Beer
Firelight2
Firelight2's picture
Last seen: 2 hours 29 min ago
Absolutely awesome build!
Wonderful work with that heatsink and active cooling. OL would be proud! Cool
How long can it run on turbo with the fan speed set to high?
Got any outdoor beamshots at turbo?
Flashy Mike
Thanks for the info. So the electrical contact for batt- is done only by the 2 tubes connected with epoxy? Since I have a somehow similar mod in my mind I wonder if over the time the pressure between the 2 tubes decreases and the contact resistance rises.
The tubes are nice, they look similar to the Q8.
southland
southland's picture
Deserves a bump.
